Epoxy/metal filler that will hold up in exhaust port? #2678256
07/17/19 10:44 AM
07/17/19 10:44 AM
Columbus, GA
Michael Ecks Offline OP
Columbus, GA
Does such a thing exist? I have a pair of aluminum heads I bought used, not noticing that the exhaust ports have been opened up nearly to W2 size. With the standard headers, this would have a good amount of exhaust gas flow crashing into the header flange. I think there is enough material to seal, but I would prefer to be able smooth out the transition from the exhaust runner into the header.
This will be for a driver/street stroker. So it has to be a fix that will last more than a race or a season
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Epoxy/metal filler that will hold up in exhaust port? [Re: Michael Ecks] #2678261
07/17/19 11:03 AM
07/17/19 11:03 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I don't think what you are looking for exists.
However aluminum heads can be easily welded up.
Re: Epoxy/metal filler that will hold up in exhaust port? [Re: Michael Ecks] #2678293
07/17/19 01:03 PM
07/17/19 01:03 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
The max I have ever read about epoxy based is around 500F, and that is expensive, so my answer to your question is, no.
Re: Epoxy/metal filler that will hold up in exhaust port? [Re: jcc] #2678694
07/18/19 02:01 PM
07/18/19 02:01 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I wouldn't bother with epoxy/metal when the known fix is easy. Weld and grind.
2011 Drag Pak Challenger
Re: Epoxy/metal filler that will hold up in exhaust port? [Re: rickseeman] #2678888
07/18/19 10:09 PM
07/18/19 10:09 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Grind the header flange to match the ports.
Re: Epoxy/metal filler that will hold up in exhaust port? [Re: GODSCOUNTRY340] #2679013
07/19/19 10:11 AM
07/19/19 10:11 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Yes, you can weld on the outside of the header tube/flange connection and grind the inside opening bigger to a point.
Re: Epoxy/metal filler that will hold up in exhaust port? [Re: Neil] #2679154
07/19/19 04:40 PM
07/19/19 04:40 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I can't see the headers making it around the block after this mod !! The weld on the thin gauge tube will make them brittle - the main reason virtually every header is welded on the inside of the flange.
Re: Epoxy/metal filler that will hold up in exhaust port? [Re: Stanton] #2679168
07/19/19 05:20 PM
07/19/19 05:20 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Obviously, the correct solution is to weld the heads up.
Whether or not the heads in question are worth the time and $$$ to go through that is another story.
Re: Epoxy/metal filler that will hold up in exhaust port? [Re: fast68plymouth] #2679181
07/19/19 05:58 PM
07/19/19 05:58 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
They make W2 headers you know,
Re: Epoxy/metal filler that will hold up in exhaust port? [Re: Sniper] #2679204
07/19/19 07:52 PM
07/19/19 07:52 PM
So. Burlington, Vt.
So. Burlington, Vt.
Don’t dedicated W2 headers use the W2 bolt pattern?
Re: Epoxy/metal filler that will hold up in exhaust port? [Re: fast68plymouth] #2679217
07/19/19 08:28 PM
07/19/19 08:28 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Drilling holes is easier than welding exhaust ports.
Re: Epoxy/metal filler that will hold up in exhaust port? [Re: Sniper] #2679251
07/19/19 10:18 PM
07/19/19 10:18 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
W2 to LA header flange adapters, if you have room to space your header outwards.
Re: Epoxy/metal filler that will hold up in exhaust port? [Re: Michael Ecks] #2710257
10/26/19 09:04 PM
10/26/19 09:04 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
This is a new product from a company i buy material from, it's worth looking at, as there is nothing else available i am aware of.
#575-N 3000F
FEATURES
Ceramacast™ 575-N is a fine-grain, alumina-filled, ceramic compound ideal for potting high temperature electrical components including lamps, heaters, vacuum feed-thrus, PTC devices, rheostats, and temperature sensors. Material properties include a temperature resistance to 3000 °F (1650 °C), dielectric strength of 150 Volts/Mil, compressive strength of 11,800 psi, and excellent chemical and moisture resistance.
Ceramacast™ 575-N is supplied in powder form and is mixed in a ratio of 100 parts powder to 13-15 parts water. It is easily dispensed through pressurized dispensing equipment and hydraulically sets in 16 hours at room temperature and cures fully at 250 °F in 1-2 hours. Cured material exhibits a porosity of less than 2% and an extremely low shrink rate of less than 0.3% at 1000 °F.
Ceramacast™ 575-N is available from stock in quart, gallon and five-gallon containers.
Please contact Aremco's Technical Sales Department at technical@aremco.com for more information about this advanced high temperature adhesive.
https://www.aremco.com/wp-content/uploads/2018/05/A04_18.pdf
