Using 440 Bellhousing with a Hemi? #2680630
07/23/19 06:33 PM
07/23/19 06:33 PM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
I have a 67 Coronet with a 426 hemi and automatic. I want to switch over to a 4-speed. I have a 67 440 bellhousing 2843234 to use. First, will it work with the hemi? second, I know I need an 8-bolt flywheel, but 11" and 172 tooth one? I am wondering about starter issues? I plan to use stock exhaust manifolds and a mini-starter. Third, will other 440 parts ie torque bar, clutch fork, 4-speed driveshaft etc. work. Thanks for your help.
RS23L7 4-Speed
Re: Using 440 Bellhousing with a Hemi? [Re: Mopar_Mike] #2680634
07/23/19 06:44 PM
07/23/19 06:44 PM
AndyF Offline
AndyF  Offline
Depends what you mean by work. For example you can buy an 8 bolt 130 tooth flywheel and then use a 10.5 inch clutch. That will all physically bolt together but it might not hold up to the power of the Hemi. Just depends on how much torque the Hemi makes. Best bet is to jump on Brewer's website and figure out the parts you need and then talk to them about a clutch package that will fit your parts and hold up to the Hemi. There might be a solution and there might not be.
Re: Using 440 Bellhousing with a Hemi? [Re: AndyF] #2680641
07/23/19 07:14 PM
07/23/19 07:14 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
172-tooth pretty much locks you into either a RobbMC starter (excellent but $$$) or the direct-drive OEM piece (slow as molassses and REALLY spendy).
Like Andy says, call Brewer's (or Passon) and ask them for specifics depending on what you have going on.
Re: Using 440 Bellhousing with a Hemi? [Re: topside] #2680666
07/23/19 08:25 PM
07/23/19 08:25 PM
BC Canada
O
ogopogo Offline
ogopogo  Offline
O
BC Canada
im pretty sure a 67 440 bell would use a 11in clutch and 143 tooth flywheel,mini starter will be fine
Re: Using 440 Bellhousing with a Hemi? [Re: ogopogo] #2680669
07/23/19 08:28 PM
07/23/19 08:28 PM
Danville, NH
Danville, NH
Thanks all for your replies and advice.
RS23L7 4-Speed
Re: Using 440 Bellhousing with a Hemi? [Re: ogopogo] #2680671
07/23/19 08:30 PM
07/23/19 08:30 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
According to Brewer's 2843234 is a 143 tooth bellhousing
Re: Using 440 Bellhousing with a Hemi? [Re: Sniper] #2680708
07/23/19 10:01 PM
07/23/19 10:01 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
If you use 143 flywheel and 67 bell the starter will hit the manifold even mini starter I have seen shimming the manifold with a header flange
I'm using 1970 bell 130 flywheel and mini starter still tie fit with manifolds all so use 10.95 clutch 500 hp works well
I do have a 67 4 speed hemi bell available
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: Using 440 Bellhousing with a Hemi? [Re: 1969gtx] #2680733
07/23/19 11:11 PM
07/23/19 11:11 PM
VA
dragon slayer Offline
VA
You also need to match the bell house to trans bearing retainer. The 67 is small hole bell. Depending on what you have for a hemi 4 Speed and which size bearing retainer is installed, may also have to get it.
Re: Using 440 Bellhousing with a Hemi? [Re: dragon slayer] #2680742
07/24/19 12:05 AM
07/24/19 12:05 AM
Danville, NH
Danville, NH
Yeah, I have a 67 18 spline so it will match the 67 bell I have.. hitting the bell with the starter is upsetting though..
RS23L7 4-Speed
Re: Using 440 Bellhousing with a Hemi? [Re: Mopar_Mike] #2680755
07/24/19 03:20 AM
07/24/19 03:20 AM
The factory made many 1967 Hem B body 4 peed cars, I'm not sure if all of them or some of them had the 172 flywheel with the direct drive starters and some where built with the 143 tooth flywheel, bell housing and gear drive starters or not confused
I do know you could use a 383-440 130 tooth bell housing with a 10.95 size clutch and a 8 bolt 130 steel or aluminum flywheel as already pointed out to make sure it clears the stock exhaust work you might have to have your front bearing retainer turn down to fit into the small front bearing size on the stock bellhousing also, maybe not shruggy
All the 18 spline 833NP I've owned and work on all had the large 308 front bearings along with the large front bearing retainers, I was using Ansens and Lakewood scatter shields and not stock bell housing to run my old Hemi car in NHRA A/S stock class, that was a non hooking experience for 2.5 yrs whiney
Re: Using 440 Bellhousing with a Hemi? [Re: Mopar_Mike] #2680824
07/24/19 09:03 AM
07/24/19 09:03 AM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Best to use 10.5" stuff with Hemi and exhaust manifolds. Clutch size is a non issue.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: Using 440 Bellhousing with a Hemi? [Re: Dan Brewer] #2680827
07/24/19 09:08 AM
07/24/19 09:08 AM
Danville, NH
Danville, NH
Thanks Dan!
RS23L7 4-Speed
