Re: IRON CNC HEAD SHOP
[Re: A/MP]
#2688790
08/17/19 04:37 PM
08/17/19 04:37 PM
Posts: 394 Ohio
moparjoe360.4
Ohio
There is a shop. I think in Ohio, that has a CNC program for BB iron Mopar heads. Anyone have that info? Thanks The shop is called KG Engines. Here’s their website: https://kgengines.wixsite.com/kgengines
[Re: A/MP]
#2688820
08/17/19 05:57 PM
08/17/19 05:57 PM
Posts: 4,209 New York
polyspheric
New York
The quality of a CNC head = the quality of a xerox machine. At best it can be only slightly worse than the original.
Boffin Emeritus
[Re: A727Tflite]
#2688895
08/17/19 08:48 PM
08/17/19 08:48 PM
polyspheric
New York
taking a proven port and moving it to the CNC Exactly: if the model* from which the data points were taken is successful, and the tooling is properly programmed**, the CNC product will work well. If either of these is not adequate, it won't.
* most common error I've heard of: Customer: "I have an iron BBM. What castings and chamber volume do you have programs for?" Shop: "................... What?" He'll use the one he has, even if it's from a different but interchangeable casting (906 vs. 452 etc.)
** running the program from fewer angles or at higher speed gives coarse finish and less accuracy on internal surfaces
Boffin Emeritus
[Re: moparjoe360.4]
#2688986
08/18/19 08:54 AM
08/18/19 08:54 AM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
** running the program from fewer angles or at higher speed gives coarse finish and less accuracy on internal surfaces Wow... it’s nice to see someone running off at the mouth about a company they have NO experience with. I personally don’t have experience with their heads ether but I have seen them in person and I know TONS of people that do and make big power with them. I also know for a fact that the owner has separate programs for at least 4 different BBM head castings (516,915,906,452etc) If you had read his post before you ran off at the mouth, you would see he wasn't talking about any company in particular and that you actually agree with him, different castings need different programs. Kevin
[Re: Twostick]
#2689016
08/18/19 10:27 AM
08/18/19 10:27 AM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
516, 906, 452 heads don’t have similar enough port shapes to be able to use the same program for all 3.
If one were to try it, they’d likely end up with holes in the head.
[Re: Twostick]
#2689017
08/18/19 10:27 AM
08/18/19 10:27 AM
Posts: 5,160 Texas
dannysbee
Texas
Wonder if they do any work on the source heads. Might be a reliable avenue for them.
Getting old just means you were smarter than some and luckier than others.
[Re: dannysbee]
#2689031
08/18/19 11:03 AM
08/18/19 11:03 AM
Posts: 43,237 Bend,OR USA
Cab_Burge
Modern Cylinder head has a program for CNC porting the 440 Source heads One of my customer has a set on one of his motors.
[Re: Cab_Burge]
#2689046
08/18/19 11:41 AM
08/18/19 11:41 AM
Posts: 4,692 Wichita
GY3
Wichita
Modern Cylinder head has a program for CNC porting the 440 Source heads One of my customer has a set on one of his motors. They did mine. Very nice work! They even CNC the combustion chambers.
[Re: fast68plymouth]
#2689047
08/18/19 11:42 AM
08/18/19 11:42 AM
GY3
Wichita
If one were to try it, they’d likely end up with holes in the head. Theirs or the engine's?
#2689093
08/18/19 02:12 PM
08/18/19 02:12 PM
Posts: 429 Washington
skrews
Washington
If one were to try it, they’d likely end up with holes in the head. Not to mention broken tooling.
