Re: late model 5.2 or 5.9 MPI / OD in earlier chassis
[Re: gtx6970]
#2680257
07/22/19 09:47 PM
07/22/19 09:47 PM
Posts: 10,540 Freeport IL USA
poorboy
Freeport IL USA
I did a 97 5.9 with the RE46 into a 39 Dodge pickup. I bought a Hot Wire harness ( www.hotwireauto.com) not cheap, but is a plug and play with 4 wires to hook up to make the Mopar EFI run. Now, if my luck with the trans would have been as good as the efi was, I'd be driving it now. Note to sef, always install a rebuilt/re-manufactured auto trans.... Gene
[Re: gtx6970]
#2680290
07/23/19 12:06 AM
07/23/19 12:06 AM
Posts: 20,633 in a cattle trailer down by th...
Guitar Jones
I am doing something similar, see my sig line. I am taking everything from the donor Ram Charger though including the dash, HVAC, steering column, wiring harnesses, fuel tank and lines. I'm also using a NV4500 from a 97 2WD 2500. I am nowhere near done though. At this point I just have the donor truck stripped and the 93 OBD1 converted to an 01 OBD2 controller.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Twostick]
#2680700
07/23/19 09:35 PM
07/23/19 09:35 PM
poorboy
Freeport IL USA
A buddy of mine has the perfect solution for you. A 93 D150 chassis with a 5.2 and auto complete rolling.
Put the Sweptline cab etc on the 93 chassis and get EFI, OD and power steering, brakes, handling plus a ride that won't break your back.
He bought the truck in Florida for a cab and sheet metal donor for his W350 Diesel Dodge. Drove it to Canada.
Kevin That would be great for my next project, but your some distance from me. By the time I got it here, it likely wouldn't be very cost effective for me. Gene
