Re: Aluminum water pump housing and billet alt. setup help..
[Re: mopower440]
#2684405
08/04/19 06:54 PM
08/04/19 06:54 PM
RapidRobert
get the 8 blader & cut some scrap & add an antcav plate behind the vanes (cut your scrap circle in half & weld each piece). Do you know the exact pulley dimentions you need, total depth (how high setting on the shelf) & dia range that will clear (ratio comes into play there also)
[Re: RapidRobert]
#2684424
08/04/19 07:33 PM
08/04/19 07:33 PM
Posts: 2,863 middle Tennessee
mopower440
middle Tennessee
get the 8 blader & cut some scrap & add an antcav plate behind the vanes (cut your scrap circle in half & weld each piece). Do you know the exact pulley dimentions you need, total depth (how high setting on the shelf) & dia range that will clear (ratio comes into play there also) Im not sure what will work..The car only has the water pump and alternator..no AC and no power steering.. Wondering if i need to change the crank pulley to a smaller diameter so i can use that bigger water pump pulley i have thats deeper..? Im not sure what all the pulley combos were available.. The smaller diameter pulley ive been using is 5 3/4 and its 1 1/4 deep. It worked with the old bracketry it was kinda rigged as that pulley and the 4 groove crank pulley werent a matched set so i rigged the old bracket a bit. Now that i have a nice bracket setup they dont line up. The Bigger pulley in the picture is 6 1/2" and 2 3/4 deep. It ALMOST lines up with the alternator and the rear groove on the crank pulley but not quite, plus its too big and hits the crank pulley a little, ALSO, i cant go bigger with the water pump pulley anyways because the thing likes to get a little warm in the 100 degree heat here when not moving or not moving fast enough.
[Re: mopower440]
#2684437
08/04/19 08:08 PM
08/04/19 08:08 PM
Posts: 6,240 nowhere
Sniper
nowhere
[Re: mopower440]
#2684487
08/04/19 10:58 PM
08/04/19 10:58 PM
RapidRobert
get an 8 blader & add the anticav plate or buy one with it installed. As you said you wouldn't want to go any slower on the ratio & likely should speed it up. OE A/C apps were 1.33% overdriven (crank to pump). A shroud would for sure help as would a fan blade with more blades & proper fore/aft fan spacing expecially with a shroud setup. Confirm the (alum) pump housing is unrestricted (been issues with some of em). You have enough radiator?
[Re: mopower440]
#2684584
08/05/19 09:43 AM
08/05/19 09:43 AM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
Looks to me that your existing pulleys are for an AC setup. Pics of my 67 Coronet 383 AC pulleys.
[Re: markz528]
#2684587
08/05/19 09:54 AM
08/05/19 09:54 AM
mopower440
middle Tennessee
They are indeed for AC. the engine assembly came out of a 1975 new Yorker with AC. my dart has no AC, no Power steering or anything, so im needing the correct pulley setup for no anything..lol..Hopefully the alternator bracketry didn't change between AC and non- AC cars..?
[Re: mopower440]
#2684632
08/05/19 11:14 AM
08/05/19 11:14 AM
mopower440
middle Tennessee
They are indeed for AC. the engine assembly came out of a 1975 new Yorker with AC. my dart has no AC, no Power steering or anything, so im needing the correct pulley setup for no anything..lol..Hopefully the alternator bracketry didn't change between AC and non- AC cars..? If I remember right, they only had one part# for this billet kit I got and not sure if its meant for an AC or non-AC car..?
[Re: mopower440]
#2684745
08/05/19 04:53 PM
08/05/19 04:53 PM
mopower440
middle Tennessee
I will order the correct crank pulley. So not much has been said about the aluminum water pump i pictured above..Anyone used this one with any luck? If i remember right (been a few years since i read it) that people were saying its a terrible design and not to use it. I read all of that after i had already bought it of course. Also, I have not been running a thermostat in this engine and know i need to, so i bought a murray branded stat from oreilly..is that ok to use or do i need a better brand or anything? Any mods need to be done to it before installing it?
