Re: MSD BOX
[Re: Cab_Burge]
#2688927
08/17/19 11:16 PM
08/17/19 11:16 PM
Posts: 1,444 Martinsville, IN
cdwmotorsports
Martinsville, IN
I ran a hot feed from the big post on the starter relay to a new auxiliary fuse box (actually I have 2 of them) and I run all of my accessory stuff on it. Fuel and water pumps, ignition box and gauge lights all run of of one and the other is 12v keyed power for electric fans and dakota digital controller.
eBay-cdwmotorsports
Re: MSD BOX
[Re: moparphilll]
#2688988
08/18/19 08:59 AM
08/18/19 08:59 AM
Posts: 2,331 Banana Republic
FM3AAR
Banana Republic
Per my MSD instructions, I powered it directly from the battery.
“You’ll own nothing” — And “you’ll be happy about it.” K. Schwab
Re: MSD BOX
[Re: FM3AAR]
#2689002
08/18/19 09:47 AM
08/18/19 09:47 AM
Posts: 4,916 new berlin wisconsin
Mr T2U
if i remember correctly. if you use the ballast wiring for the key on power you will need to splice the brown and blue wires together ( i think that is the power wire colors ). one has voltage at key on and no voltage at key start. and the other has no voltage on key on and voltage at key start.
perception is 90% of reality
