Re: bending cotter pins on tie rod ends and ball joints
[Re: mopars4ever]
#2688155
08/15/19 05:57 PM
08/15/19 05:57 PM
Posts: 2,379 White Plains, NY
VCODE
White Plains, NY
Which way do you bend the cotter pins on a tie rod end and ball joints? I am wanting going to duplicate the way it came from the factory in the mid 70`s. thanks The best picture of lower ball joint on a 1970 Challenger R/T. As Barry said not all the same. Although I don't think I would copy that one. Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
[Re: Paul Jacobs]
#2688176
08/15/19 07:04 PM
08/15/19 07:04 PM
Posts: 13,596 md
mopars4ever
md
[Re: mopars4ever]
#2688217
08/15/19 08:43 PM
08/15/19 08:43 PM
Posts: 4,951 northwest USA
NANKET
northwest USA
The ones on the car had been replaced at one time or another so pics wouldn`t have helped me on this car. Also the factory service manual says not to line up the slot on the tie rod adjusting sleeve with the clamp opening. Does it really matter? Yes it really matters.
[Re: mopars4ever]
#2688624
08/17/19 01:07 AM
08/17/19 01:07 AM
Posts: 1,755 Phila
PhillyRag
Phila
Which way do you bend the cotter pins on a tie rod end and ball joints? I am wanting going to duplicate the way it came from the factory in the mid 70`s. thanks You definitely need that "special" tool that I'm sure the workers used to get that "factory correct bend" in those pins.
[Re: PhillyRag]
#2688681
08/17/19 10:14 AM
08/17/19 10:14 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Which way do you bend the cotter pins on a tie rod end and ball joints? I am wanting going to duplicate the way it came from the factory in the mid 70`s. thanks You definitely need that "special" tool that I'm sure the workers used to get that "factory correct bend" in those pins. Personally,worrying about how a cotter pin is bent is going a little far but that's just me !!
[Re: 62maxwgn]
#2688744
08/17/19 01:39 PM
08/17/19 01:39 PM
Posts: 13,596 md
mopars4ever
md
[Re: mopars4ever]
#2688745
08/17/19 01:48 PM
08/17/19 01:48 PM
Posts: 25,823 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Most factory installations are "meat rippers", when the ends are bent and exposed they can draw blood. I prefer this way:
[Re: Paul Jacobs]
#2688850
08/17/19 06:45 PM
08/17/19 06:45 PM
Posts: 13,596 md
mopars4ever
md
[Re: Paul Jacobs]
#2688880
08/17/19 08:16 PM
08/17/19 08:16 PM
Posts: 21,514 N.E. OHIO, USA
A12
N.E. OHIO, USA
I heard a long time ago that the cotter pins were bent with a HAMMER....yep put them in and smack them with a hammer......next Can you think of any quicker way and less effort than that? '69 had 84,000+ Road Runners alone if each car had only ONE COTTER PIN to bend why would you waste time with any other tool or method?
[Re: A12]
#2689839
08/20/19 08:08 PM
08/20/19 08:08 PM
Posts: 1,894 Harriman NY
71GTX471
Harriman NY
To many variables for one correct answer, it depends on where the hole in the component ended up the position of the pin installer & whom he was the tool in his hand ETC ETC, for the most part they did what ever was quickest & whacked it over in the direction that was easiest at any given component/position & it wasn't supposed to look pretty, just do the same for your car.
[Re: 71GTX471]
#2689899
08/21/19 01:49 AM
08/21/19 01:49 AM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
the way john kunkel did it is very neat and tidy. id do it just like that.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: mopardude318]
#2689960
08/21/19 10:25 AM
08/21/19 10:25 AM
NANKET
northwest USA
the way john kunkel did it is very neat and tidy. id do it just like that. The original question is how to do it like the factory. So the answer is quickly. Workers perform tasks differently so which way is correct? Follow Paul Jacobs photo here. Meat ripper is appropriate and dangerous. They way John did it is ridiculously anal. And impossible. The top tang is hanging over the edge spindle nut, can’t do that on final assembly. But it does look tidy.
[Re: NANKET]
#2690062
08/21/19 04:08 PM
08/21/19 04:08 PM
John_Kunkel
Rio Linda, CA
So, "correct" becomes "anal". Noted.
BTW, it's not impossible, I routinely do it on front suspension components that are the subject of this thread.
