2001 46RE, No 2-3 Shift #2685511
08/07/19 09:31 PM
08/07/19 09:31 PM
N.W. Florida
Fat_Mike Offline OP
Fat_Mike  Offline OP
N.W. Florida
2001 Ram 1500 4X4. Issue just started today, without warning. I drove it to a buddies house and it ran fine. When I left 2 hours later, the transmission wouldn't shift from 2nd to 3rd.
Transmission was rebuilt 50,000 miles ago, and is ready for routine service, but I wouldn't think that's the problem.
My internet research leads me to believe the governor pressure solenoid and governor pressure sensor needs to be replaced. The service manual's diagnosis chart doesn't cover this specific issue.
Ideas?
Re: 2001 46RE, No 2-3 Shift [Re: Fat_Mike] #2685522
08/07/19 09:57 PM
08/07/19 09:57 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
My first thought is the front clutch piston seals....
Re: 2001 46RE, No 2-3 Shift [Re: Fat_Mike] #2685553
08/07/19 11:12 PM
08/07/19 11:12 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
I've read that solonoid pack can be troublesome, but I've never had any issues.
No mention of check engine lights, Mike, but disconnect your battery overnight and re-hook it up and see if the problem continues. The computer in these trucks is not overly useful for giving codes, so, start with the easy stuff................
Mo' Farts
Moderated by "tbagger".
Re: 2001 46RE, No 2-3 Shift [Re: Grizzly] #2685562
08/07/19 11:19 PM
08/07/19 11:19 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The governor pressure switch gave a code on my 97 46RE, but we had to scan it to see the code.
The problem I had was when I dropped the pan there were lots of chunks of clutch/band lining laying on the bottom of the pan. Gene
Re: 2001 46RE, No 2-3 Shift [Re: poorboy] #2685564
08/07/19 11:34 PM
08/07/19 11:34 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Job security:
#1 Ford diesel mechanic
#2 Ford Technician
#3 Blunder Motors intake/head gasket specialist, rear differential overhaul specialist, 700r4,......nevermind: too many issues to mention here
and,
#4 Dodge overdrive transmission specialist based on every 904 and 727 POS variant ever derived. down
I'm sure toyota, Hyundai, Kia, and Mitsubishi body/mechanical Tech fits in there somewhere, but you get my gyst.
Mo' Farts
Re: 2001 46RE, No 2-3 Shift [Re: Grizzly] #2685579
08/08/19 03:20 AM
08/08/19 03:20 AM
A727Tflite Online content
A727Tflite  Online Content
No mention of having reverse - if you do and it is strong then likely you either have a stuck throttle pressure linkage or a bad pressure transducer. (A stuck TP plug could do it but not very common).
A technician would first check the throttle pressure cable at the transmission and make sure the return spring is there and functioning.
If it isn’t and the throttle cable was stuck you could have high pressure and a late shift. Check that first since we had issues with both the cable and that spring.
Put a 100 pound gauge on the governor port and take it for a ride.
If it’s not close to vehicle speed then I would replace both the solenoid and transducer.
The tap is at the junction of the main case to the overdrive unit - on the passenger side of the main case at three o’clock.
Re: 2001 46RE, No 2-3 Shift [Re: Grizzly] #2685588
08/08/19 08:01 AM
08/08/19 08:01 AM
Guitar Jones Offline
Originally Posted by Grizzly
Job security:
#2 Ford Technician
and,
Hyundai/Kia engine tech. You will not run out of work for the foreseeable future and probably not in my lifetime. laugh2
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 2001 46RE, No 2-3 Shift [Re: Guitar Jones] #2685608
08/08/19 09:00 AM
08/08/19 09:00 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
My Diesel Dodge is doing that. It will shift cold once or twice at light throttle but after that it hangs in second. It will shift from second if I very quickly shift Neutral to Drive and then it does its thing correctly.
My transmission guy says it probably needs a pressure transducer but to change the solenoid too as they are both problematic.
Kevin
Re: 2001 46RE, No 2-3 Shift [Re: Grizzly] #2685616
08/08/19 09:38 AM
08/08/19 09:38 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Most common deal with the gov psi transducer was coming up to a stop and the trans wouldn’t shift down to first.... pull it down manually and you’d have first.
Wouldn’t a stuck kickdown also effect the 1-2 shift? I’ve seen rocks lodged in by the lever.... some peoples luck smile
Re: 2001 46RE, No 2-3 Shift [Re: Grizzly] #2685629
08/08/19 10:30 AM
08/08/19 10:30 AM
N.W. Florida
Fat_Mike Offline OP
Fat_Mike  Offline OP
N.W. Florida
No codes (in self diagnostic test)
I'll disconnect the battery for a few hours
I DO have reverse, and I'll have to check first gear. It definitely downshifts manually to 1st, but I guess there's a chance I was starting out in second when selector was in D. I was PO'd and flustered limping home...
I don't have tools to pressure test, and definitely don't have the experience to dig very deep. The only transmission experience I have is dropping the pan and replacing the filter. I don't mind taking to a shop, just would rather fix it myself if the fix was within my comfort zone. I'll report back soon...
Re: 2001 46RE, No 2-3 Shift [Re: Fat_Mike] #2685762
08/08/19 05:46 PM
08/08/19 05:46 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
As said check the kickdown linkage. But I usually find if the 1-2 shift is still normal it usually is not the throttle pressure kickdown linkage. We did have problems on some years as I cant remember which years where we would replace the front drum and piston and seals with updated parts for a late or no 2-3 shift. And I found reverse usually would still work normal since it uses much higher pressure. And I also some some with no codes where the gov pressure sensor and solenoid fixed it as we did have a lot of problems with them. Couse we would watch the gov pressure on the scanner to see what it was doing. Good luck with it, Ron
Re: 2001 46RE, No 2-3 Shift [Re: 383man] #2685775
08/08/19 06:24 PM
08/08/19 06:24 PM
N.W. Florida
Fat_Mike Offline OP
Fat_Mike  Offline OP
N.W. Florida
As it turns out, the truck starts out in 2nd and only shifts to 1st manually. I know it's tough to diagnose when you get bad information. I apologize for that. Once I figured that out, I disconnected the battery for almost 2 hours; no change. TV cable seemed good and nothing jammed up in the linkage (a quick once-over). Rather than take guesses, throw parts at it, and waste more time on it, I took it to a trusted transmission shop. He called me very soon after I dropped it off and told me the transmission wasn't getting anything from the computer. So now it's at a different shop waiting to see whether it's a broken wire, or a bad ECU, or...? Thanks to all for your input. Once I get the final verdict, I'll chime in.
Re: 2001 46RE, No 2-3 Shift [Re: Fat_Mike] #2685875
08/09/19 12:02 AM
08/09/19 12:02 AM
Salem
Grizzly Offline
Grizzly  Offline
Salem
"told me the transmission wasn't getting anything from the computer. So now it's at a different shop waiting to see whether it's a broken wire, or a bad ECU, or...?"
confused That's a new one.
Only thing tied to the computer that I know of in mine would be the Vehicle speed sensor, rear wheel abs, brake switch, and throttle position sensor.
I'm going to put my money on vehicle speed sensor at this point.
Mo' Farts
Re: 2001 46RE, No 2-3 Shift [Re: Fat_Mike] #2686029
08/09/19 01:12 PM
08/09/19 01:12 PM
The Naughty Spot
BirdinPieces Offline
The Naughty Spot
I had this exact problem on a 2000 Durango. The module on the passenger side inner fender had to be replaced. I bought a rebuilt unit online from a place (don't remember the name) in Florida for about $200. Took 5 minutes to install.
The Bird Some are wise, and some are otherwise... Say what you want, but in the end, it is what it is...
Re: 2001 46RE, No 2-3 Shift [Re: Grizzly] #2686270
08/10/19 01:19 PM
08/10/19 01:19 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
"told me the transmission wasn't getting anything from the computer.....
Interesting.... so he wasn’t able to view trans data? Viewing gov psi via the scan tool of your choice would be beneficial
Re: 2001 46RE, No 2-3 Shift [Re: J_BODY] #2686299
08/10/19 04:29 PM
08/10/19 04:29 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
It is stuck n limp mode, got to finger out why. I would check simple things first like fuses and the relay, I have had customers sent to me with "bad trans needs rebuilt" diag by udder shops and it is simple stuff like that. Check every fuse related or not and swap the trans relay with one for the horn or starter or something and see if it starts working (or the starter quits working). There is probably a p0700 in the engine computer that just says something like trans problem but unless you go in the scanner under "transmission" you will not finger out what the code in the trans conputer actually says. The cheap autozone scanner will come up with the p0700 no matter what code is in the transmission section of the confuser.
