Re: electric fans
[Re: Jerry]
#2677061
07/13/19 01:07 PM
07/13/19 01:07 PM
Posts: 11,710 Portage,michigan
B3422W5
Portage,michigan
Derale They make a nice twin fan setup that moves air.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: electric fans
[Re: mcat4321]
#2677070
07/13/19 01:43 PM
07/13/19 01:43 PM
Posts: 4,206 New York
polyspheric
New York
An electric will come with a shroud, but it won't match your exposed radiator core. Modify and/or extend it until it does. Any air striking the grill should only enter the core, and all air passing through the core must go through the shroud.
Boffin Emeritus
Re: electric fans
[Re: polyspheric]
#2677087
07/13/19 02:36 PM
07/13/19 02:36 PM
Posts: 19,355 north of coder
moparx
An electric will come with a shroud, but it won't match your exposed radiator core. Modify and/or extend it until it does. Any air striking the grill should only enter the core, and all air passing through the core must go through the shroud. absolutely ! ^^^^ and with that said, look at using OEM type fans only. they are WAY more robust, and pull WAY more air than any aftermarket fan, no matter what the aftermarket manufacturer claims. as was also mentioned, those [OEM] fans with the most required amps to run, will require your wiring system be able to handle the current draw required.
Re: electric fans
[Re: carter]
#2677271
07/14/19 09:21 AM
07/14/19 09:21 AM
Posts: 4,405 Michigan
MarkZ
Worthy
Worthy
Late 90's Ford Contour V6 dual fans fit a 26" radiator quite nicely and have no problem cooling my 512.
Re: electric fans
[Re: MarkZ]
#2677277
07/14/19 09:49 AM
07/14/19 09:49 AM
Posts: 653 Fredericksburg Va
plycuda
Fredericksburg Va
Late 90's Ford Contour V6 dual fans fit a 26" radiator quite nicely and have no problem cooling my 512. same one I use works good and is only 3.3 inches thick
Re: electric fans
[Re: plycuda]
#2677529
07/15/19 09:37 AM
07/15/19 09:37 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I used to have a dual fan built into a shroud that I had to use as a pusher.It worked,,,,,,ok untill one day the 140+ mph hitting the fan made it centrifugally EXPLODE! I replaced it with a single Spal fan and used the two feeds off the 2 relays to feed it.I had one relay for each of the duals in case one cripped out I could still make it home,,,,well it turned out the spal fan is a multi speed as when I hit the 2nd switch the fan sped up
Re: electric fans
[Re: hemi-itis]
#2677571
07/15/19 11:26 AM
07/15/19 11:26 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
P5007266 from your dodge dealer. It's the electric fan/shroud module for a 2003 dodge Viper if I'm not mistaken. It's what I have on my cuda. It has two speed settings and I swear the faster one will pull the car forward, lol. It does draw a bunch of amps, but it works great. Not expensive either, at least it wasn't when a friend that works at the dealer got me one about 10 years ago.
Re: electric fans
[Re: rumblefish72]
#2678442
07/17/19 08:43 PM
07/17/19 08:43 PM
Posts: 112 pa
gregcharger72
pa
I'm currently working with Wizard Cooling to take their 1970-73 26" B/B MOPAR APPLICATIONS ALUMINUM RADIATOR SKU = 375-100 (with the 1.25" tube upgrade) https://wizardcooling.com/1970-73-26-b-b-mopar-applications-aluminum-radiator/ and have them mount the Mercedes C class fan with Micro Autonomations Fan Speed Controller http://www.ma-uav.com/FanControllerv3.html The Mercedes shroud completely covers the 26" rad core, it's PWM controlled and it moves an incredible amount of air. I've been researching the optimal electric fan cooling system for my 'Cuda and to me, this makes the most sense and fits into the space in my engine bay. I have the Mercedes fan on my big block powered 72 charger using the above mentioned controller and it works great. Even in traffic the temp never goes above 190. The fan fits very nicely on a 26" radiator
