Re: Looking for E body convertible A pillar seals
[Re: 71TA]
#2699874
09/22/19 02:14 PM
09/22/19 02:14 PM
Posts: 636 SE PA
cudaize
SE PA
Jim, That would be great to have some nice repros of these. http://stores.restorationspecialties.com/92212-ws/ This is pretty close to the top rail profile. What's nice is that it comes in a length and you can install and make the cuts like you say for the miter. The header seals in the Soffseal kits are about the the only thing worthwhile in them if you're worried about originality. The outer one once installed is almost identical and the inner one is pretty close, just the ends into the window rail need to be glued in to get their shape proper. As you said the pieces above the windows are not correct the profile and the ones at the quarter windows are no where near correct. All in all not a bad kit if you're just looking to seal things up but not 100% correct to original. Mike Afflerbach
[Re: 71TA]
#2701871
09/28/19 11:10 PM
09/28/19 11:10 PM
Posts: 28,599 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
These seals
(What a SPECTACULAR looking Challenger vert too! Man I dig that Alpine White)
Jim, I have them in a box in my attic. I was up there Midweek and will look next time I completely forgot plus was unsure what ones ya needed. Sorry
[Re: 71TA]
#2999741
12/29/21 10:36 PM
12/29/21 10:36 PM
Posts: 1,547 Mattituck NY.
FJ6AAR
Mattituck NY.
Just placed an order with you for these! Rob
1970 Hemi 'Cuda hard top clone
1971 Hemi 'Cuda Convertible clone
[Re: 71TA]
#3000089
12/30/21 08:18 PM
12/30/21 08:18 PM
Posts: 12,431 Warren, MI
71TA
Warren, MI
Still working on the new header pieces AND the top sections. The Soffseal ones that were the only ones available before DIDN'T MITER THE TOP SECTIONS. They had the correct profiles but just cut them straight!!! I do NOT understand some companies. They are probably all golfers not really car guys. For cryin out loud, MAKE THE STUFF CORRECTLY. Measure. Review the prints. Test fit. Repeat until correct. Heres a picture of NOS ones (that I MISSED buying!) Yoiu can see the mitered ends on the top sections. 2 are sponge rubber. The ones at the back edge of the qtr glass are hard, flocked rubber. https://www.forebodiesonly.com/foru...lenger-conv-nos-top-weatherstrips.19646/
[Re: 71TA]
#3000287
12/31/21 01:34 PM
12/31/21 01:34 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
Can the the softseal parts be modified to work
NS1AAR
[Re: 71TA]
#3001952
01/04/22 01:26 PM
01/04/22 01:26 PM
Posts: 1,070 Ohio
C_B5
Ohio
Still working on the new header pieces AND the top sections. The Soffseal ones that were the only ones available before DIDN'T MITER THE TOP SECTIONS. They had the correct profiles but just cut them straight!!! I do NOT understand some companies. They are probably all golfers not really car guys. For cryin out loud, MAKE THE STUFF CORRECTLY. Measure. Review the prints. Test fit. Repeat until correct. Heres a picture of NOS ones (that I MISSED buying!) Yoiu can see the mitered ends on the top sections. 2 are sponge rubber. The ones at the back edge of the qtr glass are hard, flocked rubber. https://www.forebodiesonly.com/foru...lenger-conv-nos-top-weatherstrips.19646/ Jim, Do you need a set of original e-body convertible top rubber seals to use as patterns for the reproduction ? Let me know as I have a set of original pieces (most nice enough that I planned to re-use them on my car since as you stated the current repro ones are not correct). Chas
