Page 2 of 3 1 2 3
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: Dragula] #2678091
07/16/19 09:48 PM
07/16/19 09:48 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
So I was watching Road Kill General Mayham Hellcat transplant edition........And it seems the stock drive train in a B-body is 10.90.....A little slower than I would like...but reliability
https://www.youtube.com/watch?v=qRh5KIVO3CM
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: Dragula] #2678110
07/16/19 10:40 PM
07/16/19 10:40 PM
IL
furious70 Online content
furious70  Online Content
IL
That was a hasty deal, I'd think there's more in that combo. I'm surprised that they haven't gone back to the strip with it
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: Dragula] #2678150
07/17/19 01:32 AM
07/17/19 01:32 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
750 hp (about what it would put out in gross terms with a good tune) and 3800 lbs (guessing the weight) should get you high 9's-10.0's
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: WO23Coronet] #2678244
07/17/19 10:12 AM
07/17/19 10:12 AM
Dragula Offline OP
Dragula  Offline OP
That is where my car shines....If the Hellcrate weighs less than or equal to an Iron block 605 Hemi, I will be under 3300lbs.....My car loved the all aluminum Hemi weight wise until a rod left out the side. I figure the 605 is right around 650-680lbs.....
According to MMX the Hellcrate is 800lbs which is a lot more than I would like if that is correct. The big aluminum Hemi was under 500lbs wet, but when you look at the Hellcrate, its probably about right...with all that stuff on it......
If that is the correct weight, my car will be 3300lbs and then add me in for 3530 or so total....
The Wallace says 9.97 at 135.49 and that would be very acceptable....I can work on it from there...
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: DemonDust] #2678736
07/18/19 04:16 PM
07/18/19 04:16 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
Originally Posted by DemonDust
Originally Posted by Dragula
I knew someone would post that...I am looking for some actual feedback....The engines are under $15k, and I never see any in pro-street cars, only resto mods with a stick....
Ron Polidora put one in a 64 Dodge. Beautiful build.
I have one in my 64 Dodge 440.
I did use a gerst front suspension. It is a 727 built by John cope. Car went 10.00 with lower only, but it was making just a touch over 11lbs (about factory boost) with the longtubes and free exhaust. With an upper, it has been 9.32 so far. 8's are coming.
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: RonP] #2678794
07/18/19 06:33 PM
07/18/19 06:33 PM
Dragula Offline OP
Dragula  Offline OP
9.32.....Wow....What computer are you using, and how did you mount the engine?
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: Dragula] #2678817
07/18/19 06:59 PM
07/18/19 06:59 PM
Lebanon,IN
mr2performance Offline
Lebanon,IN
If you want to run a motorplate with a hellcat front cover, we have that program on our waterjet along with the earlier gen3 motorplate patterns. Mike
MR2PERFORMANCE RACE CARS 765 483 9371
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: mr2performance] #2678863
07/18/19 08:56 PM
07/18/19 08:56 PM
Dragula Offline OP
Dragula  Offline OP
Mike,
If you could e-mail a picture or two of how it integrates with the timing cover and accessories, and a price...I might take one...That has been the main reason I have not done one yet.
Don't get me wrong, I love the big Hemi, Its puts all your senses to the test just idling by, but reliability has not been its strong suit. I would love to have somthing I could do Drag Week with running mid 9's....
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: Dragula] #2678867
07/18/19 09:10 PM
07/18/19 09:10 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
I am running the Mopar crate kit. So factory PCM that is unlocked and I tune it with HP Tuners. When I had the front end built by Gerst, I had him put 3rd gen mounts on it and he supplied those with kit. Lined up 100% perfect.
Its been a while since I put pics on this site. Can I just add them? or do I have to host them somewhere?
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: Dragula] #2678880
07/18/19 09:59 PM
07/18/19 09:59 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Yeah a stock Hellcat can he stepped on pretty hard with pulleys
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: WO23Coronet] #2678919
07/19/19 12:23 AM
07/19/19 12:23 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
If you want to use a motorplate we do have them ready to go with tensioners and idlers mounts. This can be utilized with 5.7, 6.1, 6.4, and we also have one for hellcat and demon, yes they are different.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: DemonDust] #2679102
07/19/19 01:57 PM
07/19/19 01:57 PM
Dragula Offline OP
Dragula  Offline OP
Mike,
That looks like it would work for me. I typically run the 1-wire chevy 100amp setup on my plate....But my 35gph water pump this year has not been enough on the hot days in traffic thanks to my iron Siamese block.
What alternator are you running with that setup...Looks like you have it on the drivers side.Do you use a serp on the Alternator of V-belt? Is the elcetric water pump enough to cool it on the street? My goal would be Drag Week 2020...
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: Dragula] #2679109
07/19/19 02:34 PM
07/19/19 02:34 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
The alternator was spec'd by Jeff Sandlin, I can get you specs if necessary. It runs off the factory hellcat/demon accessory pulley using a serpentine belt. This is also hopefully a drag week build. Not sure if it will be enough to cool it or not. Will find out in a month.
SDG Motorsports
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: DemonDust] #2679117
07/19/19 02:59 PM
07/19/19 02:59 PM
Dragula Offline OP
Dragula  Offline OP
Really awesome...Strut front end....Nice!
The 100-140A work best for me on the street. I can't get away with a 60A anymore. Where did the hook up wire on the alternator end up? Mines on the back, so any position its in works.....Some are on the sides and end up in a bad spot.
If that is a Chevy water pump Meizere makes a billet mechanical version, although I bet the studs only go as deep as the plate and that would probably be a bad idea...
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: Dragula] #2679136
07/19/19 03:47 PM
07/19/19 03:47 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Originally Posted by 4406forPOWER
Also looking for real world swap details. How much fab do you need to do to fit one in a 70 e body? Best trans to use? ETs in an old muscle car? Thanks
From the pics I have collected, they look small in the engine bay. B & E body's have the same engine bay essentially and a G3 looks tiny in there....
My transmission plan is currently to run my billet drum 727 and my convertor from the 605 Hemi......If I can get the Hellcrate up 100hp, they will be in the same ballpark. But I did see an entire Hellcat drive train with the 8 speed trans and full wiring harness for sale on Racing Junk...I really never looked into the Nag 8 speeds to see of they fit. I would have to change gears in the Dana if I went that route...
Negative on the use of your 727. G3 hemis are a small block bell housing bolt pattern.
Negative on your negativity....Look up JW Ultra Bell, I have two, one for a big block, and one for a small block...It bolts on to the trans and is easily switched. Best thing that ever happened to a Mopar other than efi
Real easy to swap all the parts into a SB 727 case anyhow
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: HotRodDave] #2679164
07/19/19 05:03 PM
07/19/19 05:03 PM
Dragula Offline OP
Dragula  Offline OP
Literally, you can leave the trans in the car with the engine out, pull the convertor, swap the bell, re-install the convertor and switch engines....Ended up pulling the Hemi one year, and dropping a W2 motor in I had ready to go....Works like a charm and well worth the cost.
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: Dragula] #2679179
07/19/19 05:54 PM
07/19/19 05:54 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Positively! I was thinking of OEM cases.
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: cudadoug] #2679262
07/19/19 11:05 PM
07/19/19 11:05 PM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
May or may not be useful but TF-8 (70) teardown
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: DemonDust] #2681548
07/26/19 11:02 AM
07/26/19 11:02 AM
Dragula Offline OP
Dragula  Offline OP
Can you send me a rough cost for a plate for a Hellcat? dragula426@gmail.com is my e-mail. Include whatever pulleys and idlers are required and any new pics as yours gets closer. My other option is to switch out my Magnum Force front end for their newer one with the mounts on it.
I have not gotten any solid hits on my big 605 Hemi for sale, so I replaced the valve springs on it and ported the intake a bit further and its going back in the car next week, but I want to switch to Hellkitty power down the road. At a minimum, I want to buy one of those crate motors this winter and hide it away until this big Hemi sells or it lets go.....Or maybe they start making blocks again.
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: Dragula] #2684445
08/04/19 08:37 PM
08/04/19 08:37 PM
Dragula Offline OP
Dragula  Offline OP
Any updates with all the pulleys and stuff installed?
Page 2 of 3 1 2 3
