30 gallon fuel cell with sump - any out there? #2681474
07/26/19 03:02 AM
07/26/19 03:02 AM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
Ideally I am looking for a poly plastic 30 gallon fuel cell with a sending unit, foam and sump with outlet(s) and two outlets on top. I can find a 20, but not any larger. Just throwing this out there if anyone knows of a 30. Thanks.
RS23L7 4-Speed
Re: 30 gallon fuel cell with sump - any out there? [Re: Mopar_Mike] #2681499
07/26/19 09:12 AM
07/26/19 09:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Why do you want to carry that much fuel.. when I built my tank it was
18 gals.. that last a long time and you dont have to carry that much
weight
wave
Re: 30 gallon fuel cell with sump - any out there? [Re: MR_P_BODY] #2681508
07/26/19 09:27 AM
07/26/19 09:27 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Contact Rhodes Race Cars. They will build whatever you want.
Re: 30 gallon fuel cell with sump - any out there? [Re: fbs63] #2681510
07/26/19 09:39 AM
07/26/19 09:39 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
this guy will make whatever you want , his work is fantastic
https://www.facebook.com/pages/category/Local-Business/Winchester-Metal-Works-818250571547880/
: (603) 903-9737
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 30 gallon fuel cell with sump - any out there? [Re: MR_P_BODY] #2681521
07/26/19 10:08 AM
07/26/19 10:08 AM
Danville, NH
Danville, NH
I’m de-tuning a race car for the street. It is already set up
with a trunk mounted cell and pump. Since the car probably will
get about 10 miles per gallon lol I want to be able to drive
without stopping at every gas station along the way lol
RS23L7 4-Speed
Re: 30 gallon fuel cell with sump - any out there? [Re: bigdad] #2681522
07/26/19 10:10 AM
07/26/19 10:10 AM
Danville, NH
Danville, NH
Thanks for the info guys!
RS23L7 4-Speed
Re: 30 gallon fuel cell with sump - any out there? [Re: Mopar_Mike] #2681525
07/26/19 10:22 AM
07/26/19 10:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I bought a complete gauge cluster for my car so the fuel gauge was
part of it... they are easy to set up to have it match your tank
wave
Re: 30 gallon fuel cell with sump - any out there? [Re: Mopar_Mike] #2681540
07/26/19 10:52 AM
07/26/19 10:52 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
My Hemi got a new best this year of 6.7 mpg over last years 6.5 mpg......Can't go too far with it, but it sure lets you know somthing isn't stock under the hood...
Re: 30 gallon fuel cell with sump - any out there? [Re: Dragula] #2681559
07/26/19 11:30 AM
07/26/19 11:30 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
My 416 usually gets about 13mpg loaded on drag week (4200lbs or so with passenger and gear). I have an 18 gallon tank and I think the farthest we have ever run was like 140 miles or so on a tank. At that point you get fuel just because you don't know the area and don't know when you will see fuel again. Also after that long at 3000RPM -3500RPM even with tail pipes and stock seats its time to get out for a few minutes. I couldn't imagine going 300 miles lol.
68 Barracuda Formula S 340
Re: 30 gallon fuel cell with sump - any out there? [Re: Mopar_Mike] #2681578
07/26/19 12:24 PM
07/26/19 12:24 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have a 1977 RamCharger fuel tank that is 30-gallons. I cut an access hole in the top, and installed a -6 AN bulkhead with 3/8" pickup.
I should have put fuel cell foam in it as fuel slosh with a 1/2 tank can spin the car out.
What ever you get make sure it has something to stop the fuel slosh in a tank that big.
Re: 30 gallon fuel cell with sump - any out there? [Re: 451Mopar] #2681587
07/26/19 01:00 PM
07/26/19 01:00 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I have a 22 gallon Rhodes........I added foam , the filler and a different sending unit.
The tank itself was a hell of a value , and after the rest of the stuff I added , it was still in the 400.00 neighborhood.
Re: 30 gallon fuel cell with sump - any out there? [Re: tubtar] #2681609
07/26/19 02:45 PM
07/26/19 02:45 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
30 gallons of fuel is nearly 200lb. plus the weight of the tank. The tank itself will need to be more substantial for the weight, as will the mounting, and it will be over 4 cubic feet.. That's a bunch in the back of a car with a race type suspension. If you're set on that amount of fuel, 2 15 gallon units may be something that makes sense. Or a single 20 gallon. Or some configuration that allows for a second, easily installed and removed tank for use on road trips that can be removed or emptied and isolated to go to the track.
Re: 30 gallon fuel cell with sump - any out there? [Re: CMcAllister] #2681628
07/26/19 04:17 PM
07/26/19 04:17 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Not a bad idea, 2 tanks would allow one for pump gas and one for race gas.
Re: 30 gallon fuel cell with sump - any out there? [Re: bigdad] #2681629
07/26/19 04:23 PM
07/26/19 04:23 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
That guy is talented. Very nice. Will keep this number. Thanks
Re: 30 gallon fuel cell with sump - any out there? [Re: Bad340fish] #2681779
07/27/19 10:57 AM
07/27/19 10:57 AM
AZ
squirrel Offline
squirrel  Offline
AZ
this!
Having done drag week several times, I will attest that 150 miles range is plenty, if your car is snotty enough to be fun.
