Spark plug cross reference? #2684385
08/04/19 05:58 PM
08/04/19 05:58 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Been searching for an hour for a cross reference for Accel 414S to Autolite. Does anyone know how the 414's would match up with an Autolite 3924? Colder or hotter? By the way, the 3/16" difference in length don't do much for header clearance!!!
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Spark plug cross reference? [Re: 68LAR] #2684413
08/04/19 07:06 PM
08/04/19 07:06 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
not sure if this will help you
Attached PDF document
sparkplug CrossRef.pdf (72 downloads)
Re: Spark plug cross reference? [Re: 68LAR] #2684435
08/04/19 08:03 PM
08/04/19 08:03 PM
Look at both plugs and compare the center porclyn insulators, the bigger one is hotter scope
Re: Spark plug cross reference? [Re: Cab_Burge] #2684442
08/04/19 08:22 PM
08/04/19 08:22 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
. Not sure I understand.
Re: Spark plug cross reference? [Re: 68LAR] #2684480
08/04/19 10:35 PM
08/04/19 10:35 PM
how far out they protrude from flush with the steel shell, A longer distance means the heat has to travel further to be dissipated back into the core so that extended tip runs hotter.
Re: Spark plug cross reference? [Re: 68LAR] #2684497
08/04/19 11:16 PM
08/04/19 11:16 PM
The hotter plugs(for the same application) have fatter thicker insulators around the center ground electrode scope
Re: Spark plug cross reference? [Re: Cab_Burge] #2684605
08/05/19 10:23 AM
08/05/19 10:23 AM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Thanks for the replies. I guess a better way to ask my question is, is the Accel 0414 hotter or colder than the Accel 0416? Checking the porcelain of both the 0414's and the 3924's, they look identical.
Re: Spark plug cross reference? [Re: 68LAR] #2684620
08/05/19 10:49 AM
08/05/19 10:49 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Re: Spark plug cross reference? [Re: 68LAR] #2684628
08/05/19 11:09 AM
08/05/19 11:09 AM
Bigger last number is hotter on Accels since day one is what I remember.
That new chart shows that also up
Take a look at a Autolite 3923 compared to both of the other ones you have now scope It is colder than the 3924 up
