Page 1 of 4 1 2 3 4
bending cotter pins on tie rod ends and ball joints #2688151
08/15/19 05:45 PM
08/15/19 05:45 PM
md
mopars4ever Offline OP
md
Which way do you bend the cotter pins on a tie rod end and ball joints? I am wanting going to duplicate the way it came from the factory in the mid 70`s. thanks
Re: bending cotter pins on tie rod ends and ball joints [Re: mopars4ever] #2688154
08/15/19 05:52 PM
08/15/19 05:52 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Take photos before it all comes apart & then replicate what you found at each location.
No two will ever be exactly the same in every single detail.
Re: bending cotter pins on tie rod ends and ball joints [Re: mopars4ever] #2688155
08/15/19 05:57 PM
08/15/19 05:57 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
The best picture of lower ball joint on a 1970 Challenger R/T. As Barry said not all the same. Although I don't think I would copy that one.
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: bending cotter pins on tie rod ends and ball joints [Re: VCODE] #2688159
08/15/19 06:10 PM
08/15/19 06:10 PM
md
md
The ones on the car had been replaced at one time or another so pics wouldn`t have helped me on this car. Also the factory service manual says not to line up the slot on the tie rod adjusting sleeve with the clamp opening. Does it really matter?
Re: bending cotter pins on tie rod ends and ball joints [Re: mopars4ever] #2688166
08/15/19 06:34 PM
08/15/19 06:34 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
I’m not home right now but have lots of original pictures I’ll try to post tomorrow. I can tell you they vary some.
Re: bending cotter pins on tie rod ends and ball joints [Re: Paul Jacobs] #2688176
08/15/19 07:04 PM
08/15/19 07:04 PM
md
md
Ok, thanks
Re: bending cotter pins on tie rod ends and ball joints [Re: mopars4ever] #2688217
08/15/19 08:43 PM
08/15/19 08:43 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Yes it really matters.
Re: bending cotter pins on tie rod ends and ball joints [Re: NANKET] #2688255
08/15/19 10:41 PM
08/15/19 10:41 PM
md
md
Does it reduce the clamping force?
Re: bending cotter pins on tie rod ends and ball joints [Re: mopars4ever] #2688624
08/17/19 01:07 AM
08/17/19 01:07 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
You definitely need that "special" tool that I'm sure the workers used to get that "factory correct bend" in those pins.
Re: bending cotter pins on tie rod ends and ball joints [Re: PhillyRag] #2688681
08/17/19 10:14 AM
08/17/19 10:14 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Personally,worrying about how a cotter pin is bent is going a little far but that's just me !! twocents
Re: bending cotter pins on tie rod ends and ball joints [Re: 62maxwgn] #2688744
08/17/19 01:39 PM
08/17/19 01:39 PM
md
md
Re: bending cotter pins on tie rod ends and ball joints [Re: mopars4ever] #2688745
08/17/19 01:48 PM
08/17/19 01:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Most factory installations are "meat rippers", when the ends are bent and exposed they can draw blood. I prefer this way:
Re: bending cotter pins on tie rod ends and ball joints [Re: John_Kunkel] #2688832
08/17/19 06:20 PM
08/17/19 06:20 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Very tidy, I like it.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: bending cotter pins on tie rod ends and ball joints [Re: BloFish] #2688847
08/17/19 06:42 PM
08/17/19 06:42 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
Here is what you will find in 90% of original cars. I looked through dozens of front end pictures today and this is all I found and it makes perfect sense because it would be the quickest way to do the job.
Re: bending cotter pins on tie rod ends and ball joints [Re: Paul Jacobs] #2688850
08/17/19 06:45 PM
08/17/19 06:45 PM
md
md
Thanks for the research.
Re: bending cotter pins on tie rod ends and ball joints [Re: Paul Jacobs] #2688880
08/17/19 08:16 PM
08/17/19 08:16 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I heard a long time ago that the cotter pins were bent with a HAMMER....yep put them in and smack them with a hammer......next hammer Can you think of any quicker way and less effort than that? '69 had 84,000+ Road Runners alone if each car had only ONE COTTER PIN to bend why would you waste time with any other tool or method?
Re: bending cotter pins on tie rod ends and ball joints [Re: A12] #2689839
08/20/19 08:08 PM
08/20/19 08:08 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
To many variables for one correct answer, it depends on where the hole in the component ended up the position of the pin installer & whom he was the tool in his hand ETC ETC, for the most part they did what ever was quickest & whacked it over in the direction that was easiest at any given component/position & it wasn't supposed to look pretty, just do the same for your car.
Re: bending cotter pins on tie rod ends and ball joints [Re: 71GTX471] #2689899
08/21/19 01:49 AM
08/21/19 01:49 AM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
the way john kunkel did it is very neat and tidy. id do it just like that.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: bending cotter pins on tie rod ends and ball joints [Re: mopardude318] #2689960
08/21/19 10:25 AM
08/21/19 10:25 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The original question is how to do it like the factory. So the answer is quickly. Workers perform tasks differently so which way is correct? Follow Paul Jacobs photo here. Meat ripper is appropriate and dangerous.
They way John did it is ridiculously anal. And impossible. The top tang is hanging over the edge spindle nut, can’t do that on final assembly. But it does look tidy.
Re: bending cotter pins on tie rod ends and ball joints [Re: NANKET] #2690062
08/21/19 04:08 PM
08/21/19 04:08 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
So, "correct" becomes "anal". Noted.
BTW, it's not impossible, I routinely do it on front suspension components that are the subject of this thread.
Page 1 of 4 1 2 3 4
