Re: bending cotter pins on tie rod ends and ball joints
[Re: Little Detroit]
#2690187
08/21/19 11:03 PM
08/21/19 11:03 PM
Posts: 21,504 N.E. OHIO, USA
A12
N.E. OHIO, USA
I really can't believe I wasted my time reading this thread, but I'll say it's darn entraining to say the least ,that so many do not have anything more constructive to do than try to make a mountain out of a mole hill. but then again I read it.
Yeah and it was your 426 HEMI numbered post too, something you can remember positively about a wasted post read. Little Detroit mopar Joined: Sep 2009 Posts: 426WV
[Re: John_Kunkel]
#2690413
08/22/19 05:45 PM
08/22/19 05:45 PM
Posts: 29,651 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
So, "correct" becomes "anal". Noted.
BTW, it's not impossible, I routinely do it on front suspension components that are the subject of this thread. He asked about this part; the way it came from the factory in the mid 70`s So are you are running a 1970's era factory in 2019 or just misreading the question?
[Re: Alaskan_TA]
#2690607
08/23/19 11:40 AM
08/23/19 11:40 AM
Posts: 25,767 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I understood the original question but merely commented on, what I consider, to be silliness. One strives to be "original" by installing cotter pins willy-nilly but has the chrome/paint redone to modern show standards.
[Re: John_Kunkel]
#2690790
08/23/19 10:26 PM
08/23/19 10:26 PM
Posts: 1,754 Phila
PhillyRag
Phila
I understood the original question but merely commented on, what I consider, to be silliness. One strives to be "original" by installing cotter pins willy-nilly but has the chrome/paint redone to modern show standards. . Where's "ROCK" these days? I want him to Sign my wheel well so that it's "factory line correct". Maybe he still has the pencil he used back then. Will that suffice? I'm 99.99999% there. Approaching the far outer reaches towards madness..
[Re: PhillyRag]
#2690853
08/24/19 09:06 AM
08/24/19 09:06 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
I understood the original question but merely commented on, what I consider, to be silliness. One strives to be "original" by installing cotter pins willy-nilly but has the chrome/paint redone to modern show standards. . Where's "ROCK" these days? I want him to Sign my wheel well so that it's "factory line correct". Maybe he still has the pencil he used back then. Will that suffice? I'm 99.99999% there. Approaching the far outer reaches towards madness.. Don't forget your little black Dill valve stem caps or you're still not done !
[Re: Alaskan_TA]
#2690892
08/24/19 11:14 AM
08/24/19 11:14 AM
Posts: 16,474 On the run…
BloFish
On the run…
My vote for thread of the year!
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#2690896
08/24/19 11:32 AM
08/24/19 11:32 AM
Posts: 20,639 in a cattle trailer down by th...
Guitar Jones
My vote for thread of the year! I just bend it back over the stud/bolt/spindle/whatever then cut the protruding meat ripper off flush with the nut. It ain't brain surgery.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: 62maxwgn]
#2690932
08/24/19 02:16 PM
08/24/19 02:16 PM
Posts: 13,576 md
mopars4ever
md
anyone know the size of the factory cotter pins i need to buy some. thanks Better be careful,90 % of cotter pins are made in china ! I have a box of NOS mopar pins. I`m not sure of the size. I will have to check. Update: These are the ones I have. Are these correct? If you need some and they will work for you let me know.
[Re: A12]
#2691027
08/24/19 08:33 PM
08/24/19 08:33 PM
Posts: 1,908 Nebraska
4406bbl
Nebraska
The green box of pins are not NOS, those were sold at mopar parts stores and are relabeled pik-a-nut, originals are shorter, and do not have the bend at the end. The wrench rounding them off sure seems to make them look right. The little stuff matters on a restoration in my opinion, Johns way is better, but would stick out like a sore thumb on a restoration. When I pulled my superbird apart you could tell the idler arm was changed, correct mopar part, but wrong pin installed nicely, it stuck out. I would install the pins right and nice on everything except a restoration. Believe me, if you install the pins nicely on a car with all the proper colors, boots and plating, the mopar vin crowd would point out your "mistake". You can't win.
[Re: 4406bbl]
#2691029
08/24/19 08:39 PM
08/24/19 08:39 PM
4406bbl
Nebraska
The green box of pins are not NOS, those were sold at mopar parts stores and are relabeled pik-a-nut, originals are shorter, and do not have the bend at the end. The wrench rounding them off sure seems to make them look right. The little stuff matters on a restoration in my opinion, Johns way is better, but would stick out like a sore thumb on a restoration. When I pulled my superbird apart you could tell the idler arm was changed, correct mopar part, but wrong pin installed nicely, it stuck out. I would install the pins right and nice on everything except a restoration. Believe me, if you install the pins nicely on a car with all the proper colors, boots and plating, the mopar vin crowd would point out your "mistake". You can't win. Made a mistake here, I should have said those pins are not assembly line correct, they could well be NOS.
[Re: mopars4ever]
#2691050
08/24/19 09:48 PM
08/24/19 09:48 PM
Posts: 1,039 INDIANA
Paul Jacobs
INDIANA
76 Yes, i do. NOS upper and lower arms. NOS idler and pitman arms. NOS torsion bar end bushing. Just got a NOS upper ball joint boot 2269127 that was missing from a member here. So it`s not pointless to me but maybe to most. Honestly, I really don`t care if someone feels its trivial or not. Some people feel a need to express their way of thinking all the time around here. I feel it`s trivia when someone needs to express what they feel is trivial or not. Why do they waste their time? Dunno??? I`m getting some good info even with all the ones trying to ruin someones post. Some are proud of their work and some are proud of how their mouth works. Don’t ever let someone’s opinion stop you from getting the details right- I’m doing another OE restoration right now (#7) and am fanatical about the way it’s going- but in the end it’s my car and satisfies me and that’s all that matters...
