Determine build date '69 Plymouth B Body #2685181
08/07/19 12:02 AM
08/07/19 12:02 AM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
How do I determine the build date for my '69 roadrunner? It's a Lynch Rd car if that manners.
Re: Determine build date '69 Plymouth B Body [Re: VITC_GTX] #2685215
08/07/19 06:22 AM
08/07/19 06:22 AM
Ball Ground GA
TrueTripleX Offline
TrueTripleX  Offline
Ball Ground GA
I would post your VIN number and ask for other Lynch Road car owners with VIN numbers close to yours to provide there VIN's with the SPD. With this information you should be able to extrapolate an APPROXIMATE build date of your car.[/u][u]
Re: Determine build date '69 Plymouth B Body [Re: VITC_GTX] #2685278
08/07/19 10:29 AM
08/07/19 10:29 AM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
You can look for the K-frame date stamped on the front of it too? There's a belief that the K-frame date is within a few days (to a week) or so of the build/final assembly date. As mentioned other VIN's will also help/
Re: Determine build date '69 Plymouth B Body [Re: A12] #2685331
08/07/19 01:03 PM
08/07/19 01:03 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Actual build dates were not recorded back then, so any answer will be a guess.
Re: Determine build date '69 Plymouth B Body [Re: Alaskan_TA] #2685355
08/07/19 01:50 PM
08/07/19 01:50 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Gotcha.
Thanks guys.
Re: Determine build date '69 Plymouth B Body [Re: Alaskan_TA] #2685397
08/07/19 04:22 PM
08/07/19 04:22 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Yeah A-bomb, hand grenade and horseshoe "close" guesses and none of them can be confirmed with little or no documentation wink But then there's the missing computer data tapes from the same computers that generated the broadcast sheets.......................................and that is from an inside source, I love a good mystery and it includes NASA too shock grin
Re: Determine build date '69 Plymouth B Body [Re: A12] #2685405
08/07/19 04:43 PM
08/07/19 04:43 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
grin
I haven't checked for broadcast sheet (just got the car). Good news so far is the car is fairly unmolested. The engine and 4-spd are matching numbers and the exhaust manifolds, intake and carb have the correct casting numbers. I do not believe the engine has ever been out of the car/rebuilt and it seems to have the original clutch/pressure plate in it. Maybe the broadcast sheet is there somewhere.
Also, I have the original bill of sale that shows the original owner bought it in July of '69 so I know it was built before that!!
Re: Determine build date '69 Plymouth B Body [Re: VITC_GTX] #2685409
08/07/19 04:51 PM
08/07/19 04:51 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
does it have a fender tag? the SCHEDULED PRODUCTION DATE is on the bottom row - this particular Road Runner was more than a week late
1 thru 9 = January thru September & A, B, C = October, November, December
Re: Determine build date '69 Plymouth B Body [Re: A12] #2685410
08/07/19 04:53 PM
08/07/19 04:53 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
& that still won't show the actual production date - Chrysler tracked "SCHEDULED" & "SHIPPED" dates
Re: Determine build date '69 Plymouth B Body [Re: 6bblgt] #2685421
08/07/19 05:30 PM
08/07/19 05:30 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
The fender tag shows 616. June 16th.
Thanks guys.
Re: Determine build date '69 Plymouth B Body [Re: VITC_GTX] #2685516
08/07/19 09:50 PM
08/07/19 09:50 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Thanks guys.
When you get a chance it would be interesting to me to see what the K-frame stamped date code reads up
Mike
Re: Determine build date '69 Plymouth B Body [Re: A12] #2685554
08/07/19 11:13 PM
08/07/19 11:13 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I'll try and get out in the shop tomorrow and look Mike. It's 105 here today and I didn't turn the air conditioner on in the shop down
Re: Determine build date '69 Plymouth B Body [Re: VITC_GTX] #2693795
09/02/19 10:19 PM
09/02/19 10:19 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Sorry for the delay.
Took a quick look and couldn't find a date stamped anywhere. I'll look when I have it on the lift next time.
