Re: 70 Challenger, no gas, oil pressure or water temperature
[Re: Sammy]
#2688730
08/17/19 12:52 PM
08/17/19 12:52 PM
Posts: 2,377 White Plains, NY
VCODE
White Plains, NY
Voltage limiter, all the gauges run off it. Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
[Re: VCODE]
#2688733
08/17/19 12:54 PM
08/17/19 12:54 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Voltage limiter, all the gauges run off it. Bob What's the part that plugs in to the interior bulkhead? Is that the voltage limiter?
[Re: Sammy]
#2688735
08/17/19 01:04 PM
08/17/19 01:04 PM
Posts: 60 Midwest
On the edge 02
Midwest
Should be a little aluminun colored oblong multi pronged thing lol that plugs into the back of your dash. They make solid state units these days.
[Re: stumpy]
#2688774
08/17/19 03:36 PM
08/17/19 03:36 PM
Sammy
Wind Gap,Pa.
Did you hook a test light to the temp gauge sending unit wire before you tore into things? If the limiter is working the test light will blink. Did you also use the test light to check the fuses or did you just eyeball them? Some times a blown fuse is hard to see. Going to try now. Getting to the limiter is almost impossible
[Re: On the edge 02]
#2688780
08/17/19 04:15 PM
08/17/19 04:15 PM
Sammy
Wind Gap,Pa.
Nut? It just should pull out if I'm not mistaken. Similar to a b body dash and might be on the right side looking up from underneath. That's what I was thinking. Maybe I'm looking at the wrong thing. This is the 1st time working on a E body. I am not sure now where this voltage limiter would be at.
[Re: AARCONV]
#2688781
08/17/19 04:18 PM
08/17/19 04:18 PM
Sammy
Wind Gap,Pa.
Ots weird that this just happened overnight?.or was this around awhile? Check back to the last thing you did on the car, maybe something got knocked off..unplugged..etc.. Red top battery was very weak so I pit a 40 amp charge on the car and that didnt work, so I put a 200 amp quick start on and it fired up but noticed only the Ammeter is working. Everything else is dead.
[Re: Sammy]
#2688789
08/17/19 04:35 PM
08/17/19 04:35 PM
RapidRobert
pull the L connectors off of the gas tank sending unit & the water temp sender on the eng (rear of eng if SB/front if BB). Key on. see if you have any voltage.
[Re: Sammy]
#2688806
08/17/19 05:26 PM
08/17/19 05:26 PM
Posts: 1,707 central il.
second 70
central il.
Anyone got a picture of a 1970 Ralleye Dash voltage limiter? Sammy here’s a picture of it on a non rallye dash out of my 70 Cuda. It is the same on the rallye dash because this one came off the rallye dash because the terminal is broken and I used the good one off this dash for the rallye dash that is in car now. The bolt head is 1/4”. Mike
[Re: stumpy]
#2688813
08/17/19 05:40 PM
08/17/19 05:40 PM
Posts: 60 Midwest
On the edge 02
Midwest
Stumpy, also gauges like water and oil can be unplugged and grounded to see if the issue is in the gauge or wiring. Sounds like a limiter to me thou since all but amp ( direct power ) are not responding or a grounding of the cluster frame.
[Re: Sammy]
#2688817
08/17/19 05:52 PM
08/17/19 05:52 PM
second 70
central il.
Anyone got a picture of a 1970 Ralleye Dash voltage limiter? Sammy also check this link on ebay. https://www.ebay.com/itm/Cuda-Chall...el-Mopar-Instrument-Cluster/283494246527 For some reason I can't copy the picture but look for the one that shows the back of the dash. It doesn't have the limit switch installed but if you look at the picture you can see two bumps with a hole between them this is where it mounts. (Notice the two bumps on the side of the limiter picture I posted). Right next to hole marked DBL. In the picture it's on the bottom but in car it's the top. Hope this helps, Mike
#2688836
08/17/19 06:24 PM
08/17/19 06:24 PM
Posts: 32,929 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
Stumpy, also gauges like water and oil can be unplugged and grounded to see if the issue is in the gauge or wiring. Sounds like a limiter to me thou since all but amp ( direct power ) are not responding or a grounding of the cluster frame. But if you aren't quick enough with the key you can fry the gauges by pegging them out.
