Rubber stamps #2685767
08/08/19 06:06 PM
08/08/19 06:06 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Can't find my # stamps (the type you see on Mopar rearend housings).
Who sells them?
I seem to recall the OEM #s were about 1.25" tall, but I don't recall the font name.
The ones I'm seeing on the web say 1" x 1", but $7.95 each and I need at least 4...
(That's rubberstamps.net off the e-bodies.org site)
Thanks in advance!
Re: Rubber stamps [Re: topside] #2685850
08/08/19 10:28 PM
08/08/19 10:28 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
sylvainmopar.com
Re: Rubber stamps [Re: mopargem] #2685855
08/08/19 10:41 PM
08/08/19 10:41 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Saw a link to that website elsewhere, and just tried it again, nothing listed except a license bracket.
Can't contact through the site.
Guess I'll try locally @ Staples and see if anyone there can figure it out from a sample photo.
Re: Rubber stamps [Re: topside] #2685880
08/09/19 12:37 AM
08/09/19 12:37 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
http://board.moparts.org/ubbthreads...=7872418&an=0&page=0#Post7872418
http://board.moparts.org/ubbthreads...8&an=0&page=0&gonew=1#UNREAD
https://www.google.com/search?q=8-3/4+rear+end+paint+marks&rlz=1C1VFKB_enUS656__656&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwju1-i1q6rOAhVJlx4KHf2SAc4QsAQIHQ&biw=1280&bih=923#tbm=isch&q=8-3%2F4+a-body+rear+end+paint+daubs
https://www.e-bodies.org/resources/mopar-stamps-stencils-paint-ink-part-numbers/
Re: Rubber stamps [Re: kentj340] #2685903
08/09/19 07:02 AM
08/09/19 07:02 AM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
I bought a stencil kit at a craft store, Michael’s I think here...did my own came out pretty good I think for a budget build...
Re: Rubber stamps [Re: shakerjoe] #2685938
08/09/19 09:44 AM
08/09/19 09:44 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I had a local stamp place make a stamp for my heater box. It's an old typewriter style font, which was a real pain to match up.
Re: Rubber stamps [Re: Neil] #2686084
08/09/19 04:51 PM
08/09/19 04:51 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Well, no luck with anyone local, they just do office stuff.
The e-bodies.org site re-directs to a stamp site.
Trying to order them through the stamp site is a nightmare - and they don't show the font that e-bodies.org shows.
Left a message for them to see if someone there knows about them.
This is shaping up to be a test of my OCD...
Re: Rubber stamps [Re: topside] #2686090
08/09/19 05:28 PM
08/09/19 05:28 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Ive had a bunch made at Rubberstamp.com
with excellant results
Re: Rubber stamps [Re: gtx6970] #2686102
08/09/19 05:54 PM
08/09/19 05:54 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Heard back, and it's a deal where you send them the artwork; they don't keep a library of them.
I foolishly thought I could just call or email in an order for what I wanted.
It'll have to wait for when I have a couple hours to deal with it, I guess.
Re: Rubber stamps [Re: topside] #2686423
08/11/19 09:46 AM
08/11/19 09:46 AM
Akron, ohio
76orangewagon Offline
Akron, ohio
What Numbers are you looking for ? I have several left over stamps from my rear Axle for my 71 Cuda I would be willing to send you if their the correct ones you need, their also the correct font.
Re: Rubber stamps [Re: 76orangewagon] #2686430
08/11/19 10:01 AM
08/11/19 10:01 AM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
That would be really cool, and I'd clean & return them and reimburse your shipping.
I need a 2, a 4 and a 1.
I assume (though I could be wrong) that individual # stamps were used rather than have a stock of 3-digit codes & dates.
Re: Rubber stamps [Re: topside] #2686619
08/11/19 08:47 PM
08/11/19 08:47 PM
Akron, ohio
Akron, ohio
Well I’m not much help then my axle code is 019
Re: Rubber stamps [Re: 76orangewagon] #2686653
08/11/19 10:01 PM
08/11/19 10:01 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Nevertheless, I appreciate the offer, thank you.
Re: Rubber stamps [Re: topside] #2686683
08/11/19 11:29 PM
08/11/19 11:29 PM
Iowa
TX9AAR Offline
TX9AAR  Offline
Iowa
