DANA ID #2681028
07/24/19 08:44 PM
07/24/19 08:44 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Sitting at my garage door is a newer Dana. A note on it says ,"late model Dana 60 from a late 90's early 2000 Dodge Ram and you fool around with hot rods so you can have it". It has a blue plastic filler cap on top of the center section. Very clean. Looks like very low miles. Is this a candidate for a cut down and modify for my next project? I'll get some pics later.
Re: DANA ID [Re: A/MP] #2681036
07/24/19 09:15 PM
07/24/19 09:15 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Wow sounds like the Karma wheel rolled your way up Might have the large tubes but you can work around that.
Gus beer
64 Plymouth Savoy
Dana 60
Re: DANA ID [Re: fourgearsavoy] #2681228
07/25/19 11:57 AM
07/25/19 11:57 AM
montana
BANDIT Offline
BANDIT  Offline
montana
That blue plastic cap is where the speed sensor/ABS sensor went, but your description works too. Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: DANA ID [Re: A/MP] #2681246
07/25/19 12:50 PM
07/25/19 12:50 PM
AZ
squirrel Offline
squirrel  Offline
AZ
look at the housing where the tube meets the bearing, see if it looks like the bearing race spun and ate up the housing. Pretty common problem on the truck Danas.
