Re: MSD coil compatibility
[Re: A/MP]
#2676574
07/11/19 02:12 PM
07/11/19 02:12 PM
Posts: 13,493 Marion, South Carolina [><]
an8sec70cuda
Its not the distributor that is of issue, its the ignition box. Pick a coil and see if it will work with your ignition system.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: an8sec70cuda]
#2676586
07/11/19 02:44 PM
07/11/19 02:44 PM
Posts: 314 Medina, OH
dart440_72
Medina, OH
What happens if you use a coil that isn't compatible with your ignition? I have been running a 6AL with a HVCII coil for years. Seems to be ok
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
[Re: dart440_72]
#2676588
07/11/19 03:07 PM
07/11/19 03:07 PM
Posts: 12,303 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
HVC II Blaster #8253 is a preferred coil for a 6. The Pro Power 8261 is not.
[Re: WS68SSC]
#2676605
07/11/19 03:56 PM
07/11/19 03:56 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
I used those two MSD parts with both a 7AL, 7AL3 and a Digital 7 box FWIW.
[Re: birdtracker]
#2676638
07/11/19 07:20 PM
07/11/19 07:20 PM
Posts: 13,690 md
mopars4ever
md
[Re: fourgearsavoy]
#2676717
07/12/19 06:54 AM
07/12/19 06:54 AM
Posts: 8,080 Tulsa OK
Bad340fish
Tulsa OK
I didn't have good luck with the blaster SS, had to go back to the good old Blaster 2
68 Barracuda Formula S 340
