rpm activated switch #2684676
08/05/19 01:29 PM
08/05/19 01:29 PM
okla.
sam64 Offline OP
sam64  Offline OP
okla.
What would cause my rpm activated switch to activate twice on the 1 2 shift ? I tried a different rpm chip with no change.thanks,Sam.
Re: rpm activated switch [Re: sam64] #2684732
08/05/19 04:26 PM
08/05/19 04:26 PM
RMI,EMI, Radio magnetic interference, Electro magnetic interference shruggy(my definitions abrevations(SP?) may be wrong for that problem but bleeding signals into the device is the problem shruggy
Both are caused by ignition wires, pick up, coil feed and spark plug wires, leaking signals into the device work scope
Re: rpm activated switch [Re: Cab_Burge] #2684746
08/05/19 04:55 PM
08/05/19 04:55 PM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
Because you are dropping below the RPM chip when it changes gear - meaning your RPM is falling back and then coming back and triggering again - only thing I can think of other than electrical interference - do you have a time out on that switch so that it can't trigger for a period of time after triggering ??
Re: rpm activated switch [Re: Cab_Burge] #2684787
08/05/19 08:55 PM
08/05/19 08:55 PM
okla.
sam64 Offline OP
sam64  Offline OP
okla.
the relay is mounted with in 4 inches of rpm switch and shift solenoid,work fine last year and haven't changed anything.
Re: rpm activated switch [Re: DoubleD] #2684790
08/05/19 09:01 PM
08/05/19 09:01 PM
okla.
sam64 Offline OP
sam64  Offline OP
okla.
just hooked up as normally open and what ever rpm chip is in.Worked fine last year with 6300chip,swapped to 6500 no change.rpm switch and soleniod are mounted on shifter
