Re: Hard starts. Is this my starter? [Re: closer9] #2684006
08/03/19 11:13 AM
08/03/19 11:13 AM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
Rockauto shows a couple choices for your 67 Belvedere. 4 ga, has pictures and if you look at the AC Delco cables it gives the specifications.
Re: Hard starts. Is this my starter? [Re: Sniper] #2684013
08/03/19 11:26 AM
08/03/19 11:26 AM
SW MO
closer9 Offline OP
closer9  Offline OP
SW MO
I saw those, but they are just battery to starter. No solenoid or relay, just a flying lead with butt crimp. That's what I had on there before. Then made my own relay to solenoid and relay to battery. Just thought it would be nice to find one already made correct.
Daily:
'19 Frontier 4WD
Belle:
'67 Belvedere Convertible, 318/727 in Go ManGo!
Other:
'64 C10, 283/3 on the tree
Re: Hard starts. Is this my starter? [Re: closer9] #2684023
08/03/19 11:53 AM
08/03/19 11:53 AM
moparx Offline
moparx  Offline
glad it was an easy find. up
new cables and you are good to go.
beer
Re: Hard starts. Is this my starter? [Re: closer9] #2684027
08/03/19 11:58 AM
08/03/19 11:58 AM
nowhere
nowhere
For switch to starter
Delco part numbers
4ST24, 4 ga. 24" eyelet each end
4ST30, 4 ga. 30" eyelet each end
1ST19, 1 ga 19" eyelet each end
1ST32, 1 ga 32" eyelet each end
For battery to switch
Delco part numbers
4BC16, 4 ga. 16" no pigtail
4BC15X 4 ga. 15" with a crimp pigtail
4BC22 22" 4 ga. no pigtail
4BC22X 4 ga. with a crimp pigtail
BC18 00 ga. 18" no pigtail
1BC19 1 ga. 19" no pigtail
Re: Hard starts. Is this my starter? [Re: Sniper] #2684043
08/03/19 12:47 PM
08/03/19 12:47 PM
^^^ noted, thank you!
Re: Hard starts. Is this my starter? [Re: RapidRobert] #2684452
08/04/19 08:52 PM
08/04/19 08:52 PM
SW MO
closer9 Offline OP
closer9  Offline OP
SW MO
Guess I spoke too soon. Replaced battery cables and cleaned everything up. Cold she started and ran great. Drove her around for about 20 or 30 minutes. Let her sit for 20 and she won't start. Starter seems to be really dragging. Guess it's time to pull the battery and starter and have them tested.
Daily:
'19 Frontier 4WD
Belle:
Other:
Re: Hard starts. Is this my starter? [Re: closer9] #2684593
08/05/19 10:06 AM
08/05/19 10:06 AM
central il.
second 70 Offline
second 70  Offline
central il.
Try another known good battery. Heat kills a weak battery. I've seen them test good and still be the problem.
Re: Hard starts. Is this my starter? [Re: second 70] #2684600
08/05/19 10:11 AM
08/05/19 10:11 AM
SW MO
closer9 Offline OP
closer9  Offline OP
SW MO
I was just thinking about that on my way to work. I just put a new battery in my buddy's Jeep and it's still in my driveway.
Daily:
'19 Frontier 4WD
Belle:
Other:
Re: Hard starts. Is this my starter? [Re: closer9] #2685159
08/06/19 10:24 PM
08/06/19 10:24 PM
SW MO
closer9 Offline OP
closer9  Offline OP
SW MO
Well swapping batteries didn't help. So, after leaving the door open and seeing the interior lights flicker while idling, figured I'd just start checking everything. Long story short, I pulled the bulkhead connector and yup, melted connector.
I managed to pry out the wires, clean them up and move them to an open slot on the end. So far cold she's starting and ildling nice. Guess I need to consider ammeter bypass/volt meter?
I still need to see how she does on a hot start. Could still have a heat soak starter problem.
Daily:
'19 Frontier 4WD
Belle:
Other:
Re: Hard starts. Is this my starter? [Re: closer9] #2689112
08/18/19 03:22 PM
08/18/19 03:22 PM
SW MO
closer9 Offline OP
closer9  Offline OP
SW MO
Fixing the connector helped with the interior lights, but didn't seem to do anything for my hot start issue. I pulled the starter and had it tested at Autozone. It tested good as I assumed it would. I still brought it home and tossed it in the scrap pile. I bought a new (NOT rebuilt) Delco starter for a '95 Dakota. Fit perfect with no mods and WOW!!! I've never had a carbureted anything start this good. I haven't had time to get her good and hot, but just down the road and back, then sit for a bit and she still starts great. Scared me the first time she started so fast. Even on her best days it would take a couple seconds of cranking. Now I literally just tap the key and she's running.
So, since I started this adventure a few weeks/months ago, I've shimmed my distributor, new plug wires, cleaned the plugs and gapped them to 0.045", switched to HEI with Holley (Ford style) coil, GM ignition module, new battery cables, new mini starter, new ignition switch and fixed (band-aided) the bulkhead connector. I still plan to do the bulkhead connector and ammeter bypass, however. Someday I may consider custom gauges with a volt meter, but for now I may just see what I can fit in the ammeter slot.
I am also considering a starter heat wrap...
Daily:
'19 Frontier 4WD
Belle:
Other:
