Page 2 of 3 1 2 3
Re: E-Body Hood Scoop?? [Re: tboomer] #2690400
08/22/19 04:44 PM
08/22/19 04:44 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Nope.
Re: E-Body Hood Scoop?? [Re: BradH] #2690403
08/22/19 05:07 PM
08/22/19 05:07 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
That thing is going to slow you down 2mph because of all the air it's grabbing.
Like mounting a 5 gallon bucket on the hood. laugh
Re: E-Body Hood Scoop?? [Re: gzig5] #2690476
08/22/19 09:35 PM
08/22/19 09:35 PM
BradH Offline
BradH  Offline
Then I'll put a 5" cowl scoop on it.
Re: E-Body Hood Scoop?? [Re: BradH] #2690510
08/23/19 12:20 AM
08/23/19 12:20 AM
Texas
mprhound Offline
mprhound  Offline
Texas
This is a drag pac scoop on a Mas hood that I cut the six pack scoop off
Re: E-Body Hood Scoop?? [Re: gzig5] #2690544
08/23/19 08:17 AM
08/23/19 08:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
My car picked up 1.5 MPH when I put a sealed scoop on it..(not the same scoop but bigger)
wave
Re: E-Body Hood Scoop?? [Re: MR_P_BODY] #2690677
08/23/19 04:29 PM
08/23/19 04:29 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
My hood did this when I sealed it! guess I need better hood pins shocked
Re: E-Body Hood Scoop?? [Re: Mr340] #2690684
08/23/19 05:00 PM
08/23/19 05:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
One thing I did was build my hood in 2 sections.. the center is smaller and has 3 clips and the outer section
holding it down.. the outer piece (hood itself) has 10 fasteners holding it down.. good to as at least 152 mph
plus no glue holding it together
wave
Re: E-Body Hood Scoop?? [Re: MR_P_BODY] #2690831
08/24/19 05:45 AM
08/24/19 05:45 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
Here's ours. It's a mongrelized 6 pack 9" in height, clears an Indy tunnel ram with 2 1150's and a 4 inch filter. not to every ones taste but we sorta got used to it. Built because we used to travel the car on an open trailer, now we use an enclosed I'm going to get a flat hood and cut a hole in it and poke the carbs through with a (purple) perspex scoop
Re: E-Body Hood Scoop?? [Re: Tig] #2690838
08/24/19 07:42 AM
08/24/19 07:42 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Do this car see any street use ?
Re: E-Body Hood Scoop?? [Re: racerx] #2690850
08/24/19 09:03 AM
08/24/19 09:03 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
If you are on about ours then no, not at the moment. Over here in the UK, we have to have an "MOT" which is a certificate of road worthiness test. Unfortunately it won't pass due to having the forward vision obscured by the scoop, another reason why I'm going to a flat hood but every thing else is OK up
Re: E-Body Hood Scoop?? [Re: Tig] #2690858
08/24/19 09:14 AM
08/24/19 09:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Do they(UK) allow any height scoops to be legal
wave
Re: E-Body Hood Scoop?? [Re: MR_P_BODY] #2690876
08/24/19 10:11 AM
08/24/19 10:11 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
wave
Yeah, if it had been 3 or 4 inches in height we might have got away with it but it's really wide too. I've also once drove into a short scale dragster in the pairing lanes so i can see the argument blush
Re: E-Body Hood Scoop?? [Re: Mr340] #2691003
08/24/19 07:19 PM
08/24/19 07:19 PM
BradH Offline
BradH  Offline
What brand hood? Pin-on at all 4 corners, or hinged in the back?
Re: E-Body Hood Scoop?? [Re: Tig] #2691004
08/24/19 07:21 PM
08/24/19 07:21 PM
BradH Offline
BradH  Offline
Here's ours. It's a mongrelized 6 pack 9" in height...
Lose any MPH as the scoop kept growing over time?
Re: E-Body Hood Scoop?? [Re: mprhound] #2691006
08/24/19 07:25 PM
08/24/19 07:25 PM
BradH Offline
BradH  Offline
Looks nice; I had to grow my own. Apparently you can buy a complete early-style (2008 thru ?) lift-off Drag Pak hood for $2K+, but nobody offers a replica/replacement Drag Pak scoop separately.
Re: E-Body Hood Scoop?? [Re: BradH] #2691030
08/24/19 08:45 PM
08/24/19 08:45 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Unlimited, hinged, stock latch with 2 quik latch pins( the small ones, my mistake, should have phonyed up for the larger ones) came off going thru the traps about 115 mph.
Re: E-Body Hood Scoop?? [Re: BradH] #2691076
08/24/19 11:45 PM
08/24/19 11:45 PM
Texas
mprhound Offline
mprhound  Offline
Texas
I got lucky, found someone who lost a hood in the big end, the scoop was ok, when they ordered a new hood it came with a new scoop, so I talked them out of the old one
Re: E-Body Hood Scoop?? [Re: BradH] #2691104
08/25/19 05:50 AM
08/25/19 05:50 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
Not noticeably, the scoop grew as the hp grew laugh
I'll have to wait until next year to see if the flat hood and perspex scoop improves things.
Re: E-Body Hood Scoop?? [Re: Mr340] #2691118
08/25/19 07:56 AM
08/25/19 07:56 AM
Mo.
racerx Offline
racerx  Offline
Mo.
work you no I have this problem with all of the T/A style hood that I own, I've lost one on the big end. They seem to stress crack right were they gets molded on.
Re: E-Body Hood Scoop?? [Re: racerx] #2691317
08/25/19 06:36 PM
08/25/19 06:36 PM
Jacksonville Fl
70BigBlockSE Offline
Jacksonville Fl
TA hood, always been a fan
Page 2 of 3 1 2 3
