Re: A904 Line Pressure Issues
[Re: GOAT Duster]
#2681896
07/27/19 08:47 PM
07/27/19 08:47 PM
RapidRobert
trans was OK before the rebuild? (other than needing rebuilding). did the rebuilder note any specific part changes (valve body etc). this is more of a BTT for ya.
[Re: RapidRobert]
#2681897
07/27/19 08:56 PM
07/27/19 08:56 PM
Posts: 106 Albuquerque, NM
GOAT Duster
Albuquerque, NM
Trans had a broken valve body, so a used one purchased online was put in it. Trans was given to me in the broken state, so I am not sure of what else may have been wrong. Since condition was unknown a rebuild was decided on. I was thinking that the throttle position lever was put in wrong since it doesn't do anything. Or maybe the valve body was bad...it was used after all. Problem is the trans was redone over a year ago and sat for the past year until the project picked up again.
[Re: GOAT Duster]
#2681902
07/27/19 09:29 PM
07/27/19 09:29 PM
RapidRobert
I'd wait for Kunkel & Transman to chime in but if it was me I'd wanna do something with/about the VB (the brain) AFTER pulling the pan & seeing if the throttle pressure linkage etc looks right. (not my area just thinking out loud).
[Re: GOAT Duster]
#2682019
07/28/19 12:43 PM
07/28/19 12:43 PM
Posts: 25,729 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Disconnect the Lokar cable at the transmission lever and push the lever full forward. If it will upshift with the cable disconnected, the problem is in the cable installation/adjustment. If it still won't upshift the problem is internal.
[Re: GOAT Duster]
#2682296
07/29/19 10:59 AM
07/29/19 10:59 AM
Posts: 19,310 north of coder
moparx
did you disassemble & clean the valvebody before installation ? if so, maybe one of the check balls got placed in the wrong position or omitted. if not, there may be a sticking valve or "???" inside the valvebody. in either case, i would remove the valvebody, disassemble & clean, then inspect closely to see if anything may be suspect. then proceed accordingly with what is found.
[Re: GOAT Duster]
#2682351
07/29/19 01:14 PM
07/29/19 01:14 PM
John_Kunkel
Rio Linda, CA
Before removing anything, I would check the governor pressure, no governor, no upshift. It's fairly common to have a governor failure right after an overhaul due to improper assembly of the governor.
[Re: UCUDANT]
#2682523
07/29/19 09:07 PM
07/29/19 09:07 PM
GOAT Duster
Albuquerque, NM
Love it Bob, what's the color scheme for this one?
