Re: New bset ET at Woodburn [Re: WFO] #2681538
07/26/19 10:52 AM
07/26/19 10:52 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Congrats on the new best Cab ! up Ron
Re: New bset ET at Woodburn [Re: WFO] #2681590
07/26/19 01:08 PM
07/26/19 01:08 PM
Cab_Burge Online work OP
Cab_Burge  Online Work OP
It is close to 15.0 to one on 7 cylinders and close to 14.5 to 1 due to combustion chamber volume and deck height differences, it is not perfect whiney
I think I will recheck all eight cylinders again to make sure on the true compression ratio confused
EDITED: I recheck all 8 cylinders on the compression ratio on United(KB) web site and it has between 14.56 to 1 lowest with 15.01 as the highest compression ratio due to deck height and combustion chamber volume differences shruggy
Re: New bset ET at Woodburn [Re: Cab_Burge] #2681610
07/26/19 02:46 PM
07/26/19 02:46 PM
tboomer Offline
tboomer  Offline
Way to go Cab! You still have it! up
Re: New bset ET at Woodburn [Re: Cab_Burge] #2681612
07/26/19 02:54 PM
07/26/19 02:54 PM
Cottage Grove OR
WFO Offline
WFO  Offline
Cottage Grove OR
Originally Posted by Cab_Burge
It is close to 15.0 to one on 7 cylinders and close to 13.3 to 1 due to combustion chamber volume and deck height differences, it is not perfect whiney
Wow!
I had no idea that E85 would support that much compression. That's impressive.
'65 Plymouth Sport Fury
Blow thru twin turbo coming soon...
Re: New bset ET at Woodburn [Re: WFO] #2681723
07/27/19 12:36 AM
07/27/19 12:36 AM
I'm thinking of upping the alcohol percentage to 90+ % to see if it will go faster or not with that mix work
Re: New bset ET at Woodburn [Re: Cab_Burge] #2682172
07/28/19 11:02 PM
07/28/19 11:02 PM
gregsdart Offline
gregsdart  Offline
Good idea to try e98, or the highest you can get. I have been told there is better performance with pure ethanol, but never switched from methanol to see how pure ethanol and methanol compare.
Re: New bset ET at Woodburn [Re: gregsdart] #2682260
07/29/19 09:19 AM
07/29/19 09:19 AM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
Cab- Do you have photos of your cars available somewhere??
Re: New bset ET at Woodburn [Re: BigBlockGTS] #2682299
07/29/19 11:09 AM
07/29/19 11:09 AM
I do, but I don't know how to put them on here whiney
Re: New bset ET at Woodburn [Re: Cab_Burge] #2682358
07/29/19 01:25 PM
07/29/19 01:25 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Sorry for being late to the party. That car's haulin' a$$!
Re: New bset ET at Woodburn [Re: gregsdart] #2682592
07/30/19 07:14 AM
07/30/19 07:14 AM
gregsdart Offline
gregsdart  Offline
Cab, big congrats on the new best. That's hauling the mail with a stock block build😁
Back to the ethanol; it lands somewhere between race gas and methanol for power produced. Best thing though is if you can buy it directly from an ethanol plant? Never done it, but have been told some plants will sell it that way if you bring your own barrel. Then you know exactly what you have. Mix in 1 at Klotz and you are good to go!
Re: New best ET at Woodburn [Re: Cab_Burge] #2682596
07/30/19 07:47 AM
07/30/19 07:47 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Good to hear you're back at it.. I would imagine once it's all sorted out it's going to be fun
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: New bset ET at Woodburn [Re: BigBlockGTS] #2682625
07/30/19 09:41 AM
07/30/19 09:41 AM
SE Washington
Forest Offline
Forest  Offline
SE Washington
I have this one...no action shots from Woodburn though...
