10 x 21/2 brake drums #2684196
08/03/19 11:04 PM
08/03/19 11:04 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Does anyone know where one may obtain 10 x 2/12 brake drums? I guess I should be a bit clearer, drums that are not stamped “ China” if anyone can furnish any help it would be appreciated! Thanks
Re: 10 x 21/2 brake drums [Re: 340cpe] #2684312
08/04/19 01:30 PM
08/04/19 01:30 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
I guess the no reply’s might answer my question!! LOL I have spent a bit of time looking and can find nothing, I suppose it is not a big deal, just something stamped China on a 48 year old muscle car just doesn’t seem right. Anyhow should someone come up with anything let me know and Thanks!
Re: 10 x 21/2 brake drums [Re: 340cpe] #2684319
08/04/19 01:44 PM
08/04/19 01:44 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Maybe you can find someone with old stock. A few years back I bought mopar nos ones off ebay. Maybe if not nos, then look for old stock bendix or something like that.
Here is a example. https://www.ebay.com/itm/Mopar-10-X-2-1-2-Heavy-Duty-Finned-Brake-Drums/292855043932
You may have to put in some search time but you probably can find some out there. It isn`t easy though.
Re: 10 x 21/2 brake drums [Re: mopars4ever] #2684341
08/04/19 03:00 PM
08/04/19 03:00 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Tried Rockauto?
Re: 10 x 21/2 brake drums [Re: AARCONV] #2684403
08/04/19 06:53 PM
08/04/19 06:53 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Yes I tried Rock they have China and have been looking on eBay. I’m good with new old stock Bendix or raybestos if they can be located. Thank you both for trying to help. The Search goes on!!
Re: 10 x 21/2 brake drums [Re: mopars4ever] #2684406
08/04/19 06:56 PM
08/04/19 06:56 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Although I was not looking for HD drums they are an option. I see no reason why they would not work. Thank You
Re: 10 x 21/2 brake drums [Re: 340cpe] #2684419
08/04/19 07:22 PM
08/04/19 07:22 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Strangely the best auto parts store I've had the best luck with finding Mopar brake drums and parts is Federated Auto Parts. Don't know why but they always had what I was looking for and always Made in USA (or Canada) up If you have a local Federated Auto Parts give them a call..........or not wink
http://www.federatedautoparts.com/
Mike
Re: 10 x 21/2 brake drums [Re: A12] #2684423
08/04/19 07:31 PM
08/04/19 07:31 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I found these at Federated and never thought anyone still riveted brake linings on..................and on Chrysler Pentastar shoe cores and by Bendix shock up
Re: 10 x 21/2 brake drums [Re: A12] #2684567
08/05/19 08:48 AM
08/05/19 08:48 AM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
I have a set of new drums, that I’ve had for years - let me check and see if there’s a manu. Country listed on them.
68 Charger
70 Cuda
Re: 10 x 21/2 brake drums [Re: FC7cuda] #2684586
08/05/19 09:50 AM
08/05/19 09:50 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I have a pair and the tapered ring around the axle opening sticks out far enough that the stock steel wheels don't contact the drum surface. Basically the wheels can't be tightened down all the way. These are from NAPA and ;I'm sure they are from China or wherever they make the best junk.
Re: 10 x 21/2 brake drums [Re: Neil] #2684611
08/05/19 10:36 AM
08/05/19 10:36 AM
Michigan Detroit area
Doc Schwarz Offline
Doc Schwarz  Offline
I have a complete front brake system, backing plates, all assembled with hoses. Took them off a drag car to install disc brakes.
Also have 4 drums, 2 are drilled for 5/8 studs and the front 2 are not attached to the hubs as they had 3 inch studs.
All are in good condition. Only about 50 miles or so. Bought them in 1996. Can't read where they were made, but
I think they are Raybestos. The shoes are riveted with gold anodizing, Bendix I think.
I loaded then into the truck last night, heading for the scrap yard. I you want these call me today and I will save them.
I'm headed to the Nats. can bring them there.
Call today or tomorrow morning going to scrap.
Doc Schwarz
734-341-0507
