Page 1 of 3 1 2 3
Overdrive Feedback #2676738
07/12/19 08:20 AM
07/12/19 08:20 AM
Texas, USA
ChrgrCuda Offline OP
Texas, USA
Just thought I'd inquire again regarding feedback on folks who have installed O/D's in their B-Bodies and how well you may or may not like it, ease of installation and cost. Not trying to get any arguments, just feedback. I've been busy with customer cars so I haven't been able to spend time with my own, however once I'm done with a few customers slots I'm going to schedule my own car in for some overdue mods. Basically, I want my 69 440 Charger to be as reliable if needed to drive on a Power Tour and not be taxed by my current Dana 60 with 3.73's. I've found a lot out already by searching, just thought I'd get any current upgrades or info.
Darren
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Overdrive Feedback [Re: ChrgrCuda] #2676786
07/12/19 11:44 AM
07/12/19 11:44 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I love my A518 in my 68 Charger, was a lot of work to fit it in the car, would I do it again ? YES !!!! smile 4000 stall lock up converter smile
Re: Overdrive Feedback [Re: CSK] #2676789
07/12/19 11:59 AM
07/12/19 11:59 AM
Texas, USA
Texas, USA
Did you have to cut the floor and or cross member up?
Re: Overdrive Feedback [Re: ChrgrCuda] #2676797
07/12/19 12:37 PM
07/12/19 12:37 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I did the LGT-SS700 5-speed trans. I really like the overdrive, and diphram clutch, but install was a pain. Did have to cut top of tunnel for shifter and the T-bar brace in the tunnel for clearance. The speedometer cable still comes out at the crossmember, so clearance is a problem there too, but it works. I don't know what the best overdrive option is if you want to maintain the stock trans tunnel?
The kit I received was supposed to fit, but what they did was use a trans crossmember that dropped the back if the transmission down about 1.5 to 2" from stock. This tilted the engine back to where the headers were hitting the suspension, and the air cleaner was tilted too. So to get it to fit, had to cut T-Bar bracket inside the tunnel to get the trans output back to stock height.
Re: Overdrive Feedback [Re: 451Mopar] #2676811
07/12/19 01:00 PM
07/12/19 01:00 PM
Texas, USA
Texas, USA
Yeah that's what I don't want to get into. The Gear Vendors is the simplest, however I'm still on the fence as it's only .78 O/D. The SST A41 has a .70 O/D and also fits extremely well from what I have read, however 2X the cost. I don't mind paying the difference if the A41 is that much better.
Re: Overdrive Feedback [Re: ChrgrCuda] #2676824
07/12/19 02:14 PM
07/12/19 02:14 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
dent the floor , cut up & build a X member
Re: Overdrive Feedback [Re: CSK] #2676896
07/12/19 07:32 PM
07/12/19 07:32 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Pretty much any stick besides Passon's OD 4-speed or their $$$$ 5-speed is going to require some mods to the car, as far as I know.
The GV only requires some wiring, 2 switches, and driveshaft shortening, and that's a wash vs. any trans of different length than the 833.
I have one in my Dually with 4.10s and it made a world of difference, turning it into 3.20. 70-75 MPH is a piece of cake in OD.
It's also been bulletproof for almost 25 years.
Re: Overdrive Feedback [Re: topside] #2676898
07/12/19 07:41 PM
07/12/19 07:41 PM
IL
furious70 Offline
furious70  Offline
IL
I would have a hard time not having OD now....A500 behind the turbo 383 in my Fury and circa 2009 Keisler 5spd kit in my 68 Charger. The TKO was a PITA to get set up correctly and I don't like how it shifts at all, I'll never do one of those again, but OD and a/c are essential for me now up
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Overdrive Feedback [Re: ChrgrCuda] #2676970
07/13/19 02:35 AM
07/13/19 02:35 AM
sweden
carter Offline
carter  Offline
sweden
I have a G-V behind my 727 in a E-body and just love it. Have beating on it for 6-7 years and zero problem.
+ Easy install, just bolt on, simple wiring.
- Pricey
Re: Overdrive Feedback [Re: ChrgrCuda] #2676978
07/13/19 06:20 AM
07/13/19 06:20 AM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
I love my GV. My Coronet has a 3.54 Dana. The car is much more useable now. Minor clearance issues in the tunnel, no cutting required. I did have to tighten my 11” converter.
I also adjusted my pinion angle slightly after shortening the driveshaft.
Minor work really and the OD ratio is fine, see photo.
Re: Overdrive Feedback [Re: ChrgrCuda] #2676997
07/13/19 09:07 AM
07/13/19 09:07 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I found this chart as part of an answer to a question similar to the one the OP asked. It sums up my feelings on the matter. I have an E body and love the 518 behind my Hemi with 3.91s. I did not have to make any real mods to the car, just some light massaging. I will probably re-make the tranny mount sometime soon since I am not happy with the one I have now. And the only other thing that I would like to be different would be the weight. Man that thing is heavy.
So you think the GV is a cleaner install? Maybe. If you don't mind the weight of a GV unit hanging off a long lever arm bolted to the back of a 727 case that wasn't designed for it I don't see how you would mind having a different transmission crossmember supporting a factory designed transmission.
GV = .78 OD
500/518 = .68 OD
Using a 275/60-15 rear tire and 3.23 gears this is what the numbers look like at 60 mph:
No OD = 2300 rpm
GV = 1900 rpm
518 = 1600 rpm
75 mph:
No OD = 2900 rpm
GV = 2300 rpm
518 = 2000 rpm
For you hot rodders out there here's what it looks like with 4.10 gears.
60 mph:
No OD = 3000 rpm
GV = 2300 rpm
518 = 2000 rpm
75 mph:
No OD = 3700 rpm
GV = 2900 rpm
518 = 2500 rpm
Master, again and still
Re: Overdrive Feedback [Re: DaveRS23] #2677052
07/13/19 12:31 PM
07/13/19 12:31 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
that extra 300-400 rpm drop is pretty significant at 75 mph. 80-85 is probably the flow of traffic on the highway here. gear vendors really missed the boat not offering a bigger gear reduction.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Overdrive Feedback [Re: Jerry] #2677058
07/13/19 12:56 PM
07/13/19 12:56 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Good info, Dave; yeah, that's significant.
For a stick, though, choices are more difficult.
Re: Overdrive Feedback [Re: topside] #2677086
07/13/19 02:31 PM
07/13/19 02:31 PM
moparx Offline
moparx  Offline
since an A500 was mentioned behind a 383, how much HP and torque can one of those handle, and what was used to adapt the A500 to a big block ?
beer
Re: Overdrive Feedback [Re: ChrgrCuda] #2677154
07/13/19 07:06 PM
07/13/19 07:06 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Rule #1: only read your own posts
Rule #2: there is no Rule #2
Rule #3: see Rule #1
Boffin Emeritus
Re: Overdrive Feedback [Re: ChrgrCuda] #2677191
07/13/19 09:45 PM
07/13/19 09:45 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Darren
Give Darren Smith a call at Pro Trans. They’re in Waco TX now and he’s done OD builds and installs. Believe he’s also putting one in his Coronet build 👍🏻
Re: Overdrive Feedback [Re: moparx] #2677215
07/13/19 11:08 PM
07/13/19 11:08 PM
IL
furious70 Offline
furious70  Offline
IL
beer
I have it my 4200lbs fury. Turbo charged 383 but not a high power unit yet. Street car not a race car but it's been fine.
Tranztech in Dubuque ia does it, bb 727 bell is cut off and bolted on so everything oem still hooks up.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Overdrive Feedback [Re: moparx] #2677223
07/13/19 11:30 PM
07/13/19 11:30 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
beer
No problem:
http://smrtrans.tripod.com/smrtransmissionsintro/index.html
One of the Mopar magazines did a favorable article on these Guys.
I would definitely go 904-based transmission given the first gear ratio options and less parasitic drag.
I learned one thing quickly after owning my first 4 speed 318: the 727 is a power-sucking turd. I've had 318's and 360's with 727-based transmissions (3 speed and 4 speed od's) and they subtract a noticeable amount of horsepower. twocents
Mo' Farts
Moderated by "tbagger".
Re: Overdrive Feedback [Re: ChrgrCuda] #2677235
07/14/19 12:24 AM
07/14/19 12:24 AM
NW Illinois
MoonshineMattK Offline
NW Illinois
I have a keisler TKO in my charger from around 2003 and installed an 855 over the winter in a customers car.
The only way you know the 855 from an 833 is the 5th gear and the speedometer gear on the passenger side.
Its truly bolt in. I'd never do another TKO
Re: Overdrive Feedback [Re: polyspheric] #2677283
07/14/19 10:09 AM
07/14/19 10:09 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Originally Posted by polyspheric
Could it be installed backward as an underdrive, multiplying each gear by 1.286 (inverse of .7778) to use your existing tall axle and still have a big SLR?
I don't know.
I don't think you install it backwards, but GV does offer underdrive units as well as overdrive units.
Page 1 of 3 1 2 3
