Page 3 of 3 1 2 3
Re: First EFI purchase [Re: Spyphish] #2686116
08/09/19 07:53 PM
08/09/19 07:53 PM
AndyF Offline
AndyF  Offline
Sounds like a good plan. If you have any questions just post them on here and I'll see if I can help.
Re: First EFI purchase [Re: AndyF] #2686811
08/12/19 10:55 AM
08/12/19 10:55 AM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
STRIKE ONE HOLLEY!!!! Trying to get someone on the phone before I hit the checkout button. Ain't gonna' happen on a Monday morning. So may get help here. Anyone running the returnless Sniper system in a hot climate? Thanks
CALMED THE QUAKE!!!(AGAIN!)
Re: First EFI purchase [Re: Spyphish] #2687389
08/13/19 06:44 PM
08/13/19 06:44 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I'm a Holley Dealer. I can take care of you.
efiexpert.com
209-247-6497
Re: First EFI purchase [Re: Mopar_Rich] #2687474
08/13/19 10:42 PM
08/13/19 10:42 PM
E. Okla line
m88mark Offline
m88mark  Offline
E. Okla line
Hope I can get in on this? What do you use for a tank, sending unit, etc for the sniper system. Thanks Mark
Re: First EFI purchase [Re: Spyphish] #2687482
08/13/19 11:12 PM
08/13/19 11:12 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Originally Posted by Spyphish
Looks like we are going with Holley Sniper, ignition, distributor yata yata intake, the works. Get on it after Indy.
Reading Andy's posts about the Sniper for the last few years convinced me it was the way to go for a street machine. I literally just purchased a Holley Sniper system last night for my Coronet.
I got the whole works too - injection unit, new fuel tank with internal pump, distributor, ignition box and even the TFI coil they repackage.If it's all designed to work together, why make life hard and use other parts?
'71 Duster
'72 Challenger
'17 Ram 1500
Re: First EFI purchase [Re: RMCHRGR] #2687546
08/14/19 08:35 AM
08/14/19 08:35 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
What was the cost on that, if you don't mind sharing?
Master, again and still
Re: First EFI purchase [Re: DaveRS23] #2687582
08/14/19 09:32 AM
08/14/19 09:32 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
From Summit;
SNE-19-139 FUEL TANK $569.95
SNE-550-516 SNIPER EFI KIT GOLD $999.95
SNE-556-151 IGNITION BOX $199.95
SNE-556-152 IGNITION COIL $37.95
SNE-565-305 DISTRIBUTOR $249.9
$2,057.75
I also got a roll of 3/8" tubing which was $19.I plan to use the existing mechanical pump line as the return. I'm sure there will be a bunch of fittings and clamps involved with the fuel lines which add up quick.
When I put the parts in my online cart a few months ago, the tank was listed for $593 but was happy to see it come back down to where it was originally at $569. Prices are essentially the same everywhere.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: First EFI purchase [Re: Andrewh] #2687596
08/14/19 10:03 AM
08/14/19 10:03 AM
Halifax, VA.
moparjack44 Offline
moparjack44  Offline
Halifax, VA.
Originally Posted by Andrewh
I don't have any experience with the newer systems.
But I went to try and change a stock car over to efi, just to make it more reliable.
I have no intentions of hotrodding it, so I think we are in a similar boat.
I did go on the cheap, and overall still spent about the same amount as one of the kits out now.
Here are a few things I learned that might help you decide.
If you are not trying to get every single HP out of your build, spark control is a waste of time and money.
Just one extra thing to tinker with, that a regular vacuum advance distributor(still electronic) would do just fine.
A surge tank is another way to go instead of an efi gas tank, or having a custom tank built or cutting up your existing one.
However, it creates complexity. In my case, there is no mechanical carb pump to feed it, and it requires I have 2 electric pumps instead of just 1.
While there are other choices like the holley hydromat(which recommends replacment every 10 years,) the aeromotive efi pump kit with the foam, or having a sump or baffels welded into your existing tank, I think I would go for the custom tank built for efi instead.
There are several systems out there.
Each with its own unique set of issues. however for a straight stock application, I don't really think you can go wrong with any of them.
you really have to look at support for your decision.
How likely is that company going to be around in 10 years when some part fails.
I always assume the worst. So I look to see how common the replacable parts are going to be.
What o2 sensor do they need you to have. Is it proprietary, or is it a common off the shelf one.
what fuel pump is it?
did they do some odd connector or is it the standard for that part?
The only thing you have to worry about after that is the ecu.
Now if you read the board regularly, you will see people here are a bit fickle.
Each time a new efi product comes out, it is the best. Till it isn't.
Today it is holley, 6 months ago it was Fi tech. 6 months before that it was FAST Efi.
It kind of goes in cycles.
As more people use them, more problems come up.
But if you pay attention, it is for the people doing more than stock stuff generally, not just the plain swap from a carb.
I have seen the same for what I did. As you add more things the efi computer needs to do, it just adds complexity for more things to not work together, or fail.
My recommendation is to make it as simple as possible. Keep with 1 system of stuff, with good support in case you need it.
Sometimes simple means spending a bit to make it simple.
So you buy the efi tank or mod yours.
you get the returnless system if they make it. or create a short return run like corvettes do.
Good luck.
Great read, simple, just like me.
K.I.S.S.
Re: First EFI purchase [Re: DaveRS23] #2687598
08/14/19 10:08 AM
08/14/19 10:08 AM
Halifax, VA.
moparjack44 Offline
moparjack44  Offline
Halifax, VA.
I have "0" problem with cold starts with my Edelbrock's. My issue is hot starts, after sitting for about 20 minutes.
K.I.S.S.
Re: First EFI purchase [Re: Spyphish] #2687601
08/14/19 10:14 AM
08/14/19 10:14 AM
Halifax, VA.
moparjack44 Offline
moparjack44  Offline
Halifax, VA.
The engine has a new MSD plug and play complete ignition system. Looking at videos, can I make distributor a lockout and use the adjustable rotor for the EFI? Or just get the Holley distributor. I can move the MSD system over to Lemon race car. Also, there is a small vent return line to tank from a canister on radiator support. I doubt it would be large enough for the return line some systems require. The MSD Atomic says it is single fuel line, any users of that system here. Thanks again
This years altitude change had a lot of us sea level guys working on carbs in the evening AFTER the 2 hour viewing for the crowds. Just looking for something to return our PBR time. LOL
PS Wrong thread but the Ugly Stick Hemi Coronet with the Pro System carb required nothing and ran perfect!!! For sale on Hemmings. Jake
PBR up Yadaman. beer
K.I.S.S.
Re: First EFI purchase [Re: RMCHRGR] #2687817
08/14/19 07:58 PM
08/14/19 07:58 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
From Summit;
$2,057.75
That stuff is coming down in price quickly and having the fuel tank with the in-tank pump is a great addition that wasn't available that long ago. Eventually they may be get the features and price to a point that even us carb guys can't say no.
stirthepot But that's not today. laugh2
Re: First EFI purchase [Re: DaveRS23] #2687857
08/14/19 10:20 PM
08/14/19 10:20 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
EFI seems expensive if you buy it all at once and it is.
But, I bet that if I gathered up all the various carburetors and related parts I've acquired over the years, 2 grand wouldn't come close to covering what I paid out for it.
And thankfully I enjoy the tuning aspect of driving cars with carburetors because if not I'd be pretty upset about how much time I've spent bent over a fender adjusting stuff...
'71 Duster
'72 Challenger
'17 Ram 1500
Re: First EFI purchase [Re: RMCHRGR] #2687894
08/15/19 01:19 AM
08/15/19 01:19 AM
AndyF Offline
AndyF  Offline
It just depends what you're trying to do. On a serious race car it is now cheaper to go EFI than a carb if a person is starting from scratch. For modest bracket car a simple carb and distributor can get the job done fairly cheaply. Personally I don't have a reason to run a carb on a street car anymore but I suppose everyone has to work thru that for themselves.
Re: First EFI purchase [Re: AndyF] #2688000
08/15/19 12:01 PM
08/15/19 12:01 PM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
Andy, I sent you a pm
Page 3 of 3 1 2 3
