Epoxy/metal filler that will hold up in exhaust port?
#2678256
07/17/19 10:44 AM
07/17/19 10:44 AM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
Does such a thing exist? I have a pair of aluminum heads I bought used, not noticing that the exhaust ports have been opened up nearly to W2 size. With the standard headers, this would have a good amount of exhaust gas flow crashing into the header flange. I think there is enough material to seal, but I would prefer to be able smooth out the transition from the exhaust runner into the header.
This will be for a driver/street stroker. So it has to be a fix that will last more than a race or a season
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Epoxy/metal filler that will hold up in exhaust port?
[Re: Michael Ecks]
#2678293
07/17/19 01:03 PM
07/17/19 01:03 PM
Posts: 22,696 Bitopia
jcc
Bitopia
The max I have ever read about epoxy based is around 500F, and that is expensive, so my answer to your question is, no.
[Re: jcc]
#2678694
07/18/19 02:01 PM
07/18/19 02:01 PM
Posts: 2,645 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I wouldn't bother with epoxy/metal when the known fix is easy. Weld and grind.
2011 Drag Pak Challenger
[Re: Neil]
#2679154
07/19/19 04:40 PM
07/19/19 04:40 PM
Posts: 8,871 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Yes, you can weld on the outside of the header tube/flange connection and grind the inside opening bigger to a point. I can't see the headers making it around the block after this mod !! The weld on the thin gauge tube will make them brittle - the main reason virtually every header is welded on the inside of the flange.
[Re: Stanton]
#2679168
07/19/19 05:20 PM
07/19/19 05:20 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Obviously, the correct solution is to weld the heads up.
Whether or not the heads in question are worth the time and $$$ to go through that is another story.
[Re: fast68plymouth]
#2679181
07/19/19 05:58 PM
07/19/19 05:58 PM
Posts: 6,240 nowhere
Sniper
nowhere
They make W2 headers you know,
[Re: Sniper]
#2679204
07/19/19 07:52 PM
07/19/19 07:52 PM
fast68plymouth
So. Burlington, Vt.
They make W2 headers you know, Don’t dedicated W2 headers use the W2 bolt pattern?
[Re: Michael Ecks]
#2710257
10/26/19 09:04 PM
10/26/19 09:04 PM
jcc
Bitopia
This will be for a driver/street stroker. So it has to be a fix that will last more than a race or a season This is a new product from a company i buy material from, it's worth looking at, as there is nothing else available i am aware of. #575-N 3000F FEATURES Ceramacast™ 575-N is a fine-grain, alumina-filled, ceramic compound ideal for potting high temperature electrical components including lamps, heaters, vacuum feed-thrus, PTC devices, rheostats, and temperature sensors. Material properties include a temperature resistance to 3000 °F (1650 °C), dielectric strength of 150 Volts/Mil, compressive strength of 11,800 psi, and excellent chemical and moisture resistance. Ceramacast™ 575-N is supplied in powder form and is mixed in a ratio of 100 parts powder to 13-15 parts water. It is easily dispensed through pressurized dispensing equipment and hydraulically sets in 16 hours at room temperature and cures fully at 250 °F in 1-2 hours. Cured material exhibits a porosity of less than 2% and an extremely low shrink rate of less than 0.3% at 1000 °F. Ceramacast™ 575-N is available from stock in quart, gallon and five-gallon containers. Please contact Aremco's Technical Sales Department at technical@aremco.com for more information about this advanced high temperature adhesive. https://www.aremco.com/wp-content/uploads/2018/05/A04_18.pdf.
