Re: New bset ET at Woodburn
[Re: WFO]
#2681590
07/26/19 01:08 PM
07/26/19 01:08 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
It is close to 15.0 to one on 7 cylinders and close to 14.5 to 1 due to combustion chamber volume and deck height differences, it is not perfect I think I will recheck all eight cylinders again to make sure on the true compression ratio EDITED: I recheck all 8 cylinders on the compression ratio on United(KB) web site and it has between 14.56 to 1 lowest with 15.01 as the highest compression ratio due to deck height and combustion chamber volume differences
[Re: Cab_Burge]
#2681612
07/26/19 02:54 PM
07/26/19 02:54 PM
Posts: 109 Cottage Grove OR
WFO
Cottage Grove OR
It is close to 15.0 to one on 7 cylinders and close to 13.3 to 1 due to combustion chamber volume and deck height differences, it is not perfect I think I will recheck all eight cylinders again to make sure on the true compression ratio EDITED: I recheck all 8 cylinders on the compression ratio on United(KB) web site and it has between 14.56 to 1 lowest with 15.01 as the highest compression ratio due to deck height and combustion chamber volume differences Wow! I had no idea that E85 would support that much compression. That's impressive.
'65 Plymouth Sport Fury Blow thru twin turbo coming soon...
[Re: Cab_Burge]
#2682172
07/28/19 11:02 PM
07/28/19 11:02 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Good idea to try e98, or the highest you can get. I have been told there is better performance with pure ethanol, but never switched from methanol to see how pure ethanol and methanol compare.
[Re: BigBlockGTS]
#2682299
07/29/19 11:09 AM
07/29/19 11:09 AM
Cab_Burge
I do, but I don't know how to put them on here
[Re: gregsdart]
#2682592
07/30/19 07:14 AM
07/30/19 07:14 AM
gregsdart
Good idea to try e98, or the highest you can get. I have been told there is better performance with pure ethanol, but never switched from methanol to see how pure ethanol and methanol compare. Cab, big congrats on the new best. That's hauling the mail with a stock block build😁 Back to the ethanol; it lands somewhere between race gas and methanol for power produced. Best thing though is if you can buy it directly from an ethanol plant? Never done it, but have been told some plants will sell it that way if you bring your own barrel. Then you know exactly what you have. Mix in 1 at Klotz and you are good to go!
Re: New best ET at Woodburn
[Re: Cab_Burge]
#2682596
07/30/19 07:47 AM
07/30/19 07:47 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Good to hear you're back at it.. I would imagine once it's all sorted out it's going to be fun
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
