Re: Going to a 727, I have questions...
[Re: jlatessa]
#2683978
08/03/19 10:18 AM
08/03/19 10:18 AM
RapidRobert
Removing the hump is easy, but are there other considerations? was this a 4 speed?
[Re: RapidRobert]
#2683983
08/03/19 10:25 AM
08/03/19 10:25 AM
Posts: 1,315 Ohio
jlatessa
Ohio
Yes, always ran autos, so my sons and I think it will make it easier on the driveline and our learning curve.
Just a little strip time planned to sort out a few things, so mostly meets and Sunday drives. Many things to do yet, as the car is just a painted shell sitting on sub-frame dollies.
Beefed up the K-frame , adding sub-frame connectors, torque boxes and lower control arm stiffeners so we don't twist the paint off....LOL Gears will be 3.54
Thanks, Joe
[Re: jlatessa]
#2684041
08/03/19 12:42 PM
08/03/19 12:42 PM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
I don't see why the hump couldn't stay.
68 Barracuda Formula S 340 87 "Chrysler" Conquest
[Re: Bad340fish]
#2684048
08/03/19 01:05 PM
08/03/19 01:05 PM
Posts: 1,315 Ohio
jlatessa
Ohio
Good idea, put a plate over the opening and order a 4 speed carpet.
Can't see anything that might affect??
Thanks, Joe
Oh yeah, I'll need a trans support too
[Re: jlatessa]
#2684053
08/03/19 01:34 PM
08/03/19 01:34 PM
Posts: 4,651 Wichita
GY3
Wichita
Kickdown linkage unless you have a manual valvebody that doesn't require it.
[Re: GY3]
#2684071
08/03/19 03:04 PM
08/03/19 03:04 PM
Posts: 1,315 Ohio
jlatessa
Ohio
[Re: fbs63]
#2684106
08/03/19 05:18 PM
08/03/19 05:18 PM
Posts: 4,707 Moved to N.E. Tennessee
GomangoCuda
I had a 67 Valiant that I put a 4 speed hump in. I made brackets to mount a Hurst Quarter Stick pistol grip shifter inside the hole and used a 4 speed boot over it. In my opinion looked way better than the cheap plastic or aluminum covers they sell. You can even use a 4speed console over it.
[Re: jlatessa]
#2684146
08/03/19 07:05 PM
08/03/19 07:05 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
So I just remove the "hump" and weld a patch to match the curve?
Thanks, Joe I wouldn't remove it Make a screw in panel to cover the stock shifter hole and run it The 727 in a 4 speed car floor will give you more room to work on the tranny in the car to hook up the shift linkage and so on
[Re: FurryStump]
#2684651
08/05/19 11:54 AM
08/05/19 11:54 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I went auto 20 years ago.The clutch pedal just stayed on the floor untill recently I went on the Lee La Lane diet and changed to an auto pedal set up for the weight savings. As Lee says,,,,,,,,light is might and I took out 200 lbs. Every once counts!! https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2649161/1.html
