electric fans #2677042
07/13/19 11:59 AM
07/13/19 11:59 AM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
what is the best!12 inch puller fans(i need 2) i dont care cost or amp draw, i need massive air movement . at idle or in traffic , my fans wont pull enough air through the radiator , a/c condenser, and inner cooler.. at speed, im fine. im at 180ish driving.230ish in traffic
Re: electric fans [Re: mcat4321] #2677050
07/13/19 12:28 PM
07/13/19 12:28 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
look around and find the ones that have the most amp draw. that will be your best bet and measure of air flow.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: electric fans [Re: Jerry] #2677061
07/13/19 01:07 PM
07/13/19 01:07 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Derale
They make a nice twin fan setup that moves air.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: electric fans [Re: mcat4321] #2677070
07/13/19 01:43 PM
07/13/19 01:43 PM
New York
polyspheric Offline
polyspheric  Offline
New York
An electric will come with a shroud, but it won't match your exposed radiator core.
Modify and/or extend it until it does. Any air striking the grill should only enter the core, and all air passing through the core must go through the shroud.
Boffin Emeritus
Re: electric fans [Re: polyspheric] #2677087
07/13/19 02:36 PM
07/13/19 02:36 PM
moparx Offline
moparx  Offline
absolutely ! ^^^^ and with that said, look at using OEM type fans only. they are WAY more robust, and pull WAY more air than any aftermarket fan, no matter what the aftermarket manufacturer claims.
as was also mentioned, those [OEM] fans with the most required amps to run, will require your wiring system be able to handle the current draw required.
beer
Re: electric fans [Re: moparx] #2677088
07/13/19 02:42 PM
07/13/19 02:42 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Seems I remember A body guys using Chevy HHR fans.... Chrysler minivan fit my Mirada nicely
Re: electric fans [Re: J_BODY] #2677193
07/13/19 09:47 PM
07/13/19 09:47 PM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
An HHR wouldnt clear the water pump in my Duster with a Champion radiator, but a lot of people use them. A 2009 Challenger dual fan did fit with some decent trimming around the back of the fans/supports to squeeze it in there. That one did fit pretty well on a 26" radiator also.1990's Volvo 740, 850 or 950 2 speed fans move tons of air and amps if you want to build a shroud.
Re: electric fans [Re: j.mcconnell] #2677211
07/13/19 10:59 PM
07/13/19 10:59 PM
sweden
carter Offline
carter  Offline
sweden
This! And don't forget to take the 2-speed relay sitting next to the fan. wrench
Re: electric fans [Re: carter] #2677271
07/14/19 09:21 AM
07/14/19 09:21 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Late 90's Ford Contour V6 dual fans fit a 26" radiator quite nicely and have no problem cooling my 512.
Re: electric fans [Re: MarkZ] #2677277
07/14/19 09:49 AM
07/14/19 09:49 AM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
same one I use works good and is only 3.3 inches thick
Re: electric fans [Re: plycuda] #2677529
07/15/19 09:37 AM
07/15/19 09:37 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I used to have a dual fan built into a shroud that I had to use as a pusher.It worked,,,,,,ok untill one day the 140+ mph hitting the fan made it centrifugally EXPLODE! I replaced it with a single Spal fan and used the two feeds off the 2 relays to feed it.I had one relay for each of the duals in case one cripped out I could still make it home,,,,well it turned out the spal fan is a multi speed as when I hit the 2nd switch the fan sped up boogie
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: electric fans [Re: hemi-itis] #2677571
07/15/19 11:26 AM
07/15/19 11:26 AM
an8sec70cuda Offline
P5007266 from your dodge dealer. It's the electric fan/shroud module for a 2003 dodge Viper if I'm not mistaken. It's what I have on my cuda. It has two speed settings and I swear the faster one will pull the car forward, lol. It does draw a bunch of amps, but it works great. Not expensive either, at least it wasn't when a friend that works at the dealer got me one about 10 years ago.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: electric fans [Re: polyspheric] #2677697
07/15/19 04:00 PM
07/15/19 04:00 PM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
I'm currently working with Wizard Cooling to take their 1970-73 26" B/B MOPAR APPLICATIONS ALUMINUM RADIATOR SKU = 375-100 (with the 1.25" tube upgrade) https://wizardcooling.com/1970-73-26-b-b-mopar-applications-aluminum-radiator/ and have them mount the Mercedes C class fan with Micro Autonomations Fan Speed Controller http://www.ma-uav.com/FanControllerv3.html
The Mercedes shroud completely covers the 26" rad core, it's PWM controlled and it moves an incredible amount of air. I've been researching the optimal electric fan cooling system for my 'Cuda and to me, this makes the most sense and fits into the space in my engine bay.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: electric fans [Re: rumblefish72] #2677954
07/16/19 02:46 PM
07/16/19 02:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Make sure your fan has the spill rings in it.. much better fan(spill ring
is the outer ring which makes the fan much more efficient)
wave
Re: electric fans [Re: rumblefish72] #2678344
07/17/19 03:25 PM
07/17/19 03:25 PM
Halifax, VA.
moparjack44 Offline
moparjack44  Offline
Halifax, VA.
Looks like it would work, but you would have to be a rocket scientist to figure how to wire, using these videos. Way over the head of this simple man? shruggy
K.I.S.S.
Re: electric fans [Re: rumblefish72] #2678442
07/17/19 08:43 PM
07/17/19 08:43 PM
pa
gregcharger72 Offline
pa
I have the Mercedes fan on my big block powered 72 charger using the above mentioned controller and it works great. Even in traffic the temp never goes above 190. The fan fits very nicely on a 26" radiator
