Page 3 of 5 1 2 3 4 5
Re: dead dakota.........still [Re: rhad] #2689715
08/20/19 12:24 PM
08/20/19 12:24 PM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
started right up this morning,then died,no restart,checked spark,none!!,over the years of owning this truck ive come to discover its USUALLY the crank sensor,and the one in there now is less than 6 months old,so i did a ohm test on the one i replaced last fall,it showed bad,so i ordered a aftermarket one to replace the mopar one i put in last fall,its lots cheaper than oem and has a 36 month warranty,if this dont fix it then DUH!!!,im running out of ammo for the parts cannon,and money also!
my ladder of success is missing some rungs
Re: dead dakota.........still [Re: rhad] #2689717
08/20/19 12:26 PM
08/20/19 12:26 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Have you considered the PCM may be bad?
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: dead dakota.........still [Re: 3hundred] #2689882
08/20/19 10:52 PM
08/20/19 10:52 PM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
pcm has been changed!
Re: dead dakota.........still [Re: rhad] #2690316
08/22/19 12:02 PM
08/22/19 12:02 PM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
i got the crank sensor out this morning,.its a mopar part about 6 months old,according to my factory service manual it tests bad,so im going aftermarket this time,about half the price and might be made in the same mexican factory,or not!!
Re: dead dakota.........still [Re: rhad] #2690559
08/23/19 09:14 AM
08/23/19 09:14 AM
Between Houston & Galveston TX
SattyNoCar Online work
SattyNoCar  Online Work
I have nothing to add. Just wanted to say you have more patience than me! By this time, one of three things would have happened had this been mine. 1) taken it to a shop 2) called auto recyclers to pick it up 3) drug out back and set on fire. work
Thanks for keeping us posted.
John
Re: dead dakota.........still [Re: SattyNoCar] #2690561
08/23/19 09:17 AM
08/23/19 09:17 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
That's what happened to the wife's '93 Ramcharger, couldn't get it fixed, set it out front until somebody came by and wanted it.
Robert
'69 300 Convertible
'16 300 S Hemi
Re: dead dakota.........still [Re: 3hundred] #2690797
08/23/19 10:39 PM
08/23/19 10:39 PM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
put in the standard motor parts sensor this afternoon,it checked ok,and the old dakota runs good,the main reason i kept after getting it fixed is because ive owned it for 24 yrs ,it does ok on gas and its like a old friend,plus being a v6 with a 391 sure grip 2wd ive hauled and pulled more than you would ever believe,such as a 92 clubcab cummins from east texas to east kansas,i was grossing right at 12,000 # on that trip!!!
if i have more problems ill holler back!
Re: dead dakota.........still [Re: rhad] #2690828
08/24/19 03:52 AM
08/24/19 03:52 AM
Guitar Jones Offline
Mopar over the counter parts should have a one year warranty.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: dead dakota.........still [Re: Guitar Jones] #2691068
08/24/19 11:01 PM
08/24/19 11:01 PM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
im the worlds worst at keeping receipts!!!
Re: dead dakota.........still [Re: rhad] #2691148
08/25/19 10:18 AM
08/25/19 10:18 AM
If you paid by card, and have an idea when you bought it, they may be able to find record of your purchase.
(I'm bad with receipts too blush )
John
Re: dead dakota.........still [Re: SattyNoCar] #2691178
08/25/19 11:13 AM
08/25/19 11:13 AM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
well CRAP!!!,went for a drive and it died!!,restarted after a minute,im at a total loss!
ive always been Leary of something good as its usually followed by something bad,and im 3000% correct this time
Re: dead dakota.........still [Re: rhad] #2691187
08/25/19 11:26 AM
08/25/19 11:26 AM
Needs a fresh set of eyes. I'd take it to a shop you can trust.
John
Re: dead dakota.........still [Re: SattyNoCar] #2691257
08/25/19 03:40 PM
08/25/19 03:40 PM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
i agree on a fresh set of eyes,im gonna pull the cps out and retest it,what would cause it to go bad?,i have another ecm ,but i changed it when this started will a scanner work on obd1 enough to tell the problem?(i dont have any kind of scanner)
Re: dead dakota.........still [Re: rhad] #2691359
08/25/19 08:55 PM
08/25/19 08:55 PM
How to pull codes on obd1. This video shows how, and ...........
He relies on the factory tach too much. Mine is all over the place and runs fine. He seems to focus on the cps, but briefly mentioned a possible bad speed sensor as well?
John
Re: dead dakota.........still [Re: SattyNoCar] #2691390
08/25/19 10:16 PM
08/25/19 10:16 PM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
i know how to pull codes,just do the key 3 times thing,problem is i cant get the blinks right!!,and it never sets a code,nor does it turn on the check engine light!!!
Re: dead dakota.........still [Re: rhad] #2691752
08/26/19 10:46 PM
08/26/19 10:46 PM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
i pulled the aftermarket cps,it was just long enough to be rubbing on the flex plate ,so............new mopar cps tomorrow,mopar comes with a small piece of cardboard on the tip to set the depth i guess?,aftermarket dont
im getting real good at changing these!!
Re: dead dakota.........still [Re: rhad] #2692109
08/27/19 10:42 PM
08/27/19 10:42 PM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
got the new mopar CPS installed this evening,started right up,test drive 2morro,keep your fingers and toes crossed
no cardboard spacer on the new CPS
Re: dead dakota.........still [Re: rhad] #2692454
08/28/19 10:59 PM
08/28/19 10:59 PM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
drove just fine today,maybe the CPS was the problem all along????????
time will tell
Re: dead dakota.........still [Re: rhad] #2692755
08/29/19 11:08 PM
08/29/19 11:08 PM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
started this morning ,then died restarted and ran fine after that,so im gonna call it fixed,unless it acts up again!!
Re: dead dakota.........still [Re: rhad] #2693045
08/30/19 11:21 PM
08/30/19 11:21 PM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
died this morning after about 10 minutes,did restart after setting for a minute or so
