Air Shocks Revisited: #2681528
07/26/19 10:31 AM
07/26/19 10:31 AM
Highland, MI.
Sunroofcuda Offline OP
Highland, MI.
I recall a thread a few months ago about someone looking for air shocks, & wondering if anybody still made them?
Well, a couple weeks ago I was at a manufacturer show & one of my reps represents Gabriel & he was giving out the old vintage "Hi Jackers" running wabbit stickers! I asked him if these shocks were still available? Yep - still made by Gabriel.
Re: Air Shocks Revisited: [Re: Sunroofcuda] #2681560
07/26/19 11:34 AM
07/26/19 11:34 AM
moparx Online content
moparx  Online Content
alrighty then ! 160lbs of air to get the back end up so m-50's will clear on super reversed cragar ss's !
looking forward to that dumptruck like ride. wink
beer
Re: Air Shocks Revisited: [Re: Sunroofcuda] #2681566
07/26/19 11:39 AM
07/26/19 11:39 AM
robertop Offline
robertop  Offline
I have an original set from my bird that was removed to install original-type shocks. They have no leaks, but need a repaint. I also have an original, still in the box, dual line to inflate them separately, not together, which makes them work like a set of separate shocks, that is much better.
Re: Air Shocks Revisited: [Re: Sunroofcuda] #2681720
07/27/19 12:20 AM
07/27/19 12:20 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
The upper shock mounts on muscle era unibody Mopars are very thin and never meant to hold up the weight of the rear of a car!
'63 Dodge 330
11.19 @ 121 mph
Re: Air Shocks Revisited: [Re: GY3] #2681734
07/27/19 05:09 AM
07/27/19 05:09 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Sometimes you just need a minimal amount of air pressure, & would be no harm to frame. It's when you drive all the time with 100+psi that's a concern
Re: Air Shocks Revisited: [Re: moparx] #2681735
07/27/19 05:27 AM
07/27/19 05:27 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
beer
Hey, now! I resemble that remark. Lol. Of coarse I had lots of hair back then as well. It was good to be a dumb kid and your Cuda was your only transportation. Of coarse some people just cut the fenderwells out and put flares on them. At least I was not so dumb I modified my body. It was bad enough throwing away oem parts or swapping my parts to another car before I sold it.
Re: Air Shocks Revisited: [Re: fastmark] #2681743
07/27/19 07:14 AM
07/27/19 07:14 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
When I do drag week I swap on some air shocks for the road since I carry a passenger and 300lbs of junk in the back. 30-40psi in the air shocks keeps it level and really smooths out the ride of the cal trac mono leaf springs.
68 Barracuda Formula S 340
Re: Air Shocks Revisited: [Re: PhillyRag] #2681916
07/27/19 10:45 PM
07/27/19 10:45 PM
BlueRacer69 Offline
BlueRacer69  Offline
Agree. I ran air shocks for a number of years on my new 69 Dart back in those days with no harm to anything. Of course I did not blow them up to 100+lbs, only about 60lbs or just enough to get a little rake to the rear of the car. FYI, Monroe Shocks also still makes a air shock today.
Re: Air Shocks Revisited: [Re: BlueRacer69] #2681933
07/28/19 05:31 AM
07/28/19 05:31 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
I once had airshocks on a car I bought.
They were gone a week later...
Re: Air Shocks Revisited: [Re: BigBlockMopar] #2682064
07/28/19 03:53 PM
07/28/19 03:53 PM
SE Indiana
K
kowalski440 Offline
kowalski440  Offline
K
SE Indiana
I remember a traction/ go fast tip from Tony Defoe about running one air shock on the pass side to preload the springs. Raising that side about .5 -2 " higher (a tuning variable).
This applies to std/HD springs, not the SS ones. That doesn't take much pressure, and I'm sure would work fine today, also.
Re: Air Shocks Revisited: [Re: Sunroofcuda] #2682077
07/28/19 05:23 PM
07/28/19 05:23 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Yep I don't think Gabriel ever stopped making them. Big item for RV trailer towing, in fact the local Advance Auto Parts had a set and keeps a set in stock year round. I guess being close to I-80 / I-90 customers come in with their tails and wagons dragging along with all of the hot rods in the area looking for a set.
Summit has them for just about anything you can think of Summit Gabriel Air Shock link for '69 Road Runner click here
