Re: MSD coil compatibility
[Re: A/MP]
#2676574
07/11/19 02:12 PM
07/11/19 02:12 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Its not the distributor that is of issue, its the ignition box. Pick a coil and see if it will work with your ignition system.
[Re: an8sec70cuda]
#2676586
07/11/19 02:44 PM
07/11/19 02:44 PM
Posts: 314 Medina, OH
dart440_72
Medina, OH
What happens if you use a coil that isn't compatible with your ignition? I have been running a 6AL with a HVCII coil for years. Seems to be ok
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
[Re: dart440_72]
#2676588
07/11/19 03:07 PM
07/11/19 03:07 PM
Posts: 11,542 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
HVC II Blaster #8253 is a preferred coil for a 6. The Pro Power 8261 is not.
[Re: WS68SSC]
#2676605
07/11/19 03:56 PM
07/11/19 03:56 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
I used those two MSD parts with both a 7AL, 7AL3 and a Digital 7 box FWIW.
[Re: birdtracker]
#2676638
07/11/19 07:20 PM
07/11/19 07:20 PM
Posts: 13,574 md
mopars4ever
md
[Re: fourgearsavoy]
#2676717
07/12/19 06:54 AM
07/12/19 06:54 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I didn't have good luck with the blaster SS, had to go back to the good old Blaster 2
68 Barracuda Formula S 340
