A904 Line Pressure Issues #2681884
07/27/19 07:33 PM
07/27/19 07:33 PM
Albuquerque, NM
GOAT Duster Offline OP
Albuquerque, NM
My Transmission was recently rebuilt and has a used throttle body. I have a TCI torque converter. It is all behind a 360. Oh yeah and a Lokar kickdown cable. (I know I know, I read the reviews and will likely be changing it out for the Bouchillion one or stock one.
So here is the problem: I have reverse and 1st gear...no upshift. I did some testing: fluid is full, line pressure is at 80psi in 1st gear @ 1000 rpm which is high from what I am reading, should be around 54 to 60 rising to 90 to 96 when throttle lever is moved. It doesn't increase as the throttle linkage is moved. This led me to check my line pressure in drive at 1600 rpm at the front servo release port. Nothing, nota, no reading what so ever, even when the throttle position linkage is moved.
Please if anyone has experienced this or knows what could be the problem please advise.
Re: A904 Line Pressure Issues [Re: GOAT Duster] #2681896
07/27/19 08:47 PM
07/27/19 08:47 PM
trans was OK before the rebuild? (other than needing rebuilding). did the rebuilder note any specific part changes (valve body etc). this is more of a BTT for ya.
Re: A904 Line Pressure Issues [Re: RapidRobert] #2681897
07/27/19 08:56 PM
07/27/19 08:56 PM
Albuquerque, NM
Albuquerque, NM
Trans had a broken valve body, so a used one purchased online was put in it. Trans was given to me in the broken state, so I am not sure of what else may have been wrong. Since condition was unknown a rebuild was decided on. I was thinking that the throttle position lever was put in wrong since it doesn't do anything. Or maybe the valve body was bad...it was used after all. Problem is the trans was redone over a year ago and sat for the past year until the project picked up again.
Re: A904 Line Pressure Issues [Re: GOAT Duster] #2681902
07/27/19 09:29 PM
07/27/19 09:29 PM
I'd wait for Kunkel & Transman to chime in but if it was me I'd wanna do something with/about the VB (the brain) AFTER pulling the pan & seeing if the throttle pressure linkage etc looks right. (not my area just thinking out loud).
Re: A904 Line Pressure Issues [Re: GOAT Duster] #2682019
07/28/19 12:43 PM
07/28/19 12:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Disconnect the Lokar cable at the transmission lever and push the lever full forward. If it will upshift with the cable disconnected, the problem is in the cable installation/adjustment. If it still won't upshift the problem is internal.
Re: A904 Line Pressure Issues [Re: John_Kunkel] #2682051
07/28/19 03:16 PM
07/28/19 03:16 PM
John you're the man (as always).
Re: A904 Line Pressure Issues [Re: John_Kunkel] #2682118
07/28/19 07:52 PM
07/28/19 07:52 PM
Albuquerque, NM
Albuquerque, NM
Still no shift with cable disconnected...would you suggest starting with the vavlebody since it is the easiest to get to? Was thinking of adding a Transgo TF-2 shift kit in the future anyways.
Re: A904 Line Pressure Issues [Re: GOAT Duster] #2682142
07/28/19 09:16 PM
07/28/19 09:16 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
popcorn
Re: A904 Line Pressure Issues [Re: GOAT Duster] #2682296
07/29/19 10:59 AM
07/29/19 10:59 AM
moparx Offline
moparx  Offline
did you disassemble & clean the valvebody before installation ? if so, maybe one of the check balls got placed in the wrong position or omitted.
if not, there may be a sticking valve or "???" inside the valvebody.
in either case, i would remove the valvebody, disassemble & clean, then inspect closely to see if anything may be suspect. then proceed accordingly with what is found.
beer
Re: A904 Line Pressure Issues [Re: GOAT Duster] #2682351
07/29/19 01:14 PM
07/29/19 01:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Before removing anything, I would check the governor pressure, no governor, no upshift. It's fairly common to have a governor failure right after an overhaul due to improper assembly of the governor.
Re: A904 Line Pressure Issues [Re: John_Kunkel] #2682522
07/29/19 09:06 PM
07/29/19 09:06 PM
Albuquerque, NM
Albuquerque, NM
John_Kunkel, Thanks for your assistance thus far. I never thought to check the governor pressure. Unfortunately that wasn't the problem, it acted just as you described it would. I guess in reality that is fortunate not unfortunate. LOL While checking tonight I put the gauge back on the kickdown band plug and did notice that the pressure gauge did move ever so slightly when it is first put into gear but then stayed at zero. Not sure if this gives you any more to go off or not. At this point do you think that removing the throttle body and giving it a good cleaning to ensure there are no sticky check balls, ect… is worth a shot?
Re: A904 Line Pressure Issues [Re: UCUDANT] #2682523
07/29/19 09:07 PM
07/29/19 09:07 PM
Albuquerque, NM
Albuquerque, NM
Love it Bob, what's the color scheme for this one?
Re: A904 Line Pressure Issues [Re: moparx] #2682524
07/29/19 09:09 PM
07/29/19 09:09 PM
Albuquerque, NM
Albuquerque, NM
moparx...thinking you might be onto something there. Looking more and more like that is going to be next weekends project.
Re: A904 Line Pressure Issues [Re: GOAT Duster] #2684074
08/03/19 03:17 PM
08/03/19 03:17 PM
Albuquerque, NM
Albuquerque, NM
In the middle of valve body rebuild. Adding a Transgo shift kit while I'm in here. Found a broken spring and a stuck plunger so far. Thinking I found the priblem. I'll update once everything is back together.
Re: A904 Line Pressure Issues [Re: GOAT Duster] #2684469
08/04/19 10:01 PM
08/04/19 10:01 PM
Albuquerque, NM
Albuquerque, NM
Well final post I guess. Put everything back together and got 3 gears. Sweet. Thanks to those of you that gave your input. Learned some things I didnt know for sure.
Again thanks Moparts family
Re: A904 Line Pressure Issues [Re: GOAT Duster] #2684610
08/05/19 10:34 AM
08/05/19 10:34 AM
moparx Offline
moparx  Offline
it's ALWAYS happy time when things get fixed ! boogie glad you got it figured out.
beer
