MSD coil compatibility #2676404
07/10/19 08:59 PM
07/10/19 08:59 PM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
Will MSD Ignition Coil (Part # MSD 8207) work with MSD Pro-Billet Distributor (Part # MSD 8546)?
Thanks guys!
Re: MSD coil compatibility [Re: WS68SSC] #2676406
07/10/19 09:19 PM
07/10/19 09:19 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Its not the distributor that is of issue, its the ignition box. Pick a coil and see if it will work with your ignition system.
Re: MSD coil compatibility [Re: A/MP] #2676416
07/10/19 09:55 PM
07/10/19 09:55 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Re: MSD coil compatibility [Re: A/MP] #2676574
07/11/19 02:12 PM
07/11/19 02:12 PM
an8sec70cuda Offline
iagree
CHIP
'06 GMC 2500HD LBZ Duramax
Re: MSD coil compatibility [Re: an8sec70cuda] #2676586
07/11/19 02:44 PM
07/11/19 02:44 PM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
What happens if you use a coil that isn't compatible with your ignition? I have been running a 6AL with a HVCII coil for years. Seems to be ok
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: MSD coil compatibility [Re: dart440_72] #2676588
07/11/19 03:07 PM
07/11/19 03:07 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
HVC II Blaster #8253 is a preferred coil for a 6. The Pro Power 8261 is not.
Re: MSD coil compatibility [Re: WS68SSC] #2676605
07/11/19 03:56 PM
07/11/19 03:56 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I used those two MSD parts with both a 7AL, 7AL3 and a Digital 7 box FWIW.
Re: MSD coil compatibility [Re: Bigcube] #2676618
07/11/19 04:59 PM
07/11/19 04:59 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
That's what I used on mine for a couple years with zero issues. In fact, in the for sale section now. Switching to Sniper system.
Re: MSD coil compatibility [Re: 1969RR] #2676636
07/11/19 07:09 PM
07/11/19 07:09 PM
birdtracker Offline
birdtracker  Offline
MSD says to use HVC coil if you are running E-85 not a blaster. Birdtracker
Re: MSD coil compatibility [Re: birdtracker] #2676638
07/11/19 07:20 PM
07/11/19 07:20 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: MSD coil compatibility [Re: mopars4ever] #2676662
07/11/19 09:12 PM
07/11/19 09:12 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I like the Blaster SS with a 6AL and Firecore distributor been working flawless for about 6 years now up
Gus beer
64 Plymouth Savoy
Dana 60
Re: MSD coil compatibility [Re: fourgearsavoy] #2676717
07/12/19 06:54 AM
07/12/19 06:54 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I didn't have good luck with the blaster SS, had to go back to the good old Blaster 2
68 Barracuda Formula S 340
