Re: 2001 46RE, No 2-3 Shift
[Re: Fat_Mike]
#2685553
08/07/19 11:12 PM
08/07/19 11:12 PM
Posts: 5,999 Salem
Grizzly
Moparts Proctologist
Salem
I've read that solonoid pack can be troublesome, but I've never had any issues.
No mention of check engine lights, Mike, but disconnect your battery overnight and re-hook it up and see if the problem continues. The computer in these trucks is not overly useful for giving codes, so, start with the easy stuff................
Mo' Farts
Moderated by "tbagger".
[Re: poorboy]
#2685564
08/07/19 11:34 PM
08/07/19 11:34 PM
Posts: 5,999 Salem
Grizzly
Salem
Job security: #1 Ford diesel mechanic #2 Ford Technician #3 Blunder Motors intake/head gasket specialist, rear differential overhaul specialist, 700r4,......nevermind: too many issues to mention here and, #4 Dodge overdrive transmission specialist based on every 904 and 727 POS variant ever derived. I'm sure toyota, Hyundai, Kia, and Mitsubishi body/mechanical Tech fits in there somewhere, but you get my gyst.
Mo' Farts
[Re: Grizzly]
#2685579
08/08/19 03:20 AM
08/08/19 03:20 AM
Posts: 3,069 Michigan
A727Tflite
No mention of having reverse - if you do and it is strong then likely you either have a stuck throttle pressure linkage or a bad pressure transducer. (A stuck TP plug could do it but not very common).
A technician would first check the throttle pressure cable at the transmission and make sure the return spring is there and functioning. If it isn’t and the throttle cable was stuck you could have high pressure and a late shift. Check that first since we had issues with both the cable and that spring.
Put a 100 pound gauge on the governor port and take it for a ride. If it’s not close to vehicle speed then I would replace both the solenoid and transducer.
The tap is at the junction of the main case to the overdrive unit - on the passenger side of the main case at three o’clock.
[Re: Grizzly]
#2685588
08/08/19 08:01 AM
08/08/19 08:01 AM
Posts: 20,627 in a cattle trailer down by th...
Guitar Jones
Job security: #1 Ford diesel mechanic #2 Ford Technician #3 Blunder Motors intake/head gasket specialist, rear differential overhaul specialist, 700r4,......nevermind: too many issues to mention here and, #4 Dodge overdrive transmission specialist based on every 904 and 727 POS variant ever derived. I'm sure toyota, Hyundai, Kia, and Mitsubishi body/mechanical Tech fits in there somewhere, but you get my gyst. Hyundai/Kia engine tech. You will not run out of work for the foreseeable future and probably not in my lifetime.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Fat_Mike]
#2685762
08/08/19 05:46 PM
08/08/19 05:46 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
As said check the kickdown linkage. But I usually find if the 1-2 shift is still normal it usually is not the throttle pressure kickdown linkage. We did have problems on some years as I cant remember which years where we would replace the front drum and piston and seals with updated parts for a late or no 2-3 shift. And I found reverse usually would still work normal since it uses much higher pressure. And I also some some with no codes where the gov pressure sensor and solenoid fixed it as we did have a lot of problems with them. Couse we would watch the gov pressure on the scanner to see what it was doing. Good luck with it, Ron
[Re: 383man]
#2685775
08/08/19 06:24 PM
08/08/19 06:24 PM
Posts: 3,042 N.W. Florida
Fat_Mike
N.W. Florida
As it turns out, the truck starts out in 2nd and only shifts to 1st manually. I know it's tough to diagnose when you get bad information. I apologize for that. Once I figured that out, I disconnected the battery for almost 2 hours; no change. TV cable seemed good and nothing jammed up in the linkage (a quick once-over). Rather than take guesses, throw parts at it, and waste more time on it, I took it to a trusted transmission shop. He called me very soon after I dropped it off and told me the transmission wasn't getting anything from the computer. So now it's at a different shop waiting to see whether it's a broken wire, or a bad ECU, or...? Thanks to all for your input. Once I get the final verdict, I'll chime in.
[Re: Fat_Mike]
#2685875
08/09/19 12:02 AM
08/09/19 12:02 AM
Posts: 5,999 Salem
Grizzly
Salem
"told me the transmission wasn't getting anything from the computer. So now it's at a different shop waiting to see whether it's a broken wire, or a bad ECU, or...?" That's a new one. Only thing tied to the computer that I know of in mine would be the Vehicle speed sensor, rear wheel abs, brake switch, and throttle position sensor. I'm going to put my money on vehicle speed sensor at this point.
Mo' Farts
[Re: Fat_Mike]
#2686029
08/09/19 01:12 PM
08/09/19 01:12 PM
Posts: 3,437 The Naughty Spot
BirdinPieces
The Naughty Spot
I had this exact problem on a 2000 Durango. The module on the passenger side inner fender had to be replaced. I bought a rebuilt unit online from a place (don't remember the name) in Florida for about $200. Took 5 minutes to install.
The Bird
Some are wise, and some are otherwise...
Say what you want, but in the end, it is what it is...
[Re: Grizzly]
#2686270
08/10/19 01:19 PM
08/10/19 01:19 PM
Posts: 13,185 aZLiViN
J_BODY
aZLiViN
"told me the transmission wasn't getting anything from the computer..... Interesting.... so he wasn’t able to view trans data? Viewing gov psi via the scan tool of your choice would be beneficial
