Universal motor mount kits? #268439
03/27/09 01:51 PM
03/27/09 01:51 PM
Santa Cruz, California
Lefty Offline OP
Lefty  Offline OP
I'm installing Fatman coil over front suspension in a 47 Dodge 1/2 ton and the rack and pinion steering input shaft want's to be right in the middle of the current "universal" tubular motor mount cross member.
What's your "favorite" universal motor mount brand? The engine (small Chebby) is offset to the passenger side. Yeah, I know... I already told him we need to dump the engine and get a 5.7 Hemi in there.
Re: Universal motor mount kits? [Re: Lefty] #268440
03/27/09 02:53 PM
03/27/09 02:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Why not scrap the universal tubing crossmember and mount the motor on the square tube suspension/steering crossmember?
Re: Universal motor mount kits? [Re: John_Kunkel] #268441
03/27/09 03:20 PM
03/27/09 03:20 PM
Lefty Offline OP
Lefty  Offline OP
I'm a little worried the angle would be such that the mount would apply a lot of twisting torque because it's so far behind the new cross member. I'll be boxing the frame and adding support plates to the cross member because of the gaps to the frame rails.
Here's a somewhat better pic. The original mm cross member mount bolt holes are actually further back than the pic shows. The weight of the engine would be to the rear of the new cross member by about an inch. Too much twisting torque?
Re: Universal motor mount kits? [Re: Lefty] #268442
03/27/09 03:51 PM
03/27/09 03:51 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
when will these guys learn that a mopar belongs in a mopar, I don't care how cheap a chevy is, put it in a chevy rant over!!!!!
as far as mounts go I would use the ones from chassis engineering and if you have to, cut loose the rack mounts and aim it a little lower to go under the mount
and talk your friend into putting a mopar in it Ron....
http://www.chassisengineeringinc.com/page30.html
Re: Universal motor mount kits? [Re: Mopar Ron] #268443
03/27/09 04:27 PM
03/27/09 04:27 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
I'd cut a 1.5" section out of that tube and weld in a piece of heavy wall tubing (perpendicular to what's there and at an angle to match the column) and allow the steering shaft to pass through it.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: Universal motor mount kits? [Re: Lefty] #268444
03/28/09 09:04 AM
03/28/09 09:04 AM
E
earlymopar Offline
earlymopar  Offline
E
I agree with John Kunkel on this. The universal mount you have is redundant (not needed) given the close proximity to the one in front of it that supports your steering rack and the suspension pick-up points. You should be able to fabricate a motor mount off of your frame and / or the front cross member. The universal cross member you have is actually a transmission cross member.
- EM
Re: Universal motor mount kits? [Re: earlymopar] #268445
03/28/09 09:10 PM
03/28/09 09:10 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Or box in the frame rails and lose the tubular piece altogether. Affix the motor mounts to the inner frame rail. It looks to me that the surrent crossmember is a little far foward to use for the mounts.
1968 GTX hardtop
1933 Plymouth coupe
2015 Grand Cherokee
2013 Challenger
