Silly steering wheel question #2683668
08/02/19 12:24 PM
08/02/19 12:24 PM
Indiana
68_661charger Offline OP
Indiana
I have the same steering wheel without the woodgrain in my truck and was wondering if the triangle part should be up or down going down the road? Ive seen both ways on the internet. It almost looks better triangle on the bottom but I want it the way it was supposed to be.
Re: Silly steering wheel question [Re: 68_661charger] #2683670
08/02/19 12:25 PM
08/02/19 12:25 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
Stock wheels are keyed to the shaft. You can't put it on but one way.
Re: Silly steering wheel question [Re: Sniper] #2683675
08/02/19 12:31 PM
08/02/19 12:31 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Does the center part just come off and then you can flip it around.
Re: Silly steering wheel question [Re: Sniper] #2683676
08/02/19 12:31 PM
08/02/19 12:31 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Some trucks do not have a master spline.
Re: Silly steering wheel question [Re: Alaskan_TA] #2683679
08/02/19 12:49 PM
08/02/19 12:49 PM
Indiana
Indiana
The center pad only goes on one way on steering wheel but the steering shaft holes for rag joint are in same position whether the steering wheel triangle is up or down. Im replacing steering box so thats why I can spin it and check easily. Im checking for a master spline now but if its not there then its orientation is still in question.
Re: Silly steering wheel question [Re: 68_661charger] #2683682
08/02/19 12:57 PM
08/02/19 12:57 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
correct as pictured twocents
Re: Silly steering wheel question [Re: 6bblgt] #2683687
08/02/19 01:08 PM
08/02/19 01:08 PM
Indiana
Indiana
The steering wheel has no master spline but the steering shaft has the space for one. I'll believe whatever you guys tell me.
Re: Silly steering wheel question [Re: 68_661charger] #2683688
08/02/19 01:26 PM
08/02/19 01:26 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
pretty sure every time i've taken the wheel off on a truck to replace the turn signal switch, when i put the wheel back on...i do it a few times so i can adjust it by one or two splines. i like the wheel a little off center so i can rest my elbow on the arm rest and my fingers are right at the bottom of the joint on the side of the wheel...
Re: Silly steering wheel question [Re: krautrock] #2683690
08/02/19 01:31 PM
08/02/19 01:31 PM
nowhere
nowhere
From the FSM
Re: Silly steering wheel question [Re: Sniper] #2683691
08/02/19 01:35 PM
08/02/19 01:35 PM
Indiana
Indiana
Ok thanks all!
Re: Silly steering wheel question [Re: 68_661charger] #2683699
08/02/19 02:03 PM
08/02/19 02:03 PM
I would install it the way you like it the most up work
Re: Silly steering wheel question [Re: 68_661charger] #2683810
08/02/19 08:01 PM
08/02/19 08:01 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I have a super low mile volare, same exact wheel, and wood goes up like shown.
Re: Silly steering wheel question [Re: buildanother] #2683847
08/02/19 09:30 PM
08/02/19 09:30 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Yep, wood grain up.
Also correct, Trunks do not have an indexed spline.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Silly steering wheel question [Re: moparmarks] #2683878
08/02/19 10:50 PM
08/02/19 10:50 PM
Indiana
Indiana
Alright. The woods up have it. Thanks guys!
Re: Silly steering wheel question [Re: 6bblgt] #2684514
08/05/19 12:27 AM
08/05/19 12:27 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
yep
