66 coronet drag radial suggestion #2682844
07/30/19 08:24 PM
07/30/19 08:24 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
Looking to step up to drag radials on my car and wondering what everyone else is running. It is pretty tight back there with the stock wheel wells and stock position leaf spring. Right now I am running 15x7 diplomat steel wheels with 235/75-15 tires. Would prefer dot approved tire.
Re: 66 coronet drag radial suggestion [Re: crowbait] #2682909
07/30/19 10:22 PM
07/30/19 10:22 PM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
I'm running 275-60 MT ET Street S/S on my 67. With a 15x7 steel wheel. Mine has 4.25 backspace. No idea if your Diplomat wheels work.
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: 66 coronet drag radial suggestion [Re: crowbait] #2683033
07/31/19 10:45 AM
07/31/19 10:45 AM
moparx Offline
moparx  Offline
what were those tires you used at mercer that time ?
beer
Re: 66 coronet drag radial suggestion [Re: moparx] #2683086
07/31/19 12:44 PM
07/31/19 12:44 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
McReary dirt track tires.
Re: 66 coronet drag radial suggestion [Re: Sledge_57] #2683135
07/31/19 03:20 PM
07/31/19 03:20 PM
an8sec70cuda Offline
iagree Those should work great.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 66 coronet drag radial suggestion [Re: crowbait] #2683241
07/31/19 09:29 PM
07/31/19 09:29 PM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
I'm running a 255/60 M/T ET Street on my 67 Belvedere. 8" wheel, 4.5 backspacing.
Re: 66 coronet drag radial suggestion [Re: crowbait] #2683375
08/01/19 10:14 AM
08/01/19 10:14 AM
moparx Offline
moparx  Offline
whatever you decide, i'll mount and balance for you.
did you recoup from yesterday yet ? biggrin
i feel better than i expected.
beer
Re: 66 coronet drag radial suggestion [Re: moparx] #2684176
08/03/19 09:53 PM
08/03/19 09:53 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
Yes I am recovered.
https://www.jegs.com/i/Nitto/726/180300/10002/-1
How about Nitto? Sure seems cheap.at $160.00 ea.
Re: 66 coronet drag radial suggestion [Re: crowbait] #2684272
08/04/19 10:54 AM
08/04/19 10:54 AM
central il.
second 70 Offline
second 70  Offline
central il.
Too bad you don't life closer, I have a set of those nitto's on 8" wheels sitting under my workbench you could try. Nice tire they ride great but no traction on my 600hp 4-speed Hemi. 100% better ride than the bias ply that are on there now. If I'm going to drive any distance this set of radials go on the car so I can enjoy the ride. Radials and 4-speed don't play well together at the track.
Re: 66 coronet drag radial suggestion [Re: second 70] #2684410
08/04/19 06:59 PM
08/04/19 06:59 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
what don't you like about the bias ply? they follow grooves or just feel like a bad ride?
what tires do you run on the front?
Have a pic?
Thanks!!
I'm watching this therad close because I'm going to put some different tires on my 67 coronet, not sure what though. Thinking some some Pro-Trac bias ply on the front (215/75-15), or maybe some Coker 6.70-15 BFG bias ply and some MH Musclecar biasply on the rear, 275/60-15
Re: 66 coronet drag radial suggestion [Re: krautrock] #2684608
08/05/19 10:31 AM
08/05/19 10:31 AM
central il.
second 70 Offline
second 70  Offline
central il.
The biggest problem is the front Mt sportsman 28" x 7.50" x 15" and just are not a good riding tire. I change them out to the R 225/70/15 TA and it's a totally different car. The rear are Et street R 28" x 11.5" x 15" and don't seem to be a problem as long as the road is dry.
60970190_10211901005075638_2748192282418085888_o.jpg60707118_10211901000115514_4500524336297279488_o.jpg
Re: 66 coronet drag radial suggestion [Re: Sledge_57] #2684965
08/06/19 01:22 PM
08/06/19 01:22 PM
My hovercraft is full of eels
DaveKanofsky Offline
That is a beautiful car!
Sorry to the OP, I don't have any extra insight. My dad has a '66 coronet and yes they are small wheelhouses. Please share what you come up with!
MOPARS ONLY!
'69 Daytona, '16 Plum Crazy Challenger, '12 Durango, '01 Sebring conv't
Chaplain, Racers For Christ (http://teamrfc.org/)
John 3:17
Re: 66 coronet drag radial suggestion [Re: DaveKanofsky] #2685164
08/06/19 10:35 PM
08/06/19 10:35 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
275/60/15 ET Street Pro will give you the best traction but won't last if you drive it a lot. I've been 1.54 60 ft. and drive them everywhere without issue. They are AMAZING on the street for traction!
Nittos wear much better but just won't hook nearly as well.
Here is a pic of an unprepped public street (allegedly) leaving in 2nd gear. Hooked and booked.
'63 Dodge 330
11.19 @ 121 mph
Re: 66 coronet drag radial suggestion [Re: GY3] #2685573
08/08/19 12:41 AM
08/08/19 12:41 AM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
Thanks for the offer second 70. I am just gonna drop back a little on the size on this first set to the 255 60 15 ET Streets. I just want to mount up and go with no issues. After these are on I can measure a little and see what up.
Re: 66 coronet drag radial suggestion [Re: GY3] #2685698
08/08/19 01:22 PM
08/08/19 01:22 PM
Berwyn, IL
challenger70 Offline
Berwyn, IL
This, nittos last longer but don't grip nearly as well. The BFG drag radials were a happy medium for me, but I don't think they make them anymore.
