IRON CNC HEAD SHOP #2688784
08/17/19 04:20 PM
08/17/19 04:20 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
There is a shop. I think in Ohio, that has a CNC program for BB iron Mopar heads. Anyone have that info? Thanks
Re: IRON CNC HEAD SHOP [Re: A/MP] #2688790
08/17/19 04:37 PM
08/17/19 04:37 PM
Ohio
moparjoe360.4 Offline
Ohio
The shop is called KG Engines. Here’s their website:
https://kgengines.wixsite.com/kgengines
Re: IRON CNC HEAD SHOP [Re: A/MP] #2688820
08/17/19 05:57 PM
08/17/19 05:57 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The quality of a CNC head = the quality of a xerox machine.
At best it can be only slightly worse than the original.
Boffin Emeritus
Re: IRON CNC HEAD SHOP [Re: polyspheric] #2688888
08/17/19 08:37 PM
08/17/19 08:37 PM
A727Tflite Offline
A727Tflite  Offline
Seen some of their work on a few cars, the cars have picked up considerable power over some comparable hand ported stuff.
While they do port work, thier claim to fame is not the actual port development but taking a proven port and moving it to the CNC machine.
Saves considerable time (and consequently money) with consistent port to port flow.
Re: IRON CNC HEAD SHOP [Re: A727Tflite] #2688895
08/17/19 08:48 PM
08/17/19 08:48 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Exactly: if the model* from which the data points were taken is successful, and the tooling is properly programmed**, the CNC product will work well. If either of these is not adequate, it won't.
* most common error I've heard of:
Customer: "I have an iron BBM. What castings and chamber volume do you have programs for?"
Shop: "................... What?" He'll use the one he has, even if it's from a different but interchangeable casting (906 vs. 452 etc.)
** running the program from fewer angles or at higher speed gives coarse finish and less accuracy on internal surfaces
Boffin Emeritus
Re: IRON CNC HEAD SHOP [Re: polyspheric] #2688981
08/18/19 08:33 AM
08/18/19 08:33 AM
Ohio
Ohio
Wow... it’s nice to see someone running off at the mouth about a company they have NO experience with. I personally don’t have experience with their heads ether but I have seen them in person and I know TONS of people that do and make big power with them. I also know for a fact that the owner has separate programs for at least 4 different BBM head castings (516,915,906,452etc) rolleyes
Re: IRON CNC HEAD SHOP [Re: moparjoe360.4] #2688986
08/18/19 08:54 AM
08/18/19 08:54 AM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
If you had read his post before you ran off at the mouth, you would see he wasn't talking about any company in particular and that you actually agree with him, different castings need different programs.
Kevin
Re: IRON CNC HEAD SHOP [Re: Twostick] #2689016
08/18/19 10:27 AM
08/18/19 10:27 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
516, 906, 452 heads don’t have similar enough port shapes to be able to use the same program for all 3.
If one were to try it, they’d likely end up with holes in the head.
Re: IRON CNC HEAD SHOP [Re: Twostick] #2689017
08/18/19 10:27 AM
08/18/19 10:27 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Wonder if they do any work on the source heads. Might be a reliable avenue for them.
Getting old just means you were smarter than some and luckier than others.
Re: IRON CNC HEAD SHOP [Re: dannysbee] #2689031
08/18/19 11:03 AM
08/18/19 11:03 AM
Modern Cylinder head has a program for CNC porting the 440 Source heads scope
One of my customer has a set on one of his motors.
Re: IRON CNC HEAD SHOP [Re: Cab_Burge] #2689046
08/18/19 11:41 AM
08/18/19 11:41 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
They did mine. Very nice work! They even CNC the combustion chambers.
'63 Dodge 330
11.19 @ 121 mph
Re: IRON CNC HEAD SHOP [Re: fast68plymouth] #2689047
08/18/19 11:42 AM
08/18/19 11:42 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Theirs or the engine's? grin
'63 Dodge 330
11.19 @ 121 mph
Re: IRON CNC HEAD SHOP [Re: fast68plymouth] #2689093
08/18/19 02:12 PM
08/18/19 02:12 PM
Washington
skrews Offline
skrews  Offline
Washington
Not to mention broken tooling.
