Aluminum Main Caps ? #2675838
07/09/19 04:29 AM
07/09/19 04:29 AM
new zealand
70wayfarer Offline OP
new zealand
i'm thinking of doing aluminum main caps on my 440/493 stroker, chasing 700-750 hp. what are the real world advantages, if any. it was suggested to do ali caps and timing belt to help with block damaging harmonics.
BCR and 440 sourse both do ali caps and both claim theirs are the ducks nuts.
any advice on this much appreciated. car will see mainly strip duty. TIA
Re: Aluminum Main Caps ? [Re: 70wayfarer] #2675880
07/09/19 09:04 AM
07/09/19 09:04 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Use the search feature and you'll likely get multiple threads that discuss the topic in more detail.
Re 440 Source vs BCR... I don't know that's even a valid comparison. I would have used BCR caps had they been available when my block work was done. If someone gave me that other brand's cap kit, they would still be in the box on my parts shelf.
Re: Aluminum Main Caps ? [Re: BradH] #2675886
07/09/19 09:36 AM
07/09/19 09:36 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The 440Source caps are not machined to the proper bore size for RB's, they're made for low deck blocks. So unless you're a machinist you'll spend more on those and subsequent machining than you would buying BCR's in the first place.
Re: Aluminum Main Caps ? [Re: 70wayfarer] #2675895
07/09/19 09:57 AM
07/09/19 09:57 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have the BCR aluminum caps and girdle. It is a nice setup, with all the hardware.
Shop around for machine work of fitting the caps to the block. Places I called were all over the place on cost, and not all shops can perform the work.
The BCR caps are designed to be used with their girdle kit. The 1/2" thick girdle will require a bit of extra work setting up the oil pickup tube if using the internal oil pickup.
Re: Aluminum Main Caps ? [Re: 451Mopar] #2675900
07/09/19 10:01 AM
07/09/19 10:01 AM
USA
hudsonhornet7x Offline
USA
I have owned both, and hands down the BCR setup with girdle was a much nicer piece. That is they way I would go.
Re: Aluminum Main Caps ? [Re: hudsonhornet7x] #2675925
07/09/19 10:52 AM
07/09/19 10:52 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
the biggest difference between our caps and the 440 source aluminum caps, is that ours are machined here in Michigan, and are backed and supported by a Michigan company. also all of our material comes from ohio, I could drive down and touch and see where its made if I wanted to. there is a lot to be said for usa made quality materials.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Aluminum Main Caps ? [Re: 70wayfarer] #2675960
07/09/19 12:20 PM
07/09/19 12:20 PM
I have several different race motors and pump gas street motors with the 440 Source caps on them, both low deck and high deck motors, with no girdles and no problems so far shruggy
I have a customers motor in the shop now that has the original BCR cap and girdle and it looks a lot nicer on the polished caps, if that matters to you shruggy
I'm not a fan of using steel bolt on main girdles or any other type of girdles on Mopar BB twocents The girdles will not stop the main webbing from cracking work shruggy
I use to only use the ductile iron main cap kits form Mopar but when they stop offering them I had to switch to another type whiney
Re: Aluminum Main Caps ? [Re: Cab_Burge] #2676017
07/09/19 03:30 PM
07/09/19 03:30 PM
new zealand
new zealand
ok then. thanks for the input guys. good info on both sides of the fence.
Re: Aluminum Main Caps ? [Re: 70wayfarer] #2676807
07/12/19 12:50 PM
07/12/19 12:50 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
There are some other choices out there as well, where you can receive customer service. PM me if need be,.
RIP Monte Smith
