New best ET at Woodburn #2679937
07/22/19 12:09 AM
07/22/19 12:09 AM
Cab_Burge Offline OP
I towed over to Woodburn for the Mopar Nats. this morning, I made three time trails and one round, spun the heck out of the tires on the 1st TT and 1st round against Forest Fincher whiney The 1st TT I had 11.0 lbs. in the tires and it spun so bad on the line it shifted into high at 7250 RPM according to the Biondo 400 box on the play back after the run, it did run 10.088 ET at 148.24 MPH after letting off to recover and making the rest of the run in high gear shock
2nd run I made sure the tires where at 9.0 lbs. and I redlighted with a -.049 light jerking the front tires out of the beams while running 8.866 at 148.33 MPH confused
I change the shift RPM from 7000 RPM up to 7300 RPM and change the trans brake delay from .993 to 1.00. I removed the 7600 RPM chip from the MSD three step which made it run a bunch better the last two hundred feet upThat netted a .037 light with a 8.862 ET at 150.77 MPH, slightly slower MPH than I expected work
I spun the heck out of the tires on the first round due to me not being ready when they called us out which made me hurry with out checking the tires and not doing a good burn out realcrazy whiney
All in all I'm happy with the ET but I need to figure out where this new motor wants to be shifted at and see if there is some power missing due to ignition issues, possibly luck
Re: New bset ET at Woodburn [Re: Cab_Burge] #2679975
07/22/19 05:32 AM
07/22/19 05:32 AM
Mo.
racerx Offline
racerx  Offline
Mo.
What's the new combo? and this is in your cuda correct?
Re: New bset ET at Woodburn [Re: racerx] #2679992
07/22/19 08:07 AM
07/22/19 08:07 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Always great to get a new bestie! And a bad day at the track is always better than a day at work! boogie
Any pictures Cab?
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: New bset ET at Woodburn [Re: Cab_Burge] #2680026
07/22/19 09:55 AM
07/22/19 09:55 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Nice pass, congrats Cab. up
Re: New bset ET at Woodburn [Re: justinp61] #2680112
07/22/19 02:20 PM
07/22/19 02:20 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Nice job!
Re: New bset ET at Woodburn [Re: Cab_Burge] #2680125
07/22/19 02:53 PM
07/22/19 02:53 PM
an8sec70cuda Offline
Very nice Cab!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: New bset ET at Woodburn [Re: an8sec70cuda] #2680221
07/22/19 07:38 PM
07/22/19 07:38 PM
pacific northwest
Stroker Scamp Online content
Stroker Scamp  Online Content
pacific northwest
Good job Cab! Missed another one here. Life getting in the way of having fun
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: New bset ET at Woodburn [Re: Cab_Burge] #2680225
07/22/19 07:45 PM
07/22/19 07:45 PM
AndyF Online content
AndyF  Online Content
8.80 is hauling for a door slammer E body car. Nice looking car too. How much were you asking for the car and did you get any offers on it?
Re: New bset ET at Woodburn [Re: racerx] #2680227
07/22/19 07:50 PM
07/22/19 07:50 PM
This motor is a 400 block cast on 8-25-1977 that sonic tested oaky bored to 4.375 with 440 Source aluminum main caps and ARP Main studs with no fill or girdle. 4.300 forged steel stroke crankshaft, Molnar 6.700 long forged steel BB Chevy type H beam rods with ARP 2000 bolts. Diamond pistons with a +8.0 CC effective dome, Indy 440-1 CNC ported heads with 2.25 intake valves s and 1.81 exhaust valves, Jesel paired shaft 1.55 ratio rocker arms, Bullet solid roller cam with 282 @ .050 on both lobes with .457 lobe lift on both lobes, ground on a 108 LSA installed at 104 ILC.
Indy older 400-3 intake with a custom built Holley 1150 CFM Dominator converted to E 85 by AJ at Bob George racing mounted on top of a Wilson Manifold 2.0 inch tall reversion spacer:up
I change the distributor this morning due to the old one causing hard starting, back firing while trying to start it and a lot of other ignition problems, dang Chinese junk anyways rant It took me this long, half the summer racing season, to figure out what was causing these problems blush
I'm hoping the rest of this year will go better luck
This motor had issues with the Mopar brand bronze oil pump drive on the engine dyno in March causing the distributor to wobble around while trying to start it shock
I discovered the original rotor and cap on this new distributor was bad in June after it starting to miss in high gear and the intermittent hard starting has been occurring since day one on this motor work
I hate MURPHY runaway
Re: New bset ET at Woodburn [Re: Cab_Burge] #2680235
07/22/19 08:04 PM
07/22/19 08:04 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Good job Cab. Congratulations on the new best.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: New bset ET at Woodburn [Re: Cab_Burge] #2680238
07/22/19 08:19 PM
07/22/19 08:19 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Congrats on the new best Cab. I am sure you will work through the details bitting you in the butt.
"Just a Bracket car dressed up like a streetcar"
Re: New bset ET at Woodburn [Re: Just-a-dart] #2680250
07/22/19 09:20 PM
07/22/19 09:20 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Congrats on the new best.
That’s a nice running combo.
Cam looks very similar to the old UD 680/280R8
What’s the rest of the car set up like? Weight?
Re: New bset ET at Woodburn [Re: fast68plymouth] #2680279
07/22/19 11:42 PM
07/22/19 11:42 PM
It is a chrome moly tube chassis with A arm and coil over A arm front suspension with Koni steel single adjustable front shocks, 4 link Dana 60 with Mark Williams 40 spline axles, 4.56 dana Corp gears on a Moser 40 spline steel spool, double adjustable steel rear coil over Koni shocks, Power glide tranny w/Shiftnoid air shifter and throttle controller, 400 Biondo box.
Steel front end that slides off, Fibreglas doors, bumpers, hood and rear deck lid, all Lexan windows except a stock windshield.
I had Forest Fincher update the chassis this past winter to meet 7.50 SFI specs, he had it certified also up
it weighs right at 2800 lbs. wet with me in it.
The Ultra Dyne cam card shows CRB 312/312-08R. Part # 503000.
The car goes straight and repeats time if I do the burn out correctly and make sure the tire pressures are correct whistling blush
I would like to sell this one so I can get the back half 1966 Dart done and start racing it luck
Re: New bset ET at Woodburn [Re: Cab_Burge] #2680385
07/23/19 10:03 AM
07/23/19 10:03 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Well that is good news...congrats!
Rich H.
Esse Quam Videri
Re: New bset ET at Woodburn [Re: ZIPPY] #2680434
07/23/19 11:18 AM
07/23/19 11:18 AM
moparx Offline
moparx  Offline
good deal cab ! up
beer
Re: New bset ET at Woodburn [Re: moparx] #2680723
07/23/19 10:37 PM
07/23/19 10:37 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Nice job Cab. I was parked right next to you at the trailer, just never got a chance to come say hello. Was a good weekend. smile
I was in the 4 speed class and was trying to watch you guys from my car since we were right after.
Re: New bset ET at Woodburn [Re: Cab_Burge] #2680743
07/24/19 12:45 AM
07/24/19 12:45 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Back out in fine fashion Cab! Nice passes!
Re: New bset ET at Woodburn [Re: Cab_Burge] #2680808
07/24/19 08:03 AM
07/24/19 08:03 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Originally Posted by Cab_Burge
............. Bullet solid roller cam with 282 @ .050 on both lobes with .457 lobe lift on both lobes, ground on a 108 LSA installed at 104 ILC....
!Not that it matters! ...but I can't make sense of which cam you're using? I have an older Ultradyne cam list and this cam has ANY PAIRING of the numbers you listed it is not from them. I wonder if the cam wasn't reground by Bullet and the PN is the original grind. Anyway NICE to hear you out having fun and running good!
Re: New bset ET at Woodburn [Re: HardcoreB] #2680881
07/24/19 11:39 AM
07/24/19 11:39 AM
So. Burlington, Vt.
So. Burlington, Vt.
I had remembered that as a cataloged cam from UD, but I looked in my old catalog and it’s not there.
Then I remembered the two that I used were just something I had ground.
Only 3 lobes in that lobe family, 296, 308, 312.
The 312 is listed as 280@.050, but since they didn’t use different(bigger OD) masters for the BBM core size, it would grow 2* @.050 from the design spec.
Listed as 312@.020, 280@.050, 201@.200, .4567 lobe lift.
I had really good results with those.
The 311R8 was also quite popular.
Very similar, but slower lobes.
Re: New bset ET at Woodburn [Re: fast68plymouth] #2681471
07/26/19 02:26 AM
07/26/19 02:26 AM
Cottage Grove OR
WFO Offline
WFO  Offline
Cottage Grove OR
Damn, I'm definitely coming prepared to stay on Saturday next year. It snuck up on me this year and I was there Friday for the test and tune.
Hey Cab, what is your compression ratio? I love E85 but I've only run it on turbo motors.
'65 Plymouth Sport Fury
Blow thru twin turbo coming soon...
