MSD BOX #2688916
08/17/19 10:32 PM
08/17/19 10:32 PM
Fargo ND
moparphilll Offline OP
Fargo ND
the best place to hook up the power wire on a new MSD box on a 1970 challenger is??
Re: MSD BOX [Re: moparphilll] #2688918
08/17/19 10:38 PM
08/17/19 10:38 PM
If your talking about the 12V on and off wire take it to the fuse box that will provide 12V in the on position, that or splice it into the ballast resistor
ignition feed wires, both in the start and run positions scope wrench
Re: MSD BOX [Re: Cab_Burge] #2688927
08/17/19 11:16 PM
08/17/19 11:16 PM
Martinsville, IN
cdwmotorsports Online content
cdwmotorsports  Online Content
Martinsville, IN
I ran a hot feed from the big post on the starter relay to a new auxiliary fuse box (actually I have 2 of them) and I run all of my accessory stuff on it. Fuel and water pumps, ignition box and gauge lights all run of of one and the other is 12v keyed power for electric fans and dakota digital controller.
eBay-cdwmotorsports
Re: MSD BOX [Re: moparphilll] #2688988
08/18/19 08:59 AM
08/18/19 08:59 AM
Banana Republic
FM3AAR Online content
FM3AAR  Online Content
Banana Republic
Per my MSD instructions, I powered it directly from the battery.
“You’ll own nothing” — And “you’ll be happy about it.”
K. Schwab
Re: MSD BOX [Re: FM3AAR] #2689002
08/18/19 09:47 AM
08/18/19 09:47 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
if i remember correctly.
if you use the ballast wiring for the key on power you will need to splice the brown and blue wires together ( i think that is the power wire colors ). one has voltage at key on and no voltage at key start. and the other has no voltage on key on and voltage at key start.
perception is 90% of reality
Re: MSD BOX [Re: FM3AAR] #2689006
08/18/19 09:57 AM
08/18/19 09:57 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I did the same thing.
Re: MSD BOX [Re: 340Cuda] #2689036
08/18/19 11:21 AM
08/18/19 11:21 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Their wiring instructions are easy to find on the 'net.
The 10ga wires to battery is best, starter relay battery post works.
Main thing is the box never sees interruption of power/ground/signal when running.
