Going to a 727, I have questions... #2683959
08/03/19 09:33 AM
08/03/19 09:33 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
We have to modify a 71 RR tunnel to put a 727 behind a 622 HP 505.
Removing the hump is easy, but are there other considerations?
A new driveshaft and Dana are in the future too, so those are figured in already.
Thanks, Joe
Re: Going to a 727, I have questions... [Re: jlatessa] #2683970
08/03/19 10:00 AM
08/03/19 10:00 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I must be missing something here. work
Master, again and still
Re: Going to a 727, I have questions... [Re: jlatessa] #2683978
08/03/19 10:18 AM
08/03/19 10:18 AM
Quote
was this a 4 speed?
Re: Going to a 727, I have questions... [Re: RapidRobert] #2683983
08/03/19 10:25 AM
08/03/19 10:25 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Yes, always ran autos, so my sons and I think it will make it easier on the driveline and our learning curve.
Just a little strip time planned to sort out a few things, so mostly meets and Sunday drives.
Many things to do yet, as the car is just a painted shell sitting on sub-frame dollies.
Beefed up the K-frame , adding sub-frame connectors, torque boxes and lower control arm stiffeners
so we don't twist the paint off....LOL
Gears will be 3.54
Thanks, Joe
Re: Going to a 727, I have questions... [Re: jlatessa] #2684007
08/03/19 11:15 AM
08/03/19 11:15 AM
More Mopars BB cars of all years and body styles where made with 727 than any other type of trans, it is a direct bolt in wrench scope
Re: Going to a 727, I have questions... [Re: Cab_Burge] #2684017
08/03/19 11:47 AM
08/03/19 11:47 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
So I just remove the "hump" and weld a patch to match the curve?
Thanks, Joe
Re: Going to a 727, I have questions... [Re: jlatessa] #2684041
08/03/19 12:42 PM
08/03/19 12:42 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I don't see why the hump couldn't stay.
68 Barracuda Formula S 340
Re: Going to a 727, I have questions... [Re: Bad340fish] #2684048
08/03/19 01:05 PM
08/03/19 01:05 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Good idea, put a plate over the opening and order a 4 speed carpet.
Can't see anything that might affect??
Thanks, Joe
Oh yeah, I'll need a trans support too
Re: Going to a 727, I have questions... [Re: jlatessa] #2684053
08/03/19 01:34 PM
08/03/19 01:34 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Kickdown linkage unless you have a manual valvebody that doesn't require it.
'63 Dodge 330
11.19 @ 121 mph
Re: Going to a 727, I have questions... [Re: GY3] #2684071
08/03/19 03:04 PM
08/03/19 03:04 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
MVB it will be......
Joe
Re: Going to a 727, I have questions... [Re: GY3] #2684073
08/03/19 03:09 PM
08/03/19 03:09 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I had a 67 Valiant that I put a 4 speed hump in. I made brackets to mount a Hurst Quarter Stick pistol grip shifter inside the hole and used a 4 speed boot over it. In my opinion looked way better than the cheap plastic or aluminum covers they sell.
Re: Going to a 727, I have questions... [Re: fbs63] #2684106
08/03/19 05:18 PM
08/03/19 05:18 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
You can even use a 4speed console over it.
Re: Going to a 727, I have questions... [Re: jlatessa] #2684146
08/03/19 07:05 PM
08/03/19 07:05 PM
Thanks, Joe
I wouldn't remove it tsk Make a screw in panel to cover the stock shifter hole and run it up
The 727 in a 4 speed car floor will give you more room to work on the tranny in the car to hook up the shift linkage and so on work up
Re: Going to a 727, I have questions... [Re: Cab_Burge] #2684192
08/03/19 10:56 PM
08/03/19 10:56 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Thank you all, that's the info I needed.
That makes life easier, appreciate the input.
Joe
Re: Going to a 727, I have questions... [Re: jlatessa] #2684621
08/05/19 10:51 AM
08/05/19 10:51 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
A friend did that exact same thing. Just cover the hole, he also just put the clutch pedal under the carpet.
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Going to a 727, I have questions... [Re: FurryStump] #2684651
08/05/19 11:54 AM
08/05/19 11:54 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I went auto 20 years ago.The clutch pedal just stayed on the floor untill recently I went on the Lee La Lane diet and changed to an auto pedal set up for the weight savings. As Lee says,,,,,,,,light is might and I took out 200 lbs. Every once counts!!
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2649161/1.html
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
