ATI Damper Pulley Alignment?
#2690652
08/23/19 02:32 PM
08/23/19 02:32 PM
Posts: 1,810 North Dakota
Azzkikrcuda
North Dakota
Looking at getting ATI Damper part number 917470E, Which lists as working with stock cover and pulley alignment. Can anyone confirm stock pulleys will line up with this Damper. Thanks.
The only Carbs I care about are under the hood!
Re: ATI Damper Pulley Alignment?
[Re: Azzkikrcuda]
#2690659
08/23/19 02:52 PM
08/23/19 02:52 PM
Posts: 43,274 Bend,OR USA
Cab_Burge
Is that the part number for a BB? If so what year are you working on?
[Re: Cab_Burge]
#2690687
08/23/19 05:09 PM
08/23/19 05:09 PM
Azzkikrcuda
North Dakota
Internal balance, Big Block mopar
[Re: Azzkikrcuda]
#2690719
08/23/19 06:57 PM
08/23/19 06:57 PM
Posts: 277 MN
Willie68coronet
MN
Looking at getting ATI Damper part number 917470E, Which lists as working with stock cover and pulley alignment. Can anyone confirm stock pulleys will line up with this Damper. Thanks. Yeah I have that damper on my 440 with stock timing cover and pulleys. Lined up straight for me
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
[Re: Azzkikrcuda]
#2690740
08/23/19 08:47 PM
08/23/19 08:47 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
ATI 917470E
I believe that I need to use a 0.060" spacer behind the WP pulley.
[Re: Azzkikrcuda]
#2690895
08/24/19 11:29 AM
08/24/19 11:29 AM
Posts: 277 MN
Willie68coronet
MN
I bought the water pump spacer he mentioned but didn't need it when I mocked everything up.
I used Superformance gaskets everywhere, which are thicker than fel pro. That could be a difference or some other variable.
[Re: second 70]
#2690903
08/24/19 12:16 PM
08/24/19 12:16 PM
BSB67
Prospect, PA
.060 is less than 1/16" I bet the factory wasn't that precise. And it's with an aftermarket WP housing and pump. WP to block and WP housing to WP gaskets are 0.030". At the end of the day, I would say it lines up as best as one could expect considering the stack/variables.
[Re: Azzkikrcuda]
#2690939
08/24/19 02:43 PM
08/24/19 02:43 PM
Azzkikrcuda
North Dakota
Thanks everyone for the info. Sounds like it should work.
[Re: BSB67]
#2691149
08/25/19 10:18 AM
08/25/19 10:18 AM
Posts: 1,710 central il.
second 70
central il.
.060 is less than 1/16" I bet the factory wasn't that precise. And it's with an aftermarket WP housing and pump. WP to block and WP housing to WP gaskets are 0.030". At the end of the day, I would say it lines up as best as one could expect considering the stack/variables. Heck better than that yours look perfect.
[Re: second 70]
#2692749
08/29/19 10:18 PM
08/29/19 10:18 PM
Azzkikrcuda
North Dakota
Got the ATI Damper today and measured pulley location against a stock damper. Was only 0.03 inch difference. Using Stock pulley setups with this Damper should not be a problem.
