Re: shaker base plate stud markings?
[Re: mccannix]
#2689091
08/18/19 02:11 PM
08/18/19 02:11 PM
Posts: 6,391 Abilene, Texas
fastmark
Abilene, Texas
Chrysler used the numbered stud on lots of applications on various models for many years.... To name a few...E body trunk plates, top rad support, window guide part ..top picture. Earliest I have seen them is on these lower window stops on a 67 Belvedere..bottom picture The trick is removing them. So the ones you have in the picture that are off are ones you removed and not ones you have purchased, correct?
