70 Challenger, no gas, oil pressure or water temperature #2688729
08/17/19 12:46 PM
08/17/19 12:46 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I have no reading on my gas gauge, water temperature or oil pressure.
I had to put a jump on my POS red tip restoration battery.
Put in on 200 amp quick start.
All fuses look ok.
Where do I go from here?
Re: 70 Challenger, no gas, oil pressure or water temperature [Re: Sammy] #2688730
08/17/19 12:52 PM
08/17/19 12:52 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Voltage limiter, all the gauges run off it.
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: 70 Challenger, no gas, oil pressure or water temperature [Re: VCODE] #2688733
08/17/19 12:54 PM
08/17/19 12:54 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Bob
What's the part that plugs in to the interior bulkhead?
Is that the voltage limiter?
Re: 70 Challenger, no gas, oil pressure or water temperature [Re: Sammy] #2688735
08/17/19 01:04 PM
08/17/19 01:04 PM
Midwest
O
On the edge 02 Offline
O
Midwest
Should be a little aluminun colored oblong multi pronged thing lol that plugs into the back of your dash. They make solid state units these days.
Re: 70 Challenger, no gas, oil pressure or water temperature [Re: On the edge 02] #2688749
08/17/19 01:59 PM
08/17/19 01:59 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Had to pull the radio out but how do you get your arm in there to remove that little nut?
Is that nut a 1/4 or 7/32?
I'm sweating my azz off.
Re: 70 Challenger, no gas, oil pressure or water temperature [Re: Sammy] #2688752
08/17/19 02:04 PM
08/17/19 02:04 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Did you hook a test light to the temp gauge sending unit wire before you tore into things? If the limiter is working the test light will blink. Did you also use the test light to check the fuses or did you just eyeball them? Some times a blown fuse is hard to see.
Re: 70 Challenger, no gas, oil pressure or water temperature [Re: stumpy] #2688774
08/17/19 03:36 PM
08/17/19 03:36 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Going to try now.
Getting to the limiter is almost impossible
Re: 70 Challenger, no gas, oil pressure or water temperature [Re: stumpy] #2688775
08/17/19 03:37 PM
08/17/19 03:37 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Ots weird that this just happened overnight?.or was this around awhile? Check back to the last thing you did on the car, maybe something got knocked off..unplugged..etc..
Re: 70 Challenger, no gas, oil pressure or water temperature [Re: Sammy] #2688778
08/17/19 04:00 PM
08/17/19 04:00 PM
Midwest
O
O
Midwest
Nut? It just should pull out if I'm not mistaken. Similar to a b body dash and might be on the right side looking up from underneath.
Re: 70 Challenger, no gas, oil pressure or water temperature [Re: On the edge 02] #2688780
08/17/19 04:15 PM
08/17/19 04:15 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
That's what I was thinking.
Maybe I'm looking at the wrong thing.
This is the 1st time working on a E body.
I am not sure now where this voltage limiter would be at.
Re: 70 Challenger, no gas, oil pressure or water temperature [Re: AARCONV] #2688781
08/17/19 04:18 PM
08/17/19 04:18 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Red top battery was very weak so I pit a 40 amp charge on the car and that didnt work, so I put a 200 amp quick start on and it fired up but noticed only the Ammeter is working.
Everything else is dead.
Re: 70 Challenger, no gas, oil pressure or water temperature [Re: Sammy] #2688785
08/17/19 04:24 PM
08/17/19 04:24 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Anyone got a picture of a 1970 Ralleye Dash voltage limiter?
Re: 70 Challenger, no gas, oil pressure or water temperature [Re: Sammy] #2688789
08/17/19 04:35 PM
08/17/19 04:35 PM
pull the L connectors off of the gas tank sending unit & the water temp sender on the eng (rear of eng if SB/front if BB). Key on. see if you have any voltage.
Re: 70 Challenger, no gas, oil pressure or water temperature [Re: Sammy] #2688794
08/17/19 04:39 PM
08/17/19 04:39 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
On a ralleye dash the limiter is part of the fuel gauge and you either replace the fuel gauge or find the instructions on by passing it with a regular limiter. That is why I suggested checking the fuses and sending unit wire with a test light first. You can test either the temp gauge or oil pressure gauge wire which ever if easiest to get to. Either should blink if the limiter is good. You could also check the screws holding the instrument cluster to the dash because they act as ground.
Re: 70 Challenger, no gas, oil pressure or water temperature [Re: Sammy] #2688806
08/17/19 05:26 PM
08/17/19 05:26 PM
central il.
second 70 Offline
second 70  Offline
central il.
Sammy here’s a picture of it on a non rallye dash out of my 70 Cuda. It is the same on the rallye dash because this one came off the rallye dash because the terminal is broken and I used the good one off this dash for the rallye dash that is in car now.
The bolt head is 1/4”.
Mike
Re: 70 Challenger, no gas, oil pressure or water temperature [Re: second 70] #2688812
08/17/19 05:36 PM
08/17/19 05:36 PM
Midwest
O
O
Midwest
That's her.
Re: 70 Challenger, no gas, oil pressure or water temperature [Re: stumpy] #2688813
08/17/19 05:40 PM
08/17/19 05:40 PM
Midwest
O
O
Midwest
Stumpy, also gauges like water and oil can be unplugged and grounded to see if the issue is in the gauge or wiring. Sounds like a limiter to me thou since all but amp ( direct power ) are not responding or a grounding of the cluster frame.
Re: 70 Challenger, no gas, oil pressure or water temperature [Re: Sammy] #2688817
08/17/19 05:52 PM
08/17/19 05:52 PM
central il.
second 70 Offline
second 70  Offline
central il.
Sammy also check this link on ebay. https://www.ebay.com/itm/Cuda-Chall...el-Mopar-Instrument-Cluster/283494246527 For some reason I can't copy the picture but look for the one that shows the back of the dash. It doesn't have the limit switch installed but if you look at the picture you can see two bumps with a hole between them this is where it mounts. (Notice the two bumps on the side of the limiter picture I posted). Right next to hole marked DBL. In the picture it's on the bottom but in car it's the top.
Hope this helps, Mike
Re: 70 Challenger, no gas, oil pressure or water temperature [Re: On the edge 02] #2688836
08/17/19 06:24 PM
08/17/19 06:24 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
But if you aren't quick enough with the key you can fry the gauges by pegging them out.
Re: 70 Challenger, no gas, oil pressure or water temperature [Re: stumpy] #2688840
08/17/19 06:29 PM
08/17/19 06:29 PM
Midwest
O
O
Midwest
True, great point!!!
