Help decoding engine pad #2684678
08/05/19 01:32 PM
08/05/19 01:32 PM
Charlotte, NC
Kowal Offline OP
Kowal  Offline OP
Charlotte, NC
So, see pics. Any help in decoding what I am looking at would be great.
A 440, has a VIN stamp on the passenger oil pan rail. Though the VIN stamp looks to be different than factory...the pad has the usual machining marks but the VIN font seems more subtle than normal. It is now in my GTX, but not sure that means anything, the VIN stamp is the VIN of the GTX. The engine was in the car prior to it being restored. Warranty replacement?
On the second pic I highlighted what might be hard to see in the picture
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: Help decoding engine pad [Re: Kowal] #2684696
08/05/19 02:55 PM
08/05/19 02:55 PM
AndyF Offline
AndyF  Offline
Some sort of non-factory stamp. Could be a dealer stamped a warranty block or a previous owner stamped it after machine work. What is the casting info on the side?
Re: Help decoding engine pad [Re: AndyF] #2684699
08/05/19 02:59 PM
08/05/19 02:59 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
It looks like a factory stamping to me but not a typical production stamp you'd see in a car, probably a replacement block of some kind. The WT means it was a water tested block (typically seen on Hemi blocks). the 440 is the CID and the other two numbers relate to the month and day it was assembled.
Re: Help decoding engine pad [Re: Kowal] #2684713
08/05/19 03:30 PM
08/05/19 03:30 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Compare the stamped 7 8 (July 8) to the casting date on the side of the block. I agree it's a replacement bare block never assembled.
Re: Help decoding engine pad [Re: John_Kunkel] #2684718
08/05/19 03:54 PM
08/05/19 03:54 PM
Charlotte, NC
Kowal Offline OP
Kowal  Offline OP
Charlotte, NC
The block is 2536430-7
Re: Help decoding engine pad [Re: Kowal] #2684723
08/05/19 04:02 PM
08/05/19 04:02 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
That's the casting number, the casting date is also cast on the side.
Re: Help decoding engine pad [Re: ScottSmith_Harms] #2684733
08/05/19 04:28 PM
08/05/19 04:28 PM
Charlotte, NC
Kowal Offline OP
Kowal  Offline OP
Charlotte, NC
Right, took me a minute to be sure of what I was seeing. The casting date is 8/4/69.
I thought the casting date was on the driver’s side, took me a while to get a good pic of this one behind the passenger exhaust manifold under plugs 6 and 8.
The car is a late November, 1968 build car.
